Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-08-2019, 12:01 AM | #29 | |
Drives: BRZ Turbo
Even without boosting my oil temps are like this ^, what other things can cause it to run that hot? |
07-10-2019, 08:11 AM | #30 |
Drives: BR86
Where are you getting oil temps from ? I'm lost at this point . . . :/
07-10-2019, 08:19 AM | #31 |
Drives: 17 BRZ
Yeah im having a similar problem-ish my oil temps shoot up while highway driving over 3k rpms which is about 70-80mph, it usually hovers around 190-210f while local driving but anything at highway speeds for more than like 15 minutes its up closer to 270F
Sent from my SM-G973U1 using Tapatalk |
07-10-2019, 08:26 AM | #32 |
Drives: BR86
My godfather - how hard are you driving/revving it ? Thems high temps, I'd be very cautious when temps get to 250 & beyond. Those temps are not normal.
07-10-2019, 08:31 AM | #33 |
Drives: 17 BRZ
Its on cruise control and im NA
07-10-2019, 04:39 PM | #34 | |
Drives: Halo 86, '19
@thinkV
If your temps are simply at idle then there's not much you can really do to lower the temperature except maybe a thinner oil which will promote flow and therefore increased heat exchange, or maybe a heavier duty radiator, but I'm uncertain if that will actually affect idle oil temps. 109c oil and below you're probably fine, and the oil pressures only become an issue above 6000 RPM, at least on 0w20. Below that and the pressures are fairly solid even at higher temps. Once you're moving your temperatures fall to more safe temps, yeah? That would mean the oil cooler is doing its job, but I was under the impression initially that this was at speed. Quote:
07-10-2019, 04:42 PM | #35 | |
Anti stance.
07-10-2019, 11:31 PM | #36 |
Can you ask your tuner have your fans come on sooner via the tune? My tuner did this with my tune and it helped with traffic and low speed driving. This is with my supercharger running e85
2013 Series 10 FRS #553
07-10-2019, 11:45 PM | #37 |
Drives: 2013 frs red
Faulty temp sensor?
07-14-2019, 08:15 PM | #38 | ||
Drives: BRZ Turbo
And a prosport gauge with the sensor on a TRD sandwich plate below the oil cooler. Quote:
Tuner said this wasn't necessary and would keep the fans on way too much. |
Similar Threads | ||||
HVT non rising Camber Plates | dstrout | Brakes, Suspension, Chassis | 7 | 05-23-2019 10:09 PM |
HVT non rising Camber Plates | norcalpb | Brakes, Suspension, Chassis | 12 | 07-24-2018 08:08 PM |
HVT Non-Rising Camber Plates | Keenercarguy | Brakes, Suspension, Chassis | 7 | 05-08-2017 04:04 PM |
Oil temperature rising? | ChiTownFrs | Issues | Warranty | Recalls / TSB | 19 | 08-04-2015 07:59 AM |
RPMs rising while at a stand still | kpamir | Engine, Exhaust, Transmission | 13 | 10-29-2014 06:45 PM |
