Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
11-04-2011, 06:12 PM | #15 |
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
i'd caution stroking the FA20 until we know a lot more about the engine. i know on my 3SGTE, the rod:stroke ratio wasn't ideal to begin with, and when i stroked it, i made it worse. this coupled with my higher compression ratio has made tuning difficult and annoying on pump gas, to say the least. just something to consider...
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs 1990 240SX Coupe - sold 2008 Civic Si Sedan |
The Following User Says Thank You to NESW20 For This Useful Post: | Team STILLEN (10-22-2013) |
11-04-2011, 08:22 PM | #16 |
Drives: NA8C, GDB, and R50
I guess we will end up with totally different engine, where nothing is sharable with the fb25 hope I'm wrong
See My Album: http://www.ft86club.com/forums/album.php?u=949
11-04-2011, 09:21 PM | #17 | ||
Drives: 1993 Impreza w/ WRX Swap + FWD!
Its not as early as you think. We probably will have everything released information wise within a couple months, and the service manuals (at least in Subaru's case) are out a month or two before the car even hits lots, so we should have very detailed information available before the car is even out. |
11-04-2011, 09:46 PM | #18 |
Drives: Slowly
11-05-2011, 12:48 PM | #19 |
Rocket Surgeon
Drives: PSM GGA OMG
Unfortunately, that has never been the case with the EJ's. They've had everything from SOHC heads to DOHC heads with variable cam phasing, and that never changed the engine family.
11-06-2011, 06:04 PM | #20 |
Kuruma Otaku
Also, if the power is flow-limited (but bigger bore could result in a bit more flow from de-shrouding the valves), the result would be nothing more than a 200 hp FB25 with correspondingly lower rev limit. May have less of a usable power curve as well.
But the extra low-end may be what some people are looking for (SUB this may be your lucky mod...).
Because titanium. |
11-07-2011, 12:46 AM | #21 |
Drives: '06 AM V8V Coupe
In that case, wouldn't it be easier to just take an FB25, tune it, raise compression, and call it a day?
11-07-2011, 01:33 AM | #22 | |
No way, the FB25 doesn't have the heads or compression. And the BRZ/FRS will surely have a different ecu and wiring harness for the DI that won't be compatible with the FB25 heads. |
The Following User Says Thank You to Kostamojen For This Useful Post: | industrial (06-05-2012) |
11-07-2011, 01:46 AM | #23 |
Site Moderator
Drives: ichi 86 Project
Screw FB25! Give me 2.2L ver w turbo so I can call it 22BRZ
Put the joke on the side interesting topic |
11-07-2011, 03:27 PM | #24 | |
Kuruma Otaku
Airflow=hp. Pulling more air from bigger cylinders doesn't change the limit of what can get through the valves.
Because titanium. |
11-07-2011, 04:06 PM | #25 | |
But thats always been the last issue with EJ motors in the past, the head flow was usually the last in the line of modifications you needed to do in order to get the most power out of the motor. The "frankenstein" motors with EJ18 heads on EJ22 blocks, or EJ22 heads on EJ25 blocks, or even the turbo EJ20 heads on the STI EJ25 blocks, all of them never needed head work to get those significant gains in power, and none of them had lower peak power numbers either. |
11-07-2011, 05:25 PM | #26 | |
Kuruma Otaku
If we work with the assumption that there are cam upgrades and intake upgrades and exhaust upgrades as well, it has the potential to make more power, despite fighting heavier internals. But all of those mods would also be making similar results on the base FA20.
Because titanium. |
11-07-2011, 06:11 PM | #27 | |
And also don't forget the FA has full variable timing PLUS the Direct Injection. I'd be interested to see what you can do with the cams for these heads seeing as I don't know of anyone making or modifying them yet for FB motors, but I doubt it would be "required" to run the FB25 shortblock (if this even works at all). If you want more information on what people have done before, there is a good thread about it here: forums.nasioc.com/forums/showthread.php?t=631527 |
11-07-2011, 08:14 PM | #28 | |
Kuruma Otaku
Potential gains in flow can be had by de-shrouding valves (this would be achieved by the cylinder wall of the bigger bore being further from the valves). The CR increase would be part of it, but also the same thing that is probably causing the CR bumb in the EJs would also create a more favourable combustion chamber shape (more squish area). But in this much more optimized motor (de-shrouding can sometimes lose flow on some highly developed ports) if these are feasible at all the gains will likely be much smaller. And they are likely able to be offset by things like the heavier rotating assembly. Also the valve timing is optimized for the rpm range of the FA20's intake and exhaust pulse tuning. These would be different for the longer stroke, slower revving 'FA25', and could screw up the power curve (spikes and flat spots). Last is something I'm not certain on, and that is I think the DI/D4-S engines have different shaped pistons, due to the nature how the direct fuel injection spray works. So another wrench in the machine there. An FB25-swap with cams (if they come out) and bolt-ons may give what some of the members here want (200ish hp at lower revs, with more low-end torque).
Because titanium. |
Similar Threads | ||||
Would you guys prefer FB20 or FB25 for NA FT? | tranzformer | Engine, Exhaust, Transmission | 89 | 07-20-2011 04:00 PM |
FT-86 to be "introduced" for early 2012! Press conference clip from Geneva Motorshow | ft86cbx | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 03-05-2010 02:07 PM |
Design Proposal for a New VW Corrado from the Imaginary World of "What If?" | vh_supra26 | Other Vehicles & General Automotive Discussions | 2 | 02-13-2010 06:26 PM |
