07-07-2021, 06:44 PM | #197 |
Ultra Senior Member
Drives: 2014 BRZ Premium, WRB
Is there any nuance to re-installing a flywheel to ensure it’s aligned with the rotational axis of the motor? When I losened the eight bolts, there didn’t appear to be any play in the positioning of the flywheel. So it would seem that one could just put it in place and screw in the bolts, no?
07-07-2021, 07:04 PM | #198 |
Ultra Senior Member
07-08-2021, 08:49 AM | #199 |
Drives: 2013 frs base
Did you reach out to SBC? If the dealer won't help try the manufacturer.
The Following User Says Thank You to blsfrs For This Useful Post: | vfrqqq (07-08-2021) |
07-08-2021, 09:31 AM | #200 | |
Ultra Senior Member
Incidentally, since I’m essentially trying to evaluate different likelihood statements about what the problem is, can you explain more about why you think the clutch disk and pressure plate are the problem? |
07-08-2021, 12:58 PM | #201 |
I'm not an expert but I have worked on cars for a long time. When a flywheel is resurfaced, an equal amount of material is removed from its entire face. Its "balance" won't change. That leaves the pressure plate and disc as the variables.
The Following User Says Thank You to blsfrs For This Useful Post: | vfrqqq (07-12-2021) |
07-08-2021, 04:04 PM | #202 | |
Ultra Senior Member
The Following User Says Thank You to vfrqqq For This Useful Post: | MJones_RB (08-24-2021) |
07-12-2021, 04:10 PM | #203 |
Ultra Senior Member
Just got the transmission back on for the second time after replacing the flywheel and the vibration is no more! So happy. I was fully prepared to have to either just deal with the problem or take it to a shop to have it done professionally.
The Following User Says Thank You to vfrqqq For This Useful Post: | blsfrs (07-13-2021) |
07-14-2021, 06:22 AM | #204 |
Drives: GT86 2020
Its very useful, You put best efforts!
The Following User Says Thank You to Feezz For This Useful Post: | vfrqqq (07-17-2021) |
07-14-2021, 12:14 PM | #205 |
I am curious to know what the machine shop did to your flywheel when they resurfaced it. Have you discussed the problem with them?
07-17-2021, 11:55 AM | #206 | |
Ultra Senior Member
So, in the end, my sense is that the resurfacing process is perhaps a more gradual and controlled process whereas the milling, while being essentially equally precise, is more of a more forceful removal of material. But that's just my impression. I'm not a materials engineer and the shop I went to does work on hot rod performance engines and such, so I would assume they probably know what their talking about, but I suppose someone on here with actual machining experience might chime in to the contrary. Last edited by vfrqqq; 07-17-2021 at 12:24 PM. |
The Following User Says Thank You to vfrqqq For This Useful Post: | blsfrs (07-18-2021) |
07-17-2021, 12:19 PM | #207 |
Ultra Senior Member
There are a couple things I would note for anyone who takes on doing their own work on their transmission and that I don't think are really talked about on this thread (or maybe I missed it or it could also be elsewhere on the forum). Anyway...
1) I didn't realize until after the second time putting on the transmission was how important it is to understand and match up the angles at which the axis of the engine flywheel is at relative to the input shaft of the transmission. The first time I installed the transmission, I had it jacked up waaay too high, which together with the second item explains why it took me and my helper more than two hours just to get input shaft in the ring gear of the clutch disk. I did not appreciate that the input shaft on the transmission really needs to be pointing up at least a few degrees from horizontal, which is much more than I expected. 2) I also didn't realize until toward the end of the first install the importance of having my helper rotate the crankshaft pulley at the same time while I was underneath and pushing the transmission in. I appreciated that the input shaft and the clutch disk ring gear are a tight fit, but had assumed that at some point it would just slip into place even if it was just slightly off. Understanding these two points the second time around literally resulted in it taking maybe 30 seconds to get the input shaft into the clutch disk, and without much force applied at all. I could not believe how much easier it was. So point being that there's a little more to think about than simply putting everything back together the way you took it apart. |
The Following 3 Users Say Thank You to vfrqqq For This Useful Post: |
07-20-2021, 09:11 AM | #208 | |
The Following User Says Thank You to ermax For This Useful Post: | PerCompLLC (07-20-2021) |
07-21-2021, 09:11 AM | #209 | |
07-22-2021, 06:21 PM | #210 |
Ultra Senior Member
Something that surprised me was just how far the crank pulley had to be rotated before the transmission just slide into place. If I had to guess I would say it was at least 30+ degrees of rotation. Which seems a bit odd since there are 26(?) teeth on the input shaft spline which would theoretically mean you only needed to rotate less than about 13 degrees before the splines lined up with the ring gear. Oh well.
Similar Threads | ||||
Clutch engagement issue. Possible clutch cylinders upgrade? | wu_dot_com | Engine, Exhaust, Transmission | 42 | 04-05-2016 12:11 PM |
Chase Bays Clutch Line, Full Replacement | Chase Bays | Transmission and Driveline | 1 | 02-11-2013 02:57 PM |
Clutch/flywheel replacement? | bucket | BRZ First-Gen (2012+) -- General Topics | 1 | 11-19-2012 12:25 PM |
Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 12:22 PM |
Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 12:06 PM |
