Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
03-20-2019, 06:09 PM | #1 |
Drives: BRZ 2018
USDM BRZ tS question
Can someone tell me the part numbers of USDM tS springs/shocks as I want to fit them in my car?
Or pm me his MY18-19 tS chassis number as even dealers are not sure about the part codes except if they search them with chassis number? Thanks in advance! |
03-20-2019, 06:25 PM | #2 |
Wheels for Brains
If you're going through all that trouble already, why not get an aftermarket coilover system?
Going all OE will probably cost you the same. Looking up parts for just the standard BRZ/FRZ, just getting all 4 shocks, springs, and top hats already going to hit you at ~$800 USD from the dealer. tS version probably a little more. Then add tax if applicable (all of this is assuming you buy new from dealer). At $1K USD, there are really good entry level coil on the market already with adjustability |
The Following User Says Thank You to EndlessAzure For This Useful Post: | DarkPira7e (03-20-2019) |
03-20-2019, 06:30 PM | #3 |
Rust bucket enthusiast
I agree with what was said above. I also have checked Ebay for used TS/ PP parts as well. They are there and not too expensive, just make sure it shows "SACHS" and doesn't just say " fits 2017my" or whatever.
03-20-2019, 06:55 PM | #4 |
Drives: BRZ 2018
Actually I tried Ohlins coilovers for ~600Kms but due to our uneven roads along with the reduced rear suspension travel of Ohlins caused me more troubles than solved that's why I am searching for OEM quality sportier springs/shocks w/almost stock ride height.
Ohlins is a remarkable coilover with perfect behavior but not for my usage - no track days - and the roads I drive! |
03-20-2019, 07:06 PM | #6 | |
Drives: BRZ 2018
PS: This is my 4th Subaru and I trust more than anything else STI parts |
03-20-2019, 08:45 PM | #7 |
03-20-2019, 09:14 PM | #8 | |
$1000 coilovers are definitely going to ride and handle worse than the OEM TS parts.
The Following User Says Thank You to wparsons For This Useful Post: | venturaII (03-21-2019) |
03-20-2019, 11:41 PM | #9 | |
Wheels for Brains
Based on the dealer price listing provided by @norcalpb , it's going to cost way more than $1k USD from the dealer. Getting up to $1.5k to $2k, if that opens any doors on aftermarket systems. -------- In the end, @JIM THEO already mentioned they already tried coilovers in the past. Really up to them now if they are willing to bite the cost bullet on BRZ tS from dealership or give a different system a shot. A lot of the adjustable coilovers have shorter travel up front due to the construction & consideration for height adjustability that is independent from spring preload. The Ohlin V2 and Tein Flex A, etc, have this design. - Ohlin spring rate might also have been a little low (V2 being about 4 kg/mm), so if you are willing to bump up to 6 kg/mm, might be able to swing it. Another bet is to go with a euro-style coil-over, where height adjustment and preload are linked. They tend to have longer overall travel lengths. For example, K&W and Eibach systems are of this style. Last edited by EndlessAzure; 03-21-2019 at 12:07 AM. |
The Following User Says Thank You to EndlessAzure For This Useful Post: | JIM THEO (03-21-2019) |
03-21-2019, 05:41 AM | #10 |
Drives: BRZ 2018
@norcalpb I contacted some dealers last month with the codes you posted but their answer is they aren't sure if those part numbers are from tS, ONLY with chassis number they can check it that's why I ask for a tS chassis number.
Moreover, those codes are recently available in Europe where tS doesn't exist at all which makes me believe they are different from USDM tS springs/shocks. Bear in mind USDM tS springs are pink like STI ones and STI parts start with ST while the above part numbers have normal Subaru coding. @EndlessAzure exactly this, I have for sale a brand new Ohlins SUS-MP21 tested for less than 600 miles, perfect coilovers with fantastic rebound and quite comfort but NOT for my needs. |
The Following User Says Thank You to JIM THEO For This Useful Post: | chaoskaze (03-23-2019) |
03-21-2019, 10:28 AM | #11 |
Just a point that bugs me and adds zero value to the discussion other than making me feel better.
There is no such thing as a USDM BRZ. The D stands for "Domestic" as in where it was made. All US BRZs are USI, as in "Import" from the US perspective or USE for "export" from the Japanese. In contribution to the actual thread: The strut part numbers provided by Norcal are accurate for the USI Sti. I don't have the ability to check the springs. You need to check against a VIN not a chassis number.
The Following User Says Thank You to Tcoat For This Useful Post: | KoreanJesus (04-11-2019) |
03-21-2019, 10:29 AM | #12 |
Drives: 2020 BRZ tS
Someone previously posted these are the part numbers for the SACHS:
Right = 20310CA220 Left = 20310CA230 Rear = 20365CA210 |
03-21-2019, 12:19 PM | #13 | |
Drives: BRZ 2018
https://buyee.pixnet.net/blog/post/2...%AB-zc6-brz-st @Tcoat you are right US tS is probably the correct term. |
The Following User Says Thank You to JIM THEO For This Useful Post: | Tcoat (03-21-2019) |
03-21-2019, 12:47 PM | #14 | |
Similar Threads | ||||
'13 BRZ USDM vs EU Spec | leevanf | BRZ First-Gen (2012+) -- General Topics | 27 | 07-07-2017 04:09 PM |
FS-USDM Red TOMS | Cards2323 | Exterior Parts (Aero, Lighting, Etc.) | 9 | 10-26-2015 02:54 PM |
FT: JDM Clear Tom's to JDM or USDM Red Tom's | Kit523 | Canada Classifieds | 3 | 09-23-2015 08:56 PM |
WTT usdm tails | *KID* | ASIA | 0 | 01-16-2013 10:48 AM |
