01-11-2016, 02:48 PM | #519 | |
Drives: Toyota GT86
The only thing you would need then are the oil cooler, the bolt, 1.5m a 2m hose and 4 clamps. That was at around 250€ at the time for me. Works also great for AT 86. My post about it
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
02-08-2016, 01:05 PM | #520 |
Drives:
I'm also wondering if other oil coolers are compatible. The FXT's 21311AA170 seems to be hard to get at a decent price.
Are the 21311AA180's and 120's going to work? Has anybody used a sandwich plate other than 21311AA170? |
02-09-2016, 09:33 AM | #521 |
Drives: BR86
Yes part AA180 fits . . . . see my recent post 516 !
03-10-2016, 01:27 PM | #523 |
Drives: bmw
i'm using one between cooler and filter, although between oem housing and cooler might be preferred (?)
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com |
03-10-2016, 02:37 PM | #524 | |
Yeah I was gonna put it between cooler and filter as you did. I don't think adapter between oem housing and cooler is possible as the oil cooler connector has male threads. What kind of adapter did you put? Do you have a picture?? |
03-13-2016, 12:26 AM | #525 | |
Drives: bmw
04-17-2016, 10:38 PM | #526 |
Drives: Tiny Bronco
I just installed this oil cooler. While I guess you can use the BRZ's heater hose with the Forester's pipe, I wasn't happy with the kink in the hose so I went to the parts store and got a heater hose with a 90 degree bend. Carquest/Dayco Part #: 19590336. I cut off one of the bends and had a 90 degree with a straight hose which worked.
I also decided to use the Forester's coolant pipe that bolts to the driver's valve cover. It was a PAIN to bolt on. I had to pop out the cam actuator harness ties which was tricky(they were anchored where the bolts thread in), then getting the upper bolt in was a nightmare. Also, the pipe was pointing straight up into the injector cover. I used a 1/4" drive extension and bent it out. I can see why Carnz's guide just had you use a long hose. I just didn't want to sling a heater hose down the side of my engine, so I went to painful route. |
04-22-2016, 03:40 AM | #527 |
Ex-MR2 owner
Drives: Scion FRS
Anyone else running this setup but through the throttle body? Currently have mine setup that way, will monitor temps at track this upcoming summer and see how much it brings the oil temps down.
04-22-2016, 10:49 AM | #528 | |
I prefer the throttle body route due to the ease of installation and the results are pretty good. |
04-22-2016, 09:49 PM | #529 |
I'm running it on mine. Plenty of Autox and track events, so far oil temps have been good. I also have a CSF radiator so that is helping too.
04-25-2016, 03:59 PM | #530 |
Drives: Pearl White '13 ZN6
so if you're going to track a turbo car a sandwich plate and oil cooler is necessary but not if it's N/A? What about supercharged cars? I mean they do run cooler than turbos right?
04-30-2016, 01:57 AM | #531 | ||
Ex-MR2 owner
Drives: Scion FRS
Was hoping to monitor and report oil temps after today's track day but unfortunately it was raining/cold out so I couldn't get a good idea on how much it brought temps down by compared to having no oil cooler. Hopefully the next track day stays dry and warm |
05-09-2016, 11:01 PM | #532 |
Ex-MR2 owner
Drives: Scion FRS
Went to the Ridge Motorsports Park yesterday in Shelton, WA. Oil temps were at 100 degrees celcius (Total 0W-30) during and after each session. But then again, it wasn't every warm. We'll see what the temps are at in a July track day.
Tags |
brz, fxt, oil, oil cooler |
Similar Threads | ||||
OEM Oil cooler from the 2.0 DIT Forester | Kostamojen | Engine, Exhaust, Transmission | 119 | 09-10-2019 05:28 AM |
Bought a 2014 Subaru Forester | EAGLE5 | Other Vehicles & General Automotive Discussions | 10 | 10-02-2013 12:54 PM |
2014 Forester key fob - nicer than BRZ | Turbowned | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 04-17-2013 03:35 PM |
BRZ 2.0L Turbo in 2014 Forester | Sleeperz | BRZ First-Gen (2012+) -- General Topics | 37 | 03-21-2013 06:42 PM |
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… | 2013GTRNate | BRZ First-Gen (2012+) -- General Topics | 12 | 02-01-2013 12:29 PM |
