Old 04-12-2022, 03:47 PM   #43
APEX Race Parts
FT86Club Official Vendor
APEX Race Parts's Avatar
Drives: Launch-Year Whiteout FR-S
Regarding GR86 specific fitments, we have a road map of the fitments we plan to offer and are just waiting for our engineers to work their magic and figure out exactly what's possible. We hope to have gen 2 specific direct fit and track oriented setups in our Forged VS-5RS model by the end of 2022 if all goes smoothly.
We also have continued testing and compiling data on what's needed to make the current 17x9" ET42 fitment work on the new chassis. Here's a summary of our findings:
Up front, inner clearance is reduced by about the same amount as the old TRD or performance package sachs struts were so a 5mm spacer minimum is needed up front with stock suspension and the 17x9" ET42 wheel. The 17x9" ET35 would be more ideal up front if sticking with stock suspension, however in back the track has been widened and the room behind the rear fender is slightly decreased. We have seen the 17x9" ET42 work with a 245/40-17 tire, however negative camber is needed depending on the exact tire used. Somewhere around -2.5 degrees minimum will be needed and something like a Hoosier R7b would just need a higher offset wheel or at least a healthy amount of rear fender shaving.
The 17x9" ET42 is a good option if adding negative camber in back and using coilovers to gain front inner clearance. Alternatively, if sticking with stock suspension, a front spacer along with extended studs and added camber via crash bolts can work.
So essentially it can work, however you will need to run a front spacer with the stock suspension or move to coilovers and add negative camber in back via adjustable lower control arms.
Here are a couple pics we just received along with fitment specs running the classic Forged EC-7R:
Fitment Specs:
F/R: 17x9 ET42 w/ 245/40-17 Kuhmo Ecsta tires
5mm front spacer
-2° camber in the rear, -3° camber up front
-Ian
Phone: 925.245.0773 | experts@apexwheels.com | Website | Instagram | Facebook | Blog
APEX Race Parts is offline   Reply With Quote
Old 05-07-2022, 01:30 AM   #44
bradsm87
Drives: It has 4 wheels
Keep up the good work guys.
The 17x9 +42 with 245/40 should be perfect with the bumper tab mod, which I really don't understand why people are so scared to do. It's a much better option than running sub-optimal camber just to fit a wheel/tire combo IMO. Check this example out of a bumper tab mod that keeps one mounting clip. You could fill it up with sealant to stop mud and dirt getting in the gap:
https://www.instagram.com/p/CZUVYYrJwM8/
You guys are the only ones out there that offer two different offsets that when purchasing two of each, suit great both front and rear on the Gen 2 without needing spacers at all. The 17x9 +35 would be great for the front with some decent camber (unlike the rear, it's beneficial to add more negative camber up front).
Your stock levels aren't looking good. The only way to get 17x9 +35 front and +42 rear is to buy Satin Black. Do you have more coming in?
bradsm87 is offline   Reply With Quote
Old 10-05-2022, 04:33 PM   #45
redlined600
redlined600's Avatar
Drives: Fr-s
Originally Posted by APEX Race Parts View Post
[CENTER]Shoot Details
EC-7R 17x9.5" ET40 in Anthracite
255/40-17 Nitto NT01
MCS 2WNR coilovers
Camber -3.5º F. / -2.8º R.
Please be the hero we need and make a 17x10.
Old 10-05-2022, 11:11 PM   #46
Edkwok99
Drives: GR86
Fitment Specs:
5mm front spacer
-Ian
Is the car on coilover? How much is it lowered?
Edkwok99 is offline   Reply With Quote
Old 10-06-2022, 01:28 PM   #47
APEX Race Parts
Appreciate the feedback. Gen I or gen II?
We offer a 17x9.5" ET40 fitment in both our EC-7R (soon to be discontinued) and our new VS-5RS forged wheel designs, and they are both great solutions for track enthusiasts running 255/40-17.
With that said, I understand there are certain tire compounds that run really wide that could benefit from a 10" wheel. If there is real demand, we are happy to pursuit it!
I believe the car is on coilovers, but I do not have those details unfortunately.
- Ryan
Old 10-06-2022, 02:49 PM   #48
Jdmjunkie
Drives: Scion FR-S 10 Series
- Ryan
Or a 18x10 +40 like 949 racing ran on their car. XXR made a wheel but I can find a set to save my life.
Jdmjunkie is offline   Reply With Quote
Old 10-06-2022, 05:30 PM   #49
APEX Race Parts
18x10" makes a bit more sense to me considering there is really good tire availability in 265/35-18, and that size can really warrant 10" wheels.
- Ryan
Old 10-06-2022, 06:22 PM   #50
redlined600
Drives: Fr-s
Personally, I'd run a 17x10 on a 1st gen. I don't know enough about the 2nd gen to understand if they have more or less room for tires.
I am aware that you offer a 17x9.5", I have my arc-8s for sale to fund a set right now. That said, I'd prefer a 10" wheel.
There are 17x10s available in 5x114.3, and specific fitment for NC miatas. 255s would be a perfect fit.
The Following User Says Thank You to redlined600 For This Useful Post:
APEX Race Parts (10-11-2022)
Old 12-09-2022, 03:14 PM   #51
APEX Race Parts
Gear Up Now for the 2023 Track Season and Save BIG with our Year End Clearance Deals
30% Off All Remaining Classic Forged Wheels
Both ARC-8R and EC-7R
Extremely Limited Quantities – First Come, First Served
► APEX | Flow Formed Lightweight 5x100 86/BRZ Wheels - Built to Perform APEX Race Parts Wheels and Tires 51 03-22-2023 11:45 AM
► APEX | 17” & 18” Forged EC-7R Wheel Group Buy APEX Race Parts Wheels and Tires 24 04-19-2021 08:00 PM
► APEX | NorCal 86/BRZ Needed For Photoshoot With Our All-New Forged EC-7R Wheels APEX Race Parts Northern California 3 07-06-2020 04:05 PM
► Styluz Wheels ► 17x7 18x7.5 5x100 ► In Stock ► Free Shipping FM Wheels Wheels and Tires 2 08-01-2013 05:18 PM
