Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
05-19-2017, 07:38 PM | #1 |
Drives: '13 SWP GT86
What's going on here - coilover not compressing?
Okay, I might be very tired right now, since it's 1:30 AM.. but I've had my car on jackstands for a few weeks now, and I just went to drop it down to the ground, and the right side isn't coming down much at all..
Left side, as you can see, sits as it should, but the right side is very high. Did a quick visual inspection and couldn't see anything wrong that I might've missed. When I put the car in the garage, they were fine and of course the same height. Granted, they are D2 coilovers, but they have done less than 3000 miles and have given me no issues before. Tried bouncing the car from the trunk, raising it and setting it down again.. Ignore the diferent tires, both will be R888s when I'm done.
IG @squareddesign
http://www.squareddesign.se |
05-19-2017, 09:53 PM | #2 |
Custom User Title
Drives: Asphalt FR-S MT
Did you roll the car? I think you just need a good nap.
05-19-2017, 10:11 PM | #3 |
It's the rear end not settling, right? Was the e-brake locked before raising the car and still locked? If so, release the e-brake and roll the car back and forth a tiny bit, it should settle back down.
05-24-2017, 01:40 AM | #4 |
The Stig's German cousin
If releasing e-brake didn't do it, disconnect the rear sway bar and try again. Make sure you get the car fully on the ground, those wood pieces do not look the same height!
If that doesn't help, verify ride height and spring preload settings on both rear coilovers. I know you didn't change it but best to rule out the silly stuff first. Beyond that, I'm not sure. Maybe if the car spent a long time with the suspension in full droop, it pulled the shock piston out too far and now it doesn't want to compress? I'd independently (again, disconnect rear sway bar) jack up the left and right side suspension to watch it go through its full range of motion. |
The Following User Says Thank You to renfield90 For This Useful Post: | sqd (05-24-2017) |
05-24-2017, 05:41 AM | #5 | |
IG @squareddesign
Similar Threads | ||||
Coilover Review: FEAL SUSPENSION 441 coilover kit | mr. slim | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 11-28-2019 06:30 AM |
RCE T2 + Raceseng CasCam helper spring not fully compressing | AxisPower | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-19-2017 11:05 PM |
T1R Coilover | jau | Brakes, Suspension, Chassis | 9 | 10-18-2015 10:57 AM |
Compressing coilover struts by hand - any danger in "bottoming out"? | 1Cor10:23 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 12-24-2014 11:32 PM |
RCE T2 Coilover Help? | MeFryRice | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 11-25-2013 12:30 PM |
