Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
02-05-2016, 02:20 PM | #29 |
Drives: 2014 Ultramarine FR-S
02-05-2016, 02:41 PM | #30 | ||
Rebound affects the full range and you'll "feel" it more. - Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | ハチロク (02-05-2016) |
02-05-2016, 03:15 PM | #31 |
Drives: '22 BRZ
02-05-2016, 03:16 PM | #32 |
02-07-2016, 07:28 PM | #33 | |
Drives: Toyota GT86
Might be that 3-4 is a bit high for compression?
Here is a good guide to setting compression: Quote:
02-19-2017, 08:57 PM | #34 | |
Drives: 2014 WRB BRZ Limited
Why wouldn't you go max soft rebound? Is there any drawback to doing this? I've got the older, stiffer springs and the height is maxed out (about 1.25" lower than stock). Thanks!
02-19-2017, 10:17 PM | #35 | |
The car will be a little slower to react on turn in and in transitions. It would be pretty noticeable on an autox course especially. Our recommended settings are always meant as a starting point and for those that don't want to touch settings ever. Everyone is going to have slightly different cars and tastes so yes experiment and keep notes! - Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | xxBrun0xx (02-20-2017) |
Similar Threads | ||||
Ideal Suspension Setup for DD and Mild Track Use? | Lust | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 31 | 11-22-2022 09:37 AM |
Developing an ideal intake for a turbo setup | IBill4You | Forced Induction | 34 | 07-14-2015 12:29 AM |
Coilover Settings Database / Thread | glamcem | Tracking / Autocross / HPDE / Drifting | 10 | 08-11-2014 09:01 PM |
Ideal Exhaust setup | cjcoupe | AUSTRALIA | 4 | 02-07-2014 07:40 AM |
Stance SS coilover settings | Dispect | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 08-05-2013 04:43 AM |
