DIY (Do-It-Yourself) Guides For all DIYs. |
01-07-2016, 06:55 PM | #29 | |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
The Following User Says Thank You to stevesnj For This Useful Post: | Toyarzee (01-07-2016) |
01-08-2016, 12:08 PM | #30 | |
Drives: '13 FR-S
[ame="https://www.youtube.com/watch?v=-JKndoat9qU"]Make your own Lowered Car Ramps for $5 - YouTube[/ame] |
01-11-2016, 08:56 AM | #31 |
Drives: '13 Subaru BRZ Limited
I bought this exact floor jack when I got my car 2 years ago. Still works like a dream.
Sent from my SM-G920V using Tapatalk |
01-18-2016, 06:06 PM | #32 |
Drives: Ultramarine FR-S
I got this jack about 6 months ago and the other day, all the oil exploded when I tried to use it. Not sure if it's because it was 15 degrees out but it failed on me when I really needed it more than ever (flat tire)
01-19-2016, 07:21 PM | #33 |
My life has been so much easier since this jack has entered it.
IG @jordonallison
01-31-2016, 02:53 PM | #34 |
The square plug that is welded to the bottom of the jack handle on mine failed. Was trying to jack up a big 2door freezer and the valve would not tighten. Pulled the handle out of the jack and discovered that the round washer with the square hole cut in it, the weld had broken off the bottom of the handle. Jacks only have a 90 day warranty...............unless you buy an extended warranty.................
01-31-2016, 05:48 PM | #35 |
Drives: 2013 Subaru BRZ Limited LR
I use: http://www.harborfreight.com/2-ton-a...ump-62247.html
I love it because if you center it directly in front of the BRZ and slide it in until right before it hits the bumper; it's directly below the front jack point. I use hockey pucks with my jacks/stands and it also holds a hocky puck perfectly. Costs a bit more, but worth every penny. There is also the fact that it is pretty good on "travel" in the pressure release. I can let the car down slowly instead of "not moving", "not moving", "not moving", "crash". |
01-01-2018, 11:20 AM | #36 |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
*resurrection*
Just got the long-reach steel 2-ton for my lowered FRS and it's perfect. I can reach the front jack point from the front with no ramps and it lifts the car really high. I did have to return the first one because the valve was way too touchy. (Difficult to bring car down slowly) Howver, HF exchanged it with no hassle qnd the second one works great. This thing is HEAVY though..not a candidate for track days IMO, but great for the garage. Oh, and the pic under the car is with the jack raised to the jack point. It goes down level with the jack frame with just the "cup" sitting above the frame. |
The Following 2 Users Say Thank You to Twinz For This Useful Post: | bcj (01-01-2018), new2subaru (01-01-2018) |
01-02-2018, 10:02 AM | #37 |
Drives: 15 BRZ LTD, 05 FXT
I've had one of these for around 3 years. It works really well for the money.
Do a couple little things to give it a decent head start and it should serve you really well: Use blue locktite on the caster nuts, top off the jack oil, (it ships low in my experience,) all moving pivots should get a little bit of lithium grease or axle grease on them, (keeps them quiet,) and the bolt that holds the handle in strips out really easily, (the bolt threads fail, not the handle/nut threads,) so replace this with a beefier fastener. It lifts my BRZ from the front or diff no issue. The car is lowered -1.5 inches on ST's all the way around, has an STi lip, and the MXP SP exhaust is 'busy' around the rear diff, so I have no clearance issues anywhere with any setup I've tried to lift.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
01-02-2018, 12:49 PM | #38 | |
01-02-2018, 05:42 PM | #40 |
Almost...
01-02-2018, 10:52 PM | #41 |
01-16-2018, 11:15 PM | #42 |
Drives: 2015 FR-S
the 1.5 ton and 3 ton jacks are loved buy the offroad community and mine is great
Similar Threads | ||||
WTB: Low profile floor jack and jack stands! | lupindub | Want-To-Buy Requests | 2 | 11-26-2015 11:03 PM |
Harbor Freight Jacks | White64Goat | Other Vehicles & General Automotive Discussions | 28 | 12-27-2014 07:16 PM |
Harbor Freight Low Profile Jack on sale $139 | DarrenDriven | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 28 | 10-06-2014 06:18 PM |
$10 Harbor Freight Catch Can | ML | Engine, Exhaust, Transmission | 58 | 09-24-2013 01:31 PM |
Aluminum 1.5 Ton Racing Jack on sale at Harbor Freight | Foobar | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 11-22-2012 01:42 PM |
