10-31-2014, 07:29 PM | #57 | |
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | WORKS (10-31-2014) |
10-31-2014, 07:59 PM | #58 | |
Drives: WORKS CARB Legal Turbo BRZ
The BRZ uses a common Subaru sensor that has MAF and IAT sensors combined into a single unit. MAF sensors pre-turbo are very common on OEM applications, such as stock WRXs and STIs, and acceptable. '08 and up WRX and STIs even have a similar single unit MAF/IAT sensor built into the air filter housing. Hope this helps! Cheers.
11-07-2014, 09:31 AM | #60 |
Drives: FR-S 10 #103 AT
@WORKS
I officially love the layout of this system and am now starting to save for it. I want to know something though. How difficult would it be to limit the boost (or eliminate it if necessary) below 3000 rpm and run higher boost above that? I would rather keep the car mild and protect the engine in the low rpm and make more power in the upper rpm. This is my view of the best of both worlds. Much less likely to lose a rod or have other damage and still be even faster if you keep the revs up.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
11-07-2014, 02:40 PM | #61 | |
Good question. The misalignment you have noticed is not caused by our kit as it was noted by our engineers when we received the vehicle in stock form. Knowing this, the airbox was restrained into the correct stock alignment/location during the design process to ensure proper fitment (our kit will not cause a misalignment of the airbox). As you correctly noted, the misalignment does not affect function or performance, only fitment, but again was addressed in the above manner and is not a result of our kit. We plan to take new photos with the airbox in its correct position. In regards to installation, you do not need to remove the front bumper. Cheers.
11-07-2014, 02:48 PM | #62 |
Junior
Drives: a car
So @WORKS, why the decision to make a non intercooled setup?
11-07-2014, 02:51 PM | #63 | |
Cheers.
11-07-2014, 03:03 PM | #64 | ||
11-07-2014, 06:46 PM | #65 | |
With regards to fitment, our kit should bolt up to aftermarket headers that maintain the stock header outlet flange location. Remember that the stock header contains a catalytic converter and two O2 sensors, so replacing the OE header with an aftermarket one will likely require software adjustments to our base file. Spool characteristics are based on many factors that are unique to different header designs (volume, primary tube diameter, bend geometry, etc.) There are so many aftermarket BRZ header options that it's not possible to make definitive statements about what aftermarket headers will do to the spool characteristics of our kit. Hope that helps.
11-08-2014, 08:59 AM | #66 | |
Seems Legit
Drives: Toyota
No disrespect but this seems to be an ass backwards way of doing things. People interested in making power way to know what the vehicle is capable of putting down and to get away from the "like OEM ratings". That's why they dyno their car. They don't want a flywheel number or any conversions. If you put this kit out and say it's +80hp/tq you're going to be hammered for false advertising if that doesn't hold up on a dyno that measures at the wheels. Since you already have the kit installed, can you get some dyno pulls done on a dynojet, mustang dyno or dyno dynamics?
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
11-08-2014, 02:40 PM | #67 |
Drives: 13 FR-S AT
Get that CARB exemption and it will pay off big time! Oh and make sure and develop the kit for Auto Trans Cars
Hats off, I like this design!!!! |
The Following User Says Thank You to F1fletch For This Useful Post: | WORKS (11-14-2014) |
11-08-2014, 05:01 PM | #68 |
Drives: Sci FR-S, Fer F355, Toy Highlander
@WORKS .... Will this be able to be fitted to the TRD intake? I see you have it fitted to the OEM intake. The TRD intake tube doesn't have the 90degree bend and is a straight tube connection
The Following User Says Thank You to 355rockit For This Useful Post: | WORKS (11-14-2014) |
11-08-2014, 10:19 PM | #69 | |
Custom User Title
Drives: Asphalt FR-S MT
11-09-2014, 12:35 AM | #70 | |
Junior
Drives: a car
http://www.ft86club.com/forums/showthread.php?t=19572
Similar Threads | ||||
WORKS Stage 1 Turbo Kit Pre-Release Offer | WORKS | Northern California | 31 | 11-11-2014 07:24 PM |
Hello from WORKS Motorsports! **10% discount for FT86club Members!** | WORKS | Announcements, Contests, Giveaways | 1 | 04-16-2014 10:04 PM |
Full Blown Stage 2 Turbo Kit Official Release!! | FullBlown | Forced Induction | 53 | 11-18-2013 11:58 AM |
Discount offer on Tirerack | zoomzoomers | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 04-01-2013 05:45 PM |
Subaru $50.00 test drive offer/ $500.00 discount card | terrypm | BRZ First-Gen (2012+) -- General Topics | 7 | 08-24-2012 11:33 AM |
