Old 07-04-2015, 03:38 PM   #211
mush
mush's Avatar
Originally Posted by JoeBoxer View Post
I have the Swift BRZ springs, thinking about swapping over to these or the ST coilovers. ST are much cheaper obviously but they use a twin tube instead of monotube like the Bilstein. I wish somebody around had both but can anybody compare ride quality between the two?
i have a buddy with ST, haven't gotten the chance to ride or drive in his car yet, he lives close by so maybe i could set something up soon
mush is offline
The Following User Says Thank You to mush For This Useful Post:
JoeBoxer (07-08-2015)
Old 07-08-2015, 04:31 AM   #212
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Still happy with the B14's?
JoeBoxer is offline
Old 07-09-2015, 02:19 AM   #213
mush
mush's Avatar
so far, yes
mush is offline
JoeBoxer (07-09-2015)
Old 07-18-2015, 02:48 AM   #214
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Has anyone found matching blue rear dust covers for the B14s/16's?
I've got to buy a pair of dust covers for the rear, but if I can find Bilstein blue ones instead of the factory black ones that would be great.
Kostamojen is offline
Old 07-19-2015, 10:58 PM   #215
mush
mush's Avatar
show car? or are u picky? i only see the dust cover if i lift the car up
mush is offline
Old 07-20-2015, 12:09 AM   #216
Kostamojen
Its just one of those things that will bug me knowing it exists...
Old 07-24-2015, 04:04 PM   #217
Kostamojen
Question:
On the rears using stock tophats, does the metal "spacer" go below or above the tophat?
Old 07-24-2015, 05:04 PM   #218
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Bump!
FT-86 SpeedFactory is offline
Old 07-27-2015, 03:45 PM   #219
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
^Any plans to discount the coils for 8/6?
If you can get within shouting distance of other vendors' prices I'm thinking of treating the car to a slight drop...
(I still have no clue what that smiley means)
My FR-S has a build thread!
(It's mostly full of Nissans)
NissanGuy is offline
Old 07-30-2015, 02:54 PM   #220
FT-86 SpeedFactory
Those vendors might be shocked to see the cost from Bilstein has increased. They wouldn't know that though as they don't even have real pictures so they probably have never even held a set in their hands. That's what happens when drop shippers list parts for sale. We actually stock them in house, and have real photos plus can support you after the sale.
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
Racecomp Engineering (07-30-2015)
Old 07-30-2015, 02:56 PM   #221
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I would love a set of these but the canadian $
go_a_way1 is offline
Old 07-30-2015, 07:08 PM   #222
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
That might explain why I see differing part numbers around... Any idea what they've updated on the parts?
Old 08-08-2015, 10:06 PM   #223
Kostamojen
OK, I've tested out my B14's a bit now and wanted to post a quick review...
Bilstein B14's with Group-N Top Hats
What are Group-N top hats some of you may say? Well they are OEM Subaru tophats designed for rally back in the day, and considering the BRZ uses the same tophats as pretty much all Imprezas, its a part we can actually use. It consists of much stiffer rubber compounds, however its only available for the front, I had to use standard (actually part numbers from a ~2010-2015 STI) rear top hats.
Combined with the B14's, this makes for a very Street Friendly setup. You don't get the added camber/caster with Camber plates up front, but the stiffer tophats do increase the overall rigidity of the suspension for basically the same price as buying stock tophats new.
Initial Impressions
When I first installed the suspension, I noticed the "bounciness" that other people refer too. Having had coilovers before, I know that bouncy is different from harsh. These B14's are NOT harsh at all! In fact I'd say they are less "harsh" than stock in terms of how they respond to nasty issues with roads.
After a couple weeks, I've grown use to it and they do seem to have broken in a little bit more. During freeway driving or regular driving, I'd say they are no worst than the Racecomp springs I had on my stock shocks in terms of ride/comfort.
During freeway driving, I do find the front end to be a little more "loose". Reminds me of the FRS I test drove now. I think mostly due to the soft front spring rates. The car doesn't require any constant inputs or anything, its not darty on the freeway now which is good IMO.
Autocross Impressions
I did my first Autox with the coilovers and new wheels/tires last Saturday. The car was actually AMAZING IMO. A lot of it had to do with the new tires, but I was a bit frustrated before with my springs because I kept on having to go with different swaybars to get the car to handle correctly during autocross...
This is no longer the case with the B14's! I'm still running the Strano swaybar up front, but I went back to the 14mm bar in the rear. My overall setup also includes a front strut bar, whiteline front endlinks and kartboy rear endlinks with poly bushings for the swaybars and the Subframe support bushings.
The car REALLY likes to rotate with these coilovers, which is what I was looking for. The softer progressive springs up front allowed me to "play" with the weight distribution much more while cornering, allowing small inputs with the wheel or pedals to rotate the car, rather than having to throw it hard into the corner and upset it to get it to rotate. I was VERY pleased with this!
IMO the cars handling character now is more like an FRS than a BRZ, with the greater rear bias in spring rates. However, it doesn't want to step out on you like the FRS does/did stock, it wants you to play with it and make adjustments and decide how much you want to angle the car. Its hard to describe.
I do know some people might not be as happy with this as I am, because they want a car to be very linear and have more of a sudden release of traction with a very stiff spring. But I find this setup to be more "rally-car-ish" where you deal with a suspension thats able to eat up the bumps yet at the same time be able to put the car where you want to.
Impressions for back-road driving/twisities
I took the car out today on my favorite road route. A lot like some of the Youtube car review guys, I drive the same road constantly for fun which lets me compare cars or changes I've made with my car.
When I had the original "basic" setup I started with this car, with the BRZ front springs, FRS rear springs, Strano front swaybar and camber bolts, the car was quite different. The front end was stiffer and the car liked to rotate at a completely different point in the corner than the car does now. Before it would rotate later and only at a specific point, but now with the B14's I can pick and choose when and where I want it to rotate. Again, hard to describe without showing it in person.
The weight shift of this suspension works wonders with back road twisties. I can balance the car while still eating up imperfections in the road. A good example was a large bump (wasn't there before) in the middle of a corner. When the car hit it, it didn't get airborne or get upset, the weight just shifted. I was able to counter it with a slight lift of the gas and turn of the wheel and the car just stayed in the lane and kept going. Before, when I relied on the swaybars more, the car would have stepped out and possibly been unrecoverable.
Conclusion
So yes, this is certainly a VERY good setup for daily driving/street driving, even for non-ultra-competitive Autocross (results are here if you are curious: http://www.sfrscca.org/solo2/Sacrame...%209%20Raw.htm ). If you want a quality shock with the ability to lower the car, or even run custom springs a latter date and keep the quality shocks, this is certainly a great choice.
The Following 6 Users Say Thank You to Kostamojen For This Useful Post:
C4RBON (09-25-2015), dirtbike250x (08-10-2015), kevaughan (04-16-2024), riri86 (11-16-2015), spirit (03-30-2017), yberther (04-26-2016)
Old 08-08-2015, 10:36 PM   #224
xingxingtjf
Drives: Subaru BRZ
Thumbs up
xingxingtjf is offline
Bilstein Damptronic pics. DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 202 10-08-2014 08:13 PM
Anyone ETA on Bilstein coilovers? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 01-31-2014 11:26 AM
Bilstein Damptronic on an FRS DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-10-2013 12:15 AM
All Bilstein and Muteki 10% off during month of July! Infamous Performance Brakes, Suspension, Chassis 24 07-31-2013 01:52 PM
Bilstein Shocks wahsaihin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-23-2013 03:12 PM
