Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
01-03-2019, 12:47 PM | #29 |
Drives: 2013 frs red
Is the racer x intake manifold a new piece?
01-03-2019, 01:24 PM | #30 |
01-03-2019, 01:47 PM | #31 |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Parts for our cars aint cheap . Sucks tho. I will be getting the revo intake. I am purchasing the grams throttle body to pair up with the intake. I will be selling my oft for ecutek. I want to believe I'll be able to push 220whp something on e85
The Following User Says Thank You to Dr. BRZ For This Useful Post: | fika84 (01-03-2019) |
01-03-2019, 02:01 PM | #32 | |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
Yeah we will be both spending a lot for NA power but its worth it to stay light for me. I was thinking of contacting Zach at DT to see if they have experience tuning the Revo intake before purchasing, since they did my tune for ACE headers on Ecutek. No E85 nearby so im stuck with 93 |
01-03-2019, 02:12 PM | #33 | |
01-03-2019, 03:14 PM | #34 | |
Yeah im at 2375 right now. I think I can only get to 2350 without stripping the interior. Planned this spring Dry carbon Fenders -7, MPH Dry carbon hood -8, lightening dash beam -5lbs, Sound Deading behind dash -5lbs. Hoping by summer either the ram air intakes or intake manifolds have some clarity on results/tune by then |
01-03-2019, 07:59 PM | #35 | |
The Following User Says Thank You to fika84 For This Useful Post: | Shark_Bait88 (01-04-2019) |
01-03-2019, 08:14 PM | #36 | |
I was thinking of doing the Chase Bays Brake Booster Delete along with ABS removal. Main concern is with the computers and traction control will that stuff act up/throw codes ect.? 50lbs off the heaviest part of the car (DR/FR) would be amazing! I saw someone on here updated to a manual steering shaft that would take a lot of weight off the same area as well. I mean the Alfa Romeo 4C (current dream car) has manual steering why cant we? |
01-03-2019, 08:26 PM | #37 | |
For the PS, I removed the motor under the dash and 3D printed a cover for it so that it is sealed. That motor weighs a good amount Then there is a 3 plug connector that needs all 3 wires connected so that it doesn't make weird relay noises. No check engine lights, no odd issues. Just be aware if you take the steering wheel off that you keep track of the steering angle sensor.. I put it back on 180 degrees off the first time and the car was freaking out as it thought I was turning when I was going straight! |
01-03-2019, 08:33 PM | #38 | |
Interested in any pics of what you did with the ABS. If they box and equipment is still there then you didn't loose any weight? So you can remove the PS motor and still keep the stock steering shaft? That would be better than a manual shaft conversion because you could always put the motor back in if it sucks. Already changed out the steering wheel made sure to keep everything intact |
The Following User Says Thank You to SuperTom For This Useful Post: | fika84 (01-04-2019) |
01-04-2019, 10:54 AM | #39 | |
The power steering motor is 5lb 3.8oz! The car knows it's missing, so it shows the steering wheel with exclamation point light in red, but it doesn't cause any issues. I would assume that whatever column you were to put in would also cause the same thing. |
The Following User Says Thank You to fika84 For This Useful Post: | SuperTom (01-04-2019) |
01-05-2019, 05:10 PM | #40 | |
Drives: Black BRZ
01-05-2019, 06:50 PM | #41 |
From RacerX FB "Working on prototypes 2, 3 and 4 of our FR-S / BRZ / GT86 intake manifold. For more info check our website."
The Following 3 Users Say Thank You to PuslarBrrrz For This Useful Post: |
01-06-2019, 05:16 PM | #42 | |
Similar Threads | ||||
Racer X Fabrication suspension parts, and development | Jeff@Racer X Fab | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 134 | 09-01-2016 05:02 AM |
Racer X Fabrication Suspension group buy: UCA, Rear LCA, Front LCA and more!! | Jeff@Racer X Fab | Groupbuys | 74 | 06-23-2014 09:08 AM |
Racer X Fabrication: Upper rear control arms, in stock/ready to ship!! | Jeff@Racer X Fab | Brakes, Suspension, Chassis | 25 | 01-24-2014 11:42 AM |
Racer X Fabrication, New vendor intro | Jeff@Racer X Fab | Announcements, Contests, Giveaways | 0 | 03-12-2013 11:50 AM |
Freed Engineering custom metal fabrication and parts development | bFreed | Announcements, Contests, Giveaways | 23 | 03-24-2012 03:35 AM |
