DIY (Do-It-Yourself) Guides For all DIYs. |
03-28-2016, 11:40 PM | #1 |
Drives: 2015 BRZ Limited
Removing windshield cowl end filler?
Anyone know how to remove the trim pieces at each bottom corner of the windshield (formally referred to as the "cowl end filler")?
This piece: I want to run a wire behind it and I'd rather avoid breaking it by removing it incorrectly. I found a picture of the back if that helps: Last edited by inio; 03-28-2016 at 11:55 PM. |
03-30-2016, 04:10 PM | #2 |
Drives: Car
Haven't tried myself but from looking at the picture it seems like you just pull. It's fairly identical to how the rest of the panels in the car are attached. You can either pull at it with the blue piece connected or if you have room you can slide the entire piece disconnecting it from the blue piece.
The Following User Says Thank You to FirstWinter For This Useful Post: | inio (03-30-2016) |
03-30-2016, 04:12 PM | #3 |
Drives: 2013 satin white brz limited
Yes just carefully pull it off. If it does break however they are only $13 at the dealer just posted the part number in a thread for a guy earlier today.
The Following User Says Thank You to jasonojordan For This Useful Post: | inio (03-30-2016) |
03-31-2016, 08:15 AM | #4 |
Drives: 2013 Ultramarine FR-S
Super easy to do. Just had to do it a week ago. Like the photo shows, don't pull up, slide it out away from the windshield.
03-16-2019, 06:16 PM | #5 |
Drives: '13 BRZ Limited
Found this thread looking to remove mine. The subaru parts sites call it "COWL PANEL-SIDE"
The picture of the back posed by inio was helpful - you can see how the blue clip can slide out. I found it was opposite of what gl2filmerguy says - you need to slide the part toward the rear of the car (toward the windshield) to get it to slide off of the blue clip. The opening for the blue part is at the front, so sliding the piece rearward will release the blue clip. Once you have the cowl end off you can remove the clip and re-install into the cowl end, at least I found it was a lot easier to re-install by just pushing the clip in than trying to get everything positioned so you could slide it back on. Brightened up inio's picture so you can better see the details. Last edited by 86league; 03-16-2019 at 07:18 PM. |
Similar Threads | ||||
Removing cowl on frs | xcooperx | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 04-02-2015 03:57 PM |
Grimmspeed Oil Filler Cap | SilentMike | Engine, Exhaust, Bolt-Ons | 3 | 10-07-2013 10:37 AM |
For Sale: TRD Oil Filler cap | Panman | Australia Classifieds | 4 | 04-13-2013 07:22 PM |
Removing writing on front windshield | Chinadian | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 14 | 10-24-2012 07:08 PM |
Fuel Filler is on the Right!! | Guaruja | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 04-01-2012 05:55 PM |
