Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
12-11-2013, 01:16 PM | #1 |
Drives: 2013 silver BRZ
Passanger window problems
Will not open or close with driver door control but will work with passanger side control... Wierd
12-11-2013, 01:28 PM | #2 |
SLO NO MO
The Following User Says Thank You to Foobar For This Useful Post: | scary alien (12-14-2013) |
12-11-2013, 01:29 PM | #3 |
(Jo_o)J
Drives: 2013 Raven FR-S
were the lights on the button flashing? She did that to me the other day cuz I tried to roll down the window when it was frozen. Started working again once it all melted...
12-11-2013, 01:30 PM | #4 |
No flash whatsoever and its only driver side control thats not working for opening it...passanger side switch works tho
12-11-2013, 01:43 PM | #5 |
Drives: 16 CBS WRX Limited
Gee whiz...another thread? I'm about to make a thread so everyone can hassle the mods to make it a permanent sticky.
The car needs to be on ACC 2 mode in order to reset the windows. |
12-11-2013, 03:22 PM | #6 |
SLO NO MO
12-11-2013, 10:19 PM | #7 |
12-11-2013, 11:02 PM | #8 | |
Drives: 2013 WRB BRZ Premium 6MT
OP, it's because your windows iced up and couldn't move, so they won't work on the drivers side control panel or when the door is open, and the lights on the driver side door should slowly flash. Just roll down the window using the passenger controls, keep holding it until it gets to the bottom, hold for 5 more seconds, roll it up while holding it, and let then hold for 5 seconds. That should reset it. |
12-11-2013, 11:20 PM | #9 |
Oh.......my......
Maybe we should just go back to the cranks ..... they always worked ..... humfrz |
12-13-2013, 11:46 AM | #10 |
Drives: no
I literally had the same thing two days ago. I just did the reset and it's working again.
12-14-2013, 08:10 AM | #11 |
Drives: 2013 Scion FRS Asphalt
I dropped mine off this morning for some routine maintenance and noticed the same thing on my way there. Light was flashing, passenger side wouldn't go down with driver control. They'll probable reset it since I mentioned it. Glad to know it's not an electrical issue.
12-14-2013, 11:23 AM | #12 |
Drives: 2013 Scion FRS Raven Black M/T
If you read the owners manual it says how to reset it. What it is, is its a safety precaution. The car thinks there is something jamming the window so that's when it stops moving (blinking light) then to reset you just put the car in the "on" position and hold the button of the affected window up for a few seconds until it completely closes and stops flashing. This happened to me the other day it took a couple of tries to get it right but it works.
Sent from my SCH-I545 using Tapatalk |
The Following User Says Thank You to Danny86 For This Useful Post: | scary alien (12-14-2013) |
Similar Threads | ||||
Window Shatter / Fracture - passenger small triangular window | btune | Issues | Warranty | Recalls / TSB | 5 | 12-25-2016 02:14 PM |
squeaky window due to window rubbing against rubber at the top | tracerit | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 5 | 08-10-2013 05:34 AM |
Gas Problems | Kelbyat07 | Issues | Warranty | Recalls / TSB | 3 | 04-20-2013 09:21 PM |
An unexpected passanger on my way home. | Mr Franky | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 12-29-2012 10:47 PM |
No CEL problems here | BRZranger | Issues | Warranty | Recalls / TSB | 41 | 12-08-2012 01:36 PM |
