DIY (Do-It-Yourself) Guides For all DIYs. |
02-01-2015, 01:01 AM | #15 |
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
These should help. This is how my defroster circuit is wired on the right passenger footwell, behind the cover plate. You can see the seal for the door on the right edge. The wire going through the door goes to one end of the heater coil for the mirror, and the other goes to the same point on the left mirror, passing behind the shifter trim.
Here's a shot of how I grounded the turn signal and the heated part. I should probably have used a crimped connector, but I didn't have one on hand.
The Following User Says Thank You to JohnJuan For This Useful Post: | 6spd (02-13-2015) |
02-13-2015, 03:17 PM | #16 |
Drives: 2013 Raven FR-S
Do you have to add relay and fuse? or just tap into the rear defroster wire?
02-13-2015, 05:17 PM | #17 | |
The Following User Says Thank You to JohnJuan For This Useful Post: | 6spd (02-16-2015) |
Similar Threads | ||||
DIY: Auto dimming rear view mirror install | Longhorn248 | DIY (Do-It-Yourself) Guides | 64 | 01-21-2021 06:17 PM |
DIY: APR Door Mirror Install | RallySport Direct | DIY (Do-It-Yourself) Guides | 53 | 04-26-2019 03:08 PM |
DIY JDM frameless mirror install | ayau | DIY (Do-It-Yourself) Guides | 8 | 01-10-2014 08:36 PM |
Part number request for heated seat switch trim | azian_advanced | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 09-13-2013 11:02 PM |
How to install Homelink mirror? | Grimlock | Electronics | Audio | NAV | Infotainment | 10 | 06-10-2012 06:07 PM |
