09-14-2019, 12:42 AM | #127 | |
Drives: "Baby Gurl" of FBM
I don't think your engine is sitting back further than anybody elses', I think nobody openly said the tunnel needed to be cut and boxed. Mine is cut and boxed just like yours. It isn't much, and boxing it isn't a huge deal, but I can imagine what a pain in the ass it would be to go off the assumption that banging the tunnel would make it work. Banging, test fitting, in/out, only to find it doesn't have clearance... If someone has a 2J/CD009 without the tunnel cut post pictures, or a story of the clunking noise the tranny makes when they shift. You're damn near there!
Full Blown Motorsports
2JZ/CD009 drag car with license plates IG: Stevemode62 |
09-14-2019, 12:47 AM | #128 | |
2 ugga dugga's
Drives: Nike
Want to 2JZ swap your 86? Click here first!!
The Following User Says Thank You to Clash0901 For This Useful Post: | Irace86.2.0 (09-14-2019) |
09-14-2019, 08:31 AM | #129 | |
09-14-2019, 11:15 AM | #130 |
Drives: Toyota GT-86
It's really cool that you got it.
09-14-2019, 01:42 PM | #131 | |
Drives: Q5 + BRZ + M796
09-23-2019, 10:08 AM | #132 |
2 ugga dugga's
Drives: Nike
The car starts so smoothly! I drove it around the block on just the basemap and everything seems to be working great. Clutch engages well, gears shift smoothly, no weird noises, etc.
I have taken the time to organize this spreadsheet of everything done to my car. This does not include labor on anything since I did about 99% of the work myself. https://docs.google.com/spreadsheets...mphP9cS4o/edit ^The prices list in this spreadsheet are all what "you should expect to pay". They are not indicative of what i've spent but I will say my total is close to $42k on all these parts listed. Meaning I saved myself some money in certain areas. Others may save more, or less than me but as i've said before. If you want a properly built car that makes decent power, expect to spend $40k minimum on top of already owning a BRZ. And that is assuming you can do all of the work yourself.
The Following 7 Users Say Thank You to Clash0901 For This Useful Post: | Cookiemonster (09-30-2019), Icecreamtruk (09-30-2019), Irace86.2.0 (10-09-2019), JesseG (09-23-2019), Lonewolf (10-19-2019), Sportsguy83 (09-24-2019), Zer0 (09-30-2019) |
09-24-2019, 11:48 AM | #133 | |
Drives: 2013 FRS
Last year I met up with a professional builder to talk about doing a 2JZ swap and after going through everything I came up with $40-45k as well. However, you would have a beast of a car for that price! And it sounds like you do! |
09-30-2019, 01:11 PM | #134 | |
Drives: 13 FR-S, 90 Honda ED6, 07 TBSS
09-30-2019, 01:21 PM | #135 |
2 ugga dugga's
Drives: Nike
Can you expand on that estimate? PM me and I will give you my honest opinion.
09-30-2019, 05:01 PM | #136 | |
Drives: '17 BRZ M6 & '17 Corvette Z06 M7
I know shops are extremely hesitant on giving these kinds of figures out (obviously I wouldn't expect a shop to ever give anything like what you've provided here, as you practically have a BOM w/ full on pricing and labor to boot)...BUT it's really good to see the LITTLE things that I haven't thought about or overlooked, because as you experienced, they add up...quickly. Just curious, what kind of power are you looking to make on 93 with the 364.5? Correct me if I'm mistaken, but that turbo maxes at 800HP potential, so I'm guessing on 93 with boost limitation, you're probably looking in the 550-600whp range on a solid but aggressive tune? I'm planning on running the 6466 or 6266 myself when the time comes depending on budget constraints and am eyeballing ~550+whp on 93 and 700whp on 93+meth. Post up some new pics my dude, need to see everything now that you're able to drive it! |
10-19-2019, 12:46 AM | #137 | |
Solid work on the spreadsheet. The prices for listed items seem right inline with what the parts would go for.
04-21-2020, 08:19 AM | #138 |
2 ugga dugga's
Drives: Nike
I've got a bad itch to drive my car, but I can't for a while. I had to take my axles out and send them back to DSS. Both axles were leaking grease from the boots and spraying onto the insides of my wheels. Seems like both seals were not tightened enough. No tears in the boots. Let's hope they fix them right this time. After shipping and another alignment, i'll be out an additional $150+ on top of the $900 or so I paid for axles. Of course you can't even put a number on the 1 month or more of downtime I will see. Pretty ridiculous but I guess it could always be worse.
Luckily, I have other things to do on the car while it's parked. Subaru 4/2 pot caliper install with new rotors and pads, flexfuel sensor install, some hood vents, couple other miner things. Will add some pics as I progress with these things.
05-22-2020, 03:28 PM | #139 |
2 ugga dugga's
Drives: Nike
Little updates here and there.
I ordered an eBay TRD replica spoiler that came paint matched for $140 shipped. It is a perfect fit and the paint match is literally 10/10. Looks amazing too. I had to debage the Subaru and BRZ emblems but that was long overdue anyway. I had the 600hp DSS axles on the car. At the time I purchased that was the only direct swap option without changing to 5x114.3 hubs. I put maybe 80 miles on them and found both boots leaking and spitting grease into the barrels of my wheels. DSS offered to repair them for free if I sent them in. I shipped them with Fedex and Fedex lost them. Luckily I had them insured but sadly it took me forever arguing with them to get some money. I then purchased their new 800hp direct swap axles and will be installing those tomorrow. I also upgraded my calipers to the 06/07 wrx 4/2 pots. I painted them myself using VHT silver base, anodized purple paint and clearcoat. I also installed all new Power Stop rotors and pads. Not pictured: I installed my flex fuel sensor with the GM quick connect fittings. E-85 coming soon!
The Following User Says Thank You to Clash0901 For This Useful Post: | Irace86.2.0 (05-22-2020) |
05-22-2020, 10:06 PM | #140 |
Hate to be a kill joy, but there is a good chance the paint could fade over time.
I replaced a side mirror for my lancer back in the day. $75 aftermarket versus $265 OEM, but it was apparent within a year or two where the extra money went, and it was to the paint. The aftermarket one looked identical, but the clear coat slowly faded over the year, and eventually, it was matte black. They either skimped on quality or on the layers of paint. Hopefully that isn't the case for you.
Similar Threads | ||||
Built Turbo K24 Swap? | Calmwhiteguy | Engine Swaps | 31 | 02-13-2018 05:07 PM |
Custom Grill Duct Backyard Build, Opinions? | Doobster | Cosmetic Modification (Interior/Exterior/Lighting) | 22 | 08-04-2017 04:20 AM |
Giving flat black wheels a dash of bronze? Expert backyard painters want to weigh in? | Keenercarguy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 06-02-2017 09:15 PM |
My Fr-s Dyno Results!! Surprising if you ask me | track_warrior | Engine, Exhaust, Transmission | 36 | 07-02-2012 10:15 PM |
Rwd-boxer's backyard exhaust fix | RWD-boxer | Engine, Exhaust, Transmission | 9 | 06-11-2012 06:15 PM |
