Old 09-15-2019, 10:44 PM   #15
DAEMANO
Time Traveller
Yep, your TOB is on its' way out. Get it fixed soon.
You can optionally take the opportunity to upgrade the clutch, clutch fork with pivot, and either resurface or replace the flywheel at the same time.
The Following User Says Thank You to DAEMANO For This Useful Post:
Evil Jesus (09-16-2019)
Old 09-16-2019, 09:29 AM   #16
Originally Posted by Evil Jesus View Post
I think I saw your post in another TOB thread in this section. Did you have any clutch damage or flywheel damage?
Ugh, this is not a club I want to be a part of. In the 7 years I've had it I've been in the idle dropping and stalling club (literally the day I drove it off the lot), the HPFP crickets club, the condensation in the rear tail lamps club (3 F'n Times!), the coil pack failure club, the valve spring recall club, and now this one. Hooray February '12 build date!
Don't wait. If TOB melts down it takes everything related to it with it.
Old 09-16-2019, 10:54 AM   #17
toast
Drives: 14 BSP Edelbrock BRZ
Make sure you get a new TOB from the dealer and tell them you want the part for a '17+. It is the only place you can get the upgraded unit. Only way to tell is that there will be a white or yellow paint dot on it when you get it.
toast is offline   Reply With Quote
The Following 2 Users Say Thank You to toast For This Useful Post:
Evil Jesus (09-16-2019), Tcoat (09-16-2019)
Old 09-16-2019, 11:06 AM   #18
Very good point!
Make sure it part #SU003-07349 and has the dot like Toast stated. When I had mine done they were originally going to use the old part number which could have started the whole process over again.
Old 09-16-2019, 11:23 AM   #19
Evil Jesus
Evil Jesus's Avatar
Drives: '13 FR-S Raven 6MT
I had heard there was a new part. I'll be sure to get that one. Thanks for the part number and dot info.
EDIT:
Very good point!
Hey, sorry to bother you, but do you happen to know the part number for the old TOB? Just want to be armed with the proper information tomorrow when I go in.
Evil Jesus is offline   Reply With Quote
Old 09-16-2019, 03:55 PM   #20
EDIT:
Here is the service bulletin. It has the old and new numbers.
Old 09-16-2019, 04:47 PM   #21
Evil Jesus
Evil Jesus's Avatar
Excellent. Thank you so much.
Old 09-18-2019, 02:37 PM   #22
Evil Jesus
Evil Jesus's Avatar
So I took it in yesterday, 3 different techs looked at it. They said nothing is wrong and to just see if it gets worse.
Old 09-18-2019, 02:50 PM   #23
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
Interesting. Was it 4:50pm or something? Noises aren't necessarily something broken, but a good indicator of something happening internally. Hope you don't end up broken down somewhere
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
The Following User Says Thank You to Strife26 For This Useful Post:
Evil Jesus (09-20-2019)
Old 09-18-2019, 02:57 PM   #24
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Try another dealership.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following 2 Users Say Thank You to 8RZ For This Useful Post:
Evil Jesus (09-20-2019), Strife26 (09-18-2019)
Old 09-18-2019, 06:37 PM   #25
Hawk77FT
Drives: GTS 86
Throw out bearing, no doubt. Had issues with mine, opened up and voila...the tob was toast. At some point the clutch pedal got stuck at the bottom. Because I drove with it f..ed as it was, i had to replace the pressure plate too because it worn out the pressure plate legs. As a matter of fact I replaced the whole clutch with a brand new one, even though the clutch disk was still ok with some life left in it.
Hawk77FT is offline   Reply With Quote
The Following User Says Thank You to Hawk77FT For This Useful Post:
High pitched chirping when AC on?? Spectral Entity Issues | Warranty | Recalls / TSB 8 01-29-2021 05:50 AM
whining/whirring noise during high load/rpm clutch engagement 7thgear Issues | Warranty | Recalls / TSB 105 06-19-2017 11:04 AM
Is it bad to have my ankle fully extended forward when pressing the clutch? cat94 Scion FR-S / Toyota 86 GT86 General Forum 70 11-24-2016 04:10 PM
high pitched noise when clutch is engaged ( video attached) jotig Issues | Warranty | Recalls / TSB 9 07-05-2015 09:22 PM
TSB - FRS (re: High pitched chirping...) PNW FRS Issues | Warranty | Recalls / TSB 1 01-19-2013 01:05 AM
