06-28-2012, 01:50 PM | #99 | ||
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
G |
The Following User Says Thank You to jedibow For This Useful Post: | bambbrose (06-28-2012) |
06-28-2012, 01:51 PM | #100 |
I have a local tuner here that has the linux interface, I may ask him if he needs a summer project? HaHa
Good thing we are friends... |
06-28-2012, 02:07 PM | #101 | |
Wiring Nerd
Drives: 1994 Supra
I think they only use one bit rate per line, otherwise things get messy. I believe if you are getting data that is accurate at 500kb/s then that is probably the correct speed. I have a new Kvaser Leaf CAN to USB on the way in the mail. When it gets here I'm going to log raw data into BUSMASTER and see what we are getting. It has the ability to monitor in silent mode (doesn't send the acknowledgement bit), so we can pull everything off the bus in raw format.
Looking for BRZ FR-S in Wake County NC for testing. PM me. |
06-28-2012, 02:24 PM | #102 | |
BTW, the readings do not change when I change the bitrate from 1000 to 500, they are the same, the logger runs better at 500 kb/s however.. G |
06-28-2012, 02:33 PM | #103 | |
Wiring Nerd
Drives: 1994 Supra
The 125kb rate is only used for non-essential functions like some radio and body functions if I recall correctly. If a 125kb signal is sent out on the 500kb line, it will muddle the entire line with noise. If a 1000kb signal is sent out on a 500kb line, it will be ok because it fits in between the 500kb signals due to higher bit resolution. It's essentially just too much data.
The Following User Says Thank You to bambbrose For This Useful Post: | jedibow (06-28-2012) |
06-28-2012, 02:38 PM | #104 |
Well then I'm back to dealing with a scaling issue within EvoScan, that makes sense however.
***Runs to the closet and hangs himself with a wet noodle*** |
06-28-2012, 03:03 PM | #105 | ||
Drives: BMW E92 M3
I would like this as well.
ID(xxxxxxxx): B1, B2, B3, B4, B5, B6, B7, B8 ID(00000018): FF, FF, 70, 0E, 00, 00, 00, FF ID(000000D0): FF, FF, FF, FF, 00, 00, FF, FF ID(000000D1): FF, 07, 7F, 00, 00, 00, 00, 00 ID(000000D2): 00, 00, FF, FF, 00, 00, 00, 00 ID(000000D3): 00, 06, E0, 0F, FC, 00, FF, 00 ID(000000D4): FF, 07, FF, 07, FF, 07, FF, 07 ID(00000140): 7F, 4F, FF, 4F, FF, 7F, FF, 21 ID(00000141): FF, 2F, FF, 2F, FF, 8F, E0, 18 ID(00000142): FF, AF, FF, 00, 00, 00, 00, 00 ID(00000144): DC, 00, FF, 41, 06, A4, 29, 00 ID(00000148): 7F, 1F, FF, 0F, 00, 00, FF, 05 ID(00000149): 00, C7, 00, 00, 00, 00, 48, 0F ID(0000014A): FF, 03, FF, 7F, 10, A7, 00, 80 ID(00000152): F0, F4, 00, 00, 00, 02, 18, 03 ID(00000156): 00, 80, 00, 00, 00, 00, 00, 00 ID(00000282): FF, F7, FA, 8F, 8F, 00, 20, 00 ID(00000360): FF, 1F, FF, FF, FF, 90, B2, 00 ID(00000361): 00, 29, 00, DF, 0F, F0, FF, 57 ID(00000368): 12, 00, 00, 00, 00, 00, 00, 00 ID(00000370): FF, 03, 00, 00, 00, 0F, 00, 00 ID(00000372): 00, F0, 00, 00, 00, 00, 00, 00 ID(00000374): 00, 00, 00, 00, 00, 00, 00, 00 ID(00000375): 00, 00, 00, 00, 00, 00, 00, 10 ID(00000440): 42, 02, 00, 00, 00, 00, 00, 00 ID(00000442): 40, 02, 00, 00, 00, 00, 00, 00 ID(000004C1): 01, 00, 00, 00, 00, 00, 00, 00 ID(000004C2): 02, 00, 00, 00, 00, 00, 00, 00 ID(000004C3): 03, 00, 00, 00, 00, 00, 00, 00 ID(000004C6): 07, 00, 00, 00, 00, 00, 00, 00 ID(000004C8): 09, 00, 00, 00, 00, 00, 00, 00 ID(000004DD): 1E, 00, 00, 00, 00, 00, 00, 00 ID(0000063B): 00, 00, 00, 81, 00, 00, 3F, FF ID(000006E1): A1, 80, 00, 00, 00, 70, 00, 00 ID(000006E2): A2, 80, 00, 6C, 6C, 6C, FE, FE |
The Following User Says Thank You to E92M3Guy For This Useful Post: | bambbrose (06-28-2012) |
06-28-2012, 03:54 PM | #106 | |
Wiring Nerd
Drives: 1994 Supra
Looks like ID 140 is in an error state (7F). Have you connected any IDs to specific parameters yet? What CAN analyzer software and cable are you using? Moto-P stated the the IDs would be open source and released by Toyota, but I haven't heard anything else about this since then.
06-28-2012, 04:01 PM | #107 | ||||
Drives: BMW E92 M3
Sure, PM me your email address. I'll be away for the weekend, but should have email access.
06-28-2012, 04:06 PM | #108 |
Drives: BMW E92 M3
More info:
0xD0 = Steering angle and motion sensors 0xD1 = Brakes & Speedometer 0xD4 = Individual wheel speed sensors 0x140 = Throttle position, RPM 0x148 = Gear selection I guess I didn't add the dash switches to the map on my desktop; they must be on my laptop instead. |
The Following User Says Thank You to E92M3Guy For This Useful Post: | jedibow (06-28-2012) |
06-30-2012, 10:25 PM | #109 |
Took my car to the dyno today and what I found most interesting was that the AFR was within 0.1 point at all rpm points of the command AFR. Could it be possible that the ECU is running full time closed loop? Another possibility is that the MAF Scaling is spot on, however I doubt this...
06-30-2012, 10:35 PM | #110 | |
Drives: '06 AM V8V Coupe
Also when the AFR gets lower, each increment in AFR gets "bigger" in terms of fuel mass/volume if you know what I mean, maybe that sort of resolution isn't considered impressive or something. I have no idea what it typically is, so I might be talking out of my ass. |
07-01-2012, 07:10 AM | #111 | |
-John |
07-01-2012, 06:23 PM | #112 | |
What this means is once tuning is available you will not have to arbitrarely assign values to the independant cells in the fuel map, what you enter is what you will see in the external wideband gauge. It will make life easier. I would also like to comment that the oscillations between AFR on the dyno were +/- 0.2 points in AFR, after the intake, it did not oscillate at all. BTW max hp 171, max torque 146. these values are SAE corrected ofcourse for my being at 5500 feet above see level, however uncorrect it was 136, and 117 almost exactly what evoscan predicted, awesome. |
Similar Threads | ||||
Great dealership in NE Ohio.. (still has multiple pre-order slots open) | eikond | BRZ First-Gen (2012+) -- General Topics | 15 | 03-02-2012 01:03 PM |
Open Air FR-S Concept | Rampant | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 22 | 02-01-2012 11:01 PM |
Open Deck Block | nrclptcnsmniak | Engine, Exhaust, Transmission | 36 | 01-27-2012 01:00 PM |
Keep your eyes/cameras open in SoCal? | Buggy51 | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 10-10-2011 10:21 PM |
