05-28-2018, 03:03 AM | #2339 |
Meaty
265/35/18 falkens Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
The Following User Says Thank You to 15limited For This Useful Post: | yberther (06-01-2018) |
05-28-2018, 06:26 PM | #2340 |
Drives: 2014 BRZ Limited
WedsSports SA-20r 18x9.5 +45 wrapped in Sumitomo HR ZIII 265/35
05-29-2018, 12:16 PM | #2341 |
Drives: 2018 BRZ w/Performance Package
Hey everyone! Quick fitment question, as I have not been able to find this exact setup so far...
I am considering running an 18x9.5 +38 with a 245/35R18 or 255/35R18 all-around. Suspension-wise, I am a 100% stock Performance Package car. Will I run into any fitment issues, and if so what will they be? Thanks in advance! |
The Following User Says Thank You to TurboLag23 For This Useful Post: | NAEightySix (05-29-2018) |
05-29-2018, 02:43 PM | #2342 |
Drives: 2014 BRZ
I ran 18x9.5 +38 with 245/35R18 (not sure if 255's would fit on the front?) on all four corners for a few years on 100% stock suspension. No problems. No rubbing what-so-ever. Those tires look narrow for a 9.5 wheel, although some people like the stretch look. And the front poke some.
05-29-2018, 03:45 PM | #2343 | |
Drives: 2015 Scion FRS 6MT (Asphalt)
Meaty Tire Thread
265’s fit for me all around with the same wheel specs (RPF1’s), I’m running -3 camber in front and I believe -2 in the rear. 255’s would be a better fit though Edit: nvm this is for stock suspension. I can’t read :l Sent from my iPhone using Tapatalk |
05-29-2018, 04:38 PM | #2344 | |
Drives: 2013 frs
18x9.5 won’t clear stock suspension however idk about you since you have the sport package Sent from my iPhone using Tapatalk |
05-30-2018, 04:32 PM | #2345 |
Drives: 2017 series yellow BRZ
18x9.5 +38 will clear stock with a 245 tire performance package or not. 255 will not for sure.
My BRZ Build Thread
http://www.ft86club.com/forums/showt...17#post3079417 |
The Following User Says Thank You to Greenbean For This Useful Post: | sid94 (05-30-2018) |
05-30-2018, 04:36 PM | #2346 | |
My BRZ Build Thread
The Following User Says Thank You to Greenbean For This Useful Post: | BAD ROD (05-31-2018) |
05-31-2018, 06:09 PM | #2347 | |
06-01-2018, 02:44 PM | #2348 |
Drives: 2014 BRZ
06-01-2018, 07:34 PM | #2349 |
He meant Performance package "PP", relating to fitment that package comes with brembos and Sachs dampers, which might have a smaller spring perch? Common rub point in the front is on the oem spring perch
The Following User Says Thank You to 15limited For This Useful Post: | sid94 (06-01-2018) |
06-01-2018, 10:27 PM | #2350 |
Drives: 2013 frs
06-02-2018, 12:14 PM | #2351 |
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Am I meaty?
235/45/17? |
The Following User Says Thank You to Elliotw For This Useful Post: | phm14 (04-21-2020) |
06-03-2018, 06:44 PM | #2352 |
Country Boy 4 Life
I LIKE TIRES! |
Similar Threads | ||||
Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
