Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
10-18-2019, 01:45 AM | #1 |
Drives: 2014 WRB BRZ Limited
Need help identifying parts for stripped subframe
So attempted my front sway bar install tonight, all was smooth until I was reattaching the sway bar mounts (well, the subframe braces the sway bar attaches to) to the underside of the car (4 bolts on each side). Somehow, one of the holes in the subframe is stripped slightly - bolt appears to be fine but won't thread in. I didn't force it so I'm really surprised it got stripped... The bolt that is stripped is one of the shorter ones.
It is this bolt shown here (M000352, there are 2 in the front and one in the back, but only shows 1 in front in this picture for some reason). In case this isn't clear, I'm following this rough install procedure. I'm at the 9:40 point in the video: [ame]https://www.youtube.com/watch?v=j7P5FYtbfXA&t=702s[/ame] (Thanks Justin) I have never had this occur (have done 3-4 sway bar installs on my old WRX and a few other suspension installs). I need to pick up a tap and die kit (have never used one before). Can anyone point me to the correct thread pitch of that bolt so I know what tap size to buy? I tried to no avail to find a service manual but couldn't find it. Any other tips? |
10-18-2019, 01:50 AM | #2 |
https://parts.subaru.com/p/Subaru__/...901000352.html
I see this mentions M10x26.5. Is the 26.5 the threads per inch or length? At first I thought it was threads per inch but now I think it is length... |
10-18-2019, 02:28 AM | #3 | |
[insert cool phrase here]
Drives: BRZ Premium
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
The Following User Says Thank You to Mr.ac For This Useful Post: | BR-ZED (10-18-2019) |
10-19-2019, 12:29 AM | #4 |
It is M10 1.25 in case anyone has this issue.
Home Depot has a little rig that you can test the bolt in. However it's easier to just measure with a ruler. 1.25 mm between threads indicates it is a M10 by 1.25 Got my die set I found it pretty easy to use... Got the threads all cleaned up and the car back together in time for the autocross this weekend . |
The Following 3 Users Say Thank You to BR-ZED For This Useful Post: |
10-19-2019, 12:32 AM | #5 | |
10-19-2019, 12:33 PM | #6 | |
ProCrastinationConsultant
https://www.boltdepot.com/Thread_detective_-_Metal.aspx
The Following 2 Users Say Thank You to soundman98 For This Useful Post: | BR-ZED (11-10-2019), EndlessAzure (10-19-2019) |
11-10-2019, 01:54 AM | #7 | |
Similar Threads | ||||
Parts Shop Max subframe and differential risers | philstar | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 53 | 02-20-2024 11:05 AM |
Stripped Studs | ckmninja | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 02-14-2019 01:22 PM |
REVIEW | DC Sports rear subframe brace / rear subframe lateral brace | mav1178 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 04-10-2014 08:59 PM |
Need help identifying a car! | kALMIGHTY | Off-Topic Lounge [WARNING: NO POLITICS] | 15 | 09-28-2013 04:35 AM |
Have you stripped some weight off your FRS? | gt8613 | Scion FR-S / Toyota 86 GT86 General Forum | 39 | 08-20-2013 02:11 PM |
