Old 05-04-2014, 03:57 PM   #113
ATL BRZ
Driving Coach
ATL BRZ's Avatar
Originally Posted by Yamajee View Post
Can I be convinced that this is an ignition coil faulty and just replace it?
Yes, but I'd demand the dealer do it. They can read the code in memory and you can point them to this thread with lots of documentation that P0351 is isolated to the cylinder #1 coil pack.
Old 05-04-2014, 04:16 PM   #114
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
We did all of that, I even had the mechanic hop in with me in the car and did the test, CEL popped up, still convinced that it was a reflash issue, in other words, the whole UAE is complaining about the pointless service centers we have in our dealership, believe it or not, I have to tell them that I am bringing my car in for service a week before I do because the oil is not available instantly, the jacks are not made for lowered cars, the warranty goes off even with a catback exhaust, so let's leave all of that aside and say that I shouldn't be worrying about DI seals failing correct? I should just replace the coil pack that is on the passenger side (my car is LHD) located underneath the black ECU and voila, no swapping like someone stated that brought engine failure to him or anything else, just swap out the old coil with the new coil, correct?
Yamajee is offline   Reply With Quote
Old 05-04-2014, 04:22 PM   #115
ATL BRZ
Driving Coach
ATL BRZ's Avatar
Sorry to hear of the poor service and response from your dealership techs. Seems to be the case for the majority of the dealers here as well.
Yes, I replaced the same coil myself and it wasn't too difficult, just need hand tools and patience. I have more details in this thread a few posts back. You should be able to replace it yourself just fine, just remember to stuff some rags below to catch any dropped bolts.
Old 05-04-2014, 04:28 PM   #116
Yamajee
Yamajee's Avatar
I have a rocket bunny kit so my fender wheel well liners are off, I think I'm able to reach the ignition coil by taking off the front right wheel and then working from there, I have a mechanic who will do this for me but I'll also help, thank you so much for the fast responses!
The Following User Says Thank You to Yamajee For This Useful Post:
ATL BRZ (05-04-2014)
Old 05-12-2014, 10:36 AM   #117
Thongpocket
Master Troll
Thongpocket's Avatar
Drives: 2013 BRZ Limited
Just got this on cyl 1 at the global time attack this past weekend. Going to take it in and hope they will replace the coil pack. My only mods are power blocks, K&N and exhahust. NO tune. 93 oct gas, 38k miles boughti n June 2012.
Thongpocket is offline   Reply With Quote
Old 05-12-2014, 11:06 AM   #118
ATL BRZ
Driving Coach
ATL BRZ's Avatar
#1 coil failure seems to be an inevitability for those who track their cars.
Old 05-12-2014, 01:45 PM   #119
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Hopefully you didn't clear the ECU as they will need to see it in memory before they replace it typically.
Also, be aware that when they pull it, they see RPM and speed readings. I had a service manager bitch at me because I was doing 98. I told him up front though that I was passing a semi on a 2 lane road and traffic pulled into the oncoming lane (honest truth about the CEL I had the day before I went to dealer).
They may question the power blocks if they notice, even though we all know this is a problem on 100% stock cars.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 05-12-2014, 02:18 PM   #120
Thongpocket
Master Troll
I already cleared it. If it pops up again I'll leave it and bring it in. Thanks.
Sent from my XT1080 using Tapatalk
Old 06-24-2014, 07:56 AM   #121
hyper4mance
hyper4mance's Avatar
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
Had the same issue this past weekend at the track. P0351 error, so I cleared it and jiggled the wires. Next run session it didn't come back, but I also kept the rev's below 7k rpm this time around (instead of shifting at 7400-7600 - ecutek tune). All seems well so far but I took a video of the error code before I cleared it. Hopefully subaru will replace the coil pack as well.
hyper4mance is offline   Reply With Quote
Old 06-24-2014, 02:00 PM   #122
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Which bites, because the check engine light disables cruise control, and I like to use cruise control after a long track weekend.
Coil packs are $80, and I don't run that many events, so hopefully I can get a year out of one. Kind of insignificant compared to the rest of the track expenses.
celica73 is offline   Reply With Quote
Old 06-24-2014, 02:06 PM   #123
Kido1986
Dodging cones
Kido1986's Avatar
Trick to clear it without erasing from memory (to gain CC back) is restart the engine three times, with a few minutes of drive time between each restart. Seems to clear it for me. Within 10 minutes of getting that CEL, I could have my CC back
Old 06-24-2014, 02:38 PM   #124
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
I never had a problem with any of my coil packs on my original FRS engine and wiring. When I swapped in a BRZ motor, wiring harness, etc after my fire I had coil pack 1 go bad and it actually left me stranded on the side of the road.
When I pulled it there was melted plastic on the inside like the spark was jumping through the coil pack to the head. This is actually what it was doing as I was blowing a the "Ign" fuse kept blowing the moment you would crank the engine.
Wish I had a picture but it appears I tossed it in the garbage.
Element Tuning is offline   Reply With Quote
Old 06-30-2014, 09:44 AM   #125
BoostedWrbBrz
Drives: 2014 Wrb Brz limited 6m
I just pulled this code on my car too. Also seems to stumble some times as well. Where can I buy a replacement coil?
BoostedWrbBrz is offline   Reply With Quote
Old 06-30-2014, 09:47 AM   #126
ATL BRZ
Driving Coach
ATL BRZ's Avatar
Subaru parts warehouse dot com
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Shutting off your "key-in-with-door-open" beeper -- it's very easy avusblue Cosmetic Modification (Interior/Exterior/Lighting) 2 08-13-2012 05:29 PM
