08-05-2019, 08:31 PM | #645 |
Drives: 2017 Toyota 86
Why is it the 2017 data isn't already on the tablet? Seems kind of stupid you have to email to get them.
08-06-2019, 03:12 AM | #646 | |
Drives: Toyota GT86
As an example I've linked the K00C page https://www.openflashtablet.com/shop...-us-6mt-v4-03/ If you want to look for an other calid use "za1j" and then your callId in the searchbar
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
08-30-2019, 08:45 PM | #647 |
Drives: 2015 Scion FR-S || Raven Black
08-30-2019, 11:31 PM | #648 | |
Drives: 2014 FR-S
Sent from my SM-G960U1 using Tapatalk |
09-05-2019, 11:49 AM | #649 |
Drives: 2013 WRB BRZ Limited
I'm sitting in the sonic drive thru line with the windows down. I think a fan in my engine just kicked on loud. Sounds like the same thing that happens when you are using AC I'm running stage 2+ 4.03. You guys ever have that happen?
01-02-2020, 12:19 AM | #650 |
Drives: Orange GTS
Hi all,
A little bit off topic here but to do with open flash tunes. I have just flashed the stg 1 tune and noticed what appears to be quite loud injector noise around 4k rpm at mild to full throttle applications . I dont see any IAM or knock corrections or very little if at all. Has any one else noticed this? Is it in fact inject noise to do with the new maps? Thanks for any help. Cheers Geoff. |
01-02-2020, 01:51 AM | #651 |
Drives: 2014 GT86
IIRC many had reported of more noises in that area after flashing tune. Should have to do with more aggressive timings to reduce torque dip. Normal, ignore.
01-02-2020, 03:05 AM | #652 | |
Sods like the vvt induction resonace due to agressive vvt tikng to redice torque dip. Take 10 degrees out of the exhaust cam timing in the last ad rpm range should stop it but you might get some torque dip back |
01-09-2020, 02:59 PM | #653 | |
Drives: Orange GTS
Thx guys. Along way off modify maps, just learning to crawl here. Have been trolling through dozens of post and rcall some saying UEL headers with stg2 tune will improve dip and eliminate noise ??? cheers |
01-09-2020, 09:36 PM | #654 |
Drives: Orange GTS
I have read you use rom raider is it easy to use. what about tunerpro
Cheers |
01-18-2020, 06:38 AM | #655 |
Drives: 2020 BRZ tS
Is there an estimated availability date for 2020 model year?
01-18-2020, 07:20 AM | #656 |
Drives: brz 2017 hksv2
it s not like they are officially released
ecutek already has them already you can ask openflash email if they have them |
01-18-2020, 12:33 PM | #657 |
Drives: 2020 BRZ tS
01-18-2020, 05:05 PM | #658 |
Similar Threads | ||||
Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Software Tuning | 130 | 08-25-2020 07:29 AM |
The latest EU/AU OFT tunes (D00G) don't come with launch control | jamesev93 | Software Tuning | 4 | 03-12-2018 04:14 PM |
Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Engine, Exhaust, Transmission | 3 | 08-27-2016 02:04 PM |
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes | Garrett@Openflash | Engine, Exhaust, Bolt-Ons | 54 | 06-11-2014 06:29 PM |
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) | Rombinhood@OpenFlash | Software Tuning | 237 | 02-10-2014 03:35 PM |
