Old 05-12-2023, 09:52 PM   #141
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Originally Posted by Spawn_Of_Creation View Post
Another update: After driving on the lift, its amazing. everything is much smoother, even slightly spirited is planted and the slight body roll made no difference.
I've now installed my a/t tires and the wheel/tire combo is perfect. After the trimming and folding of the frame rail, I took a heat gun to the fender liner and molded it back for more room and its entirely intact. The combination with the 16x7+30 gives a few mm of clearance on all sides of the wheel well to full lock with absolutely no rub, no wheel spacers or steering limiters required. The tire is flush in the front with no poke. If i had any more poke, the tire would rub on the liner and bumper, if i had any more suck, the wheel would rub on the inner rail/fender.
how much work do you think would need to be do to fit a 225/55/17 on a 17x8 +38? The tire is 10mm shorter and looking at wheel it fit look to be with in the travel of my current autocross seatup height wise. Currently cursed with brembo, but i went about this all backwards
Breadman is offline   Reply With Quote
Old 05-13-2023, 06:34 PM   #142
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
Attachment 220527
My inner wheel edge on full lock is about 5 mm of clearance from rubbing the inside frame, which means you might rub on full lock. You will have to do the same frame rail cut and heat gun or removal of the fender liner still. Verus Engineering has a steering limiter kit if you want to run that in the front, but i think that might about the only thing different you will have to do. We might be able to get away with just 1" lift instead of a 1.5" lift. 235/55/17 is another option, i'll eventually get 2 of these to run in the rear when i start to do some rally.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 05-15-2023, 08:09 AM   #143
Breadman
Breadman's Avatar
Attachment 220527
Well if that is the case I might just run staggered with 215/55/17 in the front. I really dont want to start cutting up the frame and what not. Still in the planning phase so I'll continue to research.
Old 05-15-2023, 08:35 PM   #144
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
Attachment 220527
What app is that in the screen-shot?
mike_ekim1024 is offline   Reply With Quote
Old 05-15-2023, 09:57 PM   #145
Spawn_Of_Creation
Human
Wheel-it-fit https://wheel-it-fit.com
It's like $5 to unlock it. otherwise there's a demo car that you can still get size differences and comparisons
The Following User Says Thank You to Spawn_Of_Creation For This Useful Post:
mike_ekim1024 (05-15-2023)
Old 05-15-2023, 10:22 PM   #146
mike_ekim1024
That’s awesome to play around with. Interesting to see the wheel proximity to the springs also.
Old 05-18-2023, 07:11 AM   #147
grumpysnapper
grumpysnapper's Avatar
Throwing dirt around...
grumpysnapper is offline   Reply With Quote
The Following 10 Users Say Thank You to grumpysnapper For This Useful Post:
blsfrs (05-19-2023), Clipdat (05-20-2023), DarkSunrise (05-23-2023), JD001 (03-01-2024), mike_ekim1024 (05-18-2023), new2subaru (05-18-2023), Racecomp Engineering (05-18-2023), Spawn_Of_Creation (02-29-2024), Turdinator (11-22-2023), Wally86 (05-18-2023)
Old 10-27-2023, 11:06 AM   #148
The Red One
Planning summer road trip
The Red One's Avatar
Drives: 2019 Sport-tech RS. City car: GD3
Made a trip out to the Charlevoix rally over the weekend and much rain was anticipated to make it a slippery mud fest show.
Always nice seeing other cars besides STI’s and seeing what an 86 can do is always a treat.
Unfortunately he DNF due to an off road incident, hopefully it will be repaired in time for his home rally late next month.
More rallying picts in the OT photography tread
The Red One is offline   Reply With Quote
The Following 8 Users Say Thank You to The Red One For This Useful Post:
bcj (10-27-2023), beanswv17 (10-27-2023), grumpysnapper (11-05-2023), JD001 (10-27-2023), Jdmjunkie (10-27-2023), Racecomp Engineering (10-27-2023), Spawn_Of_Creation (02-29-2024), Wally86 (12-06-2023)
Old 02-29-2024, 08:28 PM   #149
Spawn_Of_Creation
Human
Just as an FYI y'all, TBW just released a 5mm thick rally skid plate, so now the Laile imported from japan isn't the only bolt on option, and now a much more affordable option exists.
beanswv17 (03-01-2024)
WORLD RALLY BLUE BRZ Compilation Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 1268 04-11-2023 01:44 PM
Rally GT86 - The Little Car That Could - Lots of rally video and photos! Circuit Motorsports Tracking / Autocross / HPDE / Drifting 48 10-12-2020 03:32 PM
BRZ/FRS VIS Carbon Fiber oem style hood and AMS style trunk. BNIB. js0uth Exterior Parts (Aero, Lighting, Etc.) 76 12-03-2014 04:37 PM
86 Farm Style (Rally Test?) [Video] BenArmstrong FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 81 04-10-2014 01:39 AM
Akio Toyoda Drives the 86 Rally Style (Dirt and Snow) nate89 Scion FR-S / Toyota 86 GT86 General Forum 3 02-09-2012 11:22 PM
