Old 08-16-2012, 08:41 PM   #15
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Originally Posted by chulooz View Post
Half a liter doesnt seem too healthy.
I would guess that you followed the normal 'gentle' break-in procedures, yes?
I didnt and my car does not burn oil or run badly. I did my first oil change at 500 miles and tracked the crap out of the car right after that.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 08-16-2012, 08:46 PM   #16
wheelhaus
wheelhaus's Avatar
There's two distinct theories for break in.
The "follow the manual and baby it for 1000 miles" or
"Drive it like normal, and early on, do some WOT pulls, but overall drive it easy".
The only cars I've seen consume noticeable amounts of oil are babied and never driven hard. With every *new* car I've ever had (Including two STI's and an Evo) I've driven them normally from mile 1 (with some WOT pulls and never stay at one rpm for more than a few minutes). I have never had oil consumption issues and they all ran beautifully with zero engine/drivetrain problems.
edit: There's a boatload of theories on why the manual says to baby the car; ranging from overall mechanical systems break in, to ensuring you "learn" the car and avoid driving an unfamiliar car too aggressively.
wheelhaus is offline   Reply With Quote
Old 08-16-2012, 10:51 PM   #17
oops86
oops86's Avatar
Drives: Scion FR-S
Here's two dumb questions. If he's burning oil, how big of a a deal is it, and is it fixable?
oops86 is offline   Reply With Quote
Old 08-16-2012, 11:32 PM   #18
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Thats what I like to see! :happy0180:
chulooz is offline   Reply With Quote
Old 08-16-2012, 11:53 PM   #19
MY13FRS
***** Super Senior Member
MY13FRS's Avatar
Drives: 13 FRS
I have over 1700 miles and the oil level is the same. In fact, the oil level is about 4mm over the full mark, they must have over filled from the factory.
MY13FRS is offline   Reply With Quote
Old 08-18-2012, 11:26 PM   #20
w arghh x
[I 86 I]
w arghh x's Avatar
Drives: Toyota 86 GT
I have clocked up 700km now (434miles) and just checked the oil after warming it up (15min drive) and the oil is at exactly full level.
I haven't rev'd my car over 5k rpm and pretty much babied it from the start as I wanted to run it in as per manual. The difference with this one is that I have been 'loading' up the car almost everywhere I have driven... Ie; 1st to 4th under 3000rpm then full throttle for a while, back off the throttle and let it slow down then back on full throttle.
My old man used to be a mechanic and engine builder and told me this in his opinion was the best way to bed the rings in.
No oil consumption, great low down pull and smooth as silk. Guess it hasn't been a bad thing doing it this way.
w arghh x is offline   Reply With Quote
Old 08-18-2012, 11:36 PM   #21
serialk11r
Drives: '06 AM V8V Coupe
I have no idea how break in is supposed to work, but driving like that cycles between maximum cylinder pressure and minimum cylinder pressure, so it seems like it would bed the rings in pretty hard.
Old 08-18-2012, 11:51 PM   #22
w arghh x
[I 86 I]
w arghh x's Avatar
Yep, this is what he advised me was the key to bedding them in. The other reason for keeping rpm low while bedding rings in was that high rpm with stiff new rings can (but not always) cause 'lipping' at the top of the bore, which can end up damaging the rings. After around the 700km mark, increase revs by 500rpm for 100km, then progress from there until run in period is finished and your at max rpm.
Who knows tho right, there are those where this seems like nonsense, there are those whom are Internet engine building specialists who know all, and there are those who know not a lot. For me, this hasnt had any detrimental effects but I guess only time will tell.
Old 09-30-2019, 01:31 PM   #23
ROGER-86
Drives: 2017 86
My car uses exactly 1 qt every 12,400 miles.
I have been carefully tracking my oil consumption on my 2017 86 Automatic by observing how many quarts of Mobil-1 I have gone through topping up over the last 2.5 years and 27K mi. My car uses exactly 1 qt every 12,400 miles.
As an aside: coolant consumption is 3.7oz every 7,500mi service interval.
I was super careful during the break-in period to watch RPM's and vary constantly, and a few strong pulls (torque'y, but not high RPM) to "seat the rings" if that really does happen. The car gets serviced per book at the dealer as it's new.
I drive it only for fun on a 90 mile route mostly on hiway-1 (Calif coast) to my fav hill climb from San Gregorio to Woodside CA. I do the 10 miles in the hills at 4,500-7K RPM quite hard, very fun. The oil temp gets to about 234 deg at it's peak when I reach the peak of the mountain. The water hits 212 at most (ambient air temperature of about 85).
Scenic driving flat along the coast the oil is 196 deg and water is 190.
I also blend my stupid 91 Calif gas in Woodside with 100 oct race gas (the 76 sells it there!) to get 93 oct and watch the ignition timing to confirm it advances properly to get the most power. I use BlueDriver to monitor.
Another aside... Starting in 2017 forward, Subaru stupidly programmed the car to let the battery discharge during acceleration and stops, doing most of the charging while decelerating only. I discovered this when I parked to listen to the radio for an hour and the car would barely crank. They said it's for "economy" B.S.! This will ruin batteries faster. You can force the car to "normal charge" at 14.2V by turning on the running lights (I drive with them all the time now). Also, if you turn the fan on it will hold at 13.3V. But drive normally and watch the voltage drop from an initial 14.4 at start to around 12.1 in just a few minutes. More on this later as I'm working up a big expose.
I'm an Engineer, I like to measure things.
ROGER-86 is offline   Reply With Quote
Old 10-01-2019, 06:55 AM   #24
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
did you really need to bump every oil consumption thread to tell us the exact same thing?
The Following User Says Thank You to why? For This Useful Post:
soundman98 (10-01-2019)
Old 10-01-2019, 10:02 AM   #25
He is an "engineer" so probably.
BigTuna (10-01-2019), soundman98 (10-01-2019), TofuJoe (10-05-2019), why? (10-02-2019)
Old 10-04-2019, 04:56 PM   #26
mrhayes1
Drives: 2013 Scion FRS white
I have over a 100k miles on my 2013 and it doesn't burn ANY oil, or at least a noticeable amount. Burning oil is not normal on almost any vehicle. No manufacturer develops a car knowing that it will burn oil and they are okay with that, aside from perhaps a few rare exceptions (rx8, etc.).
Point is, I would keep an eye on it and bring it in soon before warranty is up if it continues. If I had a new vehicle burning that much oil I would make them replace the motor....no question. If it burns that much oil now by the time you hit 150k you may be adding in more oil than gas haha
Also, when breaking in a motor you should follow the break in guidelines but make sure you vary your speed a lot. This is where everyone messes up. Freeway driving is bad for breakins. Side streets and stop lights are good. On and off full throttle is good. Ultimately you just want to avoid red-lining a car like crazy for the first few hundred miles.
mrhayes1 is offline   Reply With Quote
Anyone smell burning outside the car? DarrenDriven Scion FR-S / Toyota 86 GT86 General Forum 115 01-13-2015 01:31 AM
