Old 02-03-2016, 09:48 PM   #309
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
Whatever came of this?
Could not verify complaint. Also, they damaged the paint, soiled the interior, tried to void all kinds of warranties, lied about doing their diagnosis, and didn't change the oil.
So, avoid Toyota of Marin?
I'll find a new dealer in a few thousand miles once it gets incredibly bad.
My FR-S has a build thread!
(It's mostly full of Nissans)
NissanGuy is offline   Reply With Quote
Old 02-04-2016, 12:12 AM   #310
Lonewolf
Lonewolf's Avatar
Drives: Moped
Wow, what great service, lol! I hope you panned them on the survey afterwards.
That dealer sounds like a nightmare and should be reported to Toyota or at least Yelp.
Old 04-30-2016, 08:16 PM   #311
Reedarobinson
Drives: 2014 Scion FRS MONOGRAM
Coolant Loss, Coolant Smell
Hello, new to this site. My 2014 Monogram with 8500 miles has been slowly losing coolant since I bought it new. Coolant smell is obvious just getting out of the car after the vehicle has been driven and warms up I have requested that it be looked over during the last two Toyata service intervals. Allegedly no trace of a leak was found and they topped off the reservoir as I have done numerous times.
Rarely drive the car, but with summer almost here in League City Texas I took it into the local dealer and told them that I did not want the vehicle back until it was repaired. Three days later, no word on what he the issue is. I have seen numerous other postings regarding this same issue. However I have never seen a post with a final resolution to this problem. If anyone has the answer please let me know. This dealer has already NPF'ed four of my other obvious complainints.
Thanks
Reedarobinson is offline   Reply With Quote
Old 04-30-2016, 08:34 PM   #312
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Thanks
I think people found using hose clamps and not the "spring type" clamps used stock and aftermarket radiator hoses completely dropped the amount of coolant loss. If the dealer refuses to look into it go to a better dealer otherwise do it yourself.
Old 05-18-2016, 09:52 PM   #313
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Well checked my coolant today and its empty.
It started going down during this winter. In the winter month it was still in between the low and full, than in the spring it was low. Now its empty.
Before taking it to the dealer, I'm going to buy coolant first at Subaru and fill it up and monitor it as well as check t make sure all hoses are secure.
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 05-18-2016, 09:56 PM   #314
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Definitely buy a jug of the Subaru super coolant and just keep an eye on your reservoir when you do an oil change, top it off as needed.
I've topped mine off probably around 3 times since I bought it in May of 2013. It has been around 1/4 above the low line for over a year now. At nearly 80k miles and running strong.
The Following 2 Users Say Thank You to B-R-Z For This Useful Post:
FirstWinter (05-20-2016), Mr.Impreza (05-18-2016)
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 06:34 AM
Coolant Question boredom.is.me Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-15-2013 07:50 PM
Engine Coolant? L3P47 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 04-13-2013 11:33 PM
Alright to use 5-6 old coolant? Hanakuso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-11-2013 08:47 PM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 12:03 PM
