02-26-2018, 08:12 PM | #3095 |
Drives: 2013 Firestorm red FRS manual
For those of you running the Mann engineering AST 4150, which camber plates are you running? Im have a little difficulty finding which ones will work with them. I just ordered a set.
03-04-2018, 08:48 PM | #3096 |
Drives: '14 BRZ
In a bit of a pickle. I disassembled my KW V3s without marking which springs belong to which end, and threw all the pieces into a box. I've got 2x 6" and 2x 7" (all 400lb). Does it make more sense to have the shorter spring in front or rear?
03-05-2018, 11:02 AM | #3097 | |
APEXHNTR
Drives: 10 Series FR-S #1867
I did 400lb RCE springs on my v3 and all four were the same part number...
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
03-05-2018, 11:18 AM | #3098 |
Drives: 4 wheels
I would run the longer ones in front since you are more prone to binding in the front than the rear.
03-05-2018, 12:13 PM | #3099 | |
Drives: '14 BRZ
Now I'm tempted to get another set of 7" and just run that all the way around... |
03-05-2018, 12:54 PM | #3100 | |
Drives: 2013 FRS
I happen to have the front set off the car right now. I could measure and check part numbers when i get home this evening if it helps. pretty sure my front and rear springs are the same. |
03-05-2018, 01:23 PM | #3101 | |
Drives: 2017 BRZ
I got a different set of springs to try this year and ordered what I thought was right based on the size I was told to get, and they're longer than the ones that came on my coilovers... Of course, those weren't original so I have no idea what stock spring length actually was. I haven't put the car on the ground, but I'd guess it will sit about as low as it did on the old springs and there's still some room to go lower... I actually lowered the perches 30mm, and the official height difference should only be 26mm so I probably have to go up. I expect to be doing a bunch of adjusting anyway.
03-05-2018, 07:47 PM | #3102 |
Drives: 2022 BRZ
Getting ready for the season.
Simmons
2022 BRZ 71 STR
Sponsors Xero-Limit//Karcepts |
The Following 2 Users Say Thank You to Simmons For This Useful Post: | Mr.Scion (03-12-2018), Silver Ignition (03-06-2018) |
03-05-2018, 08:57 PM | #3103 | |
Drives: 2013 FRS
My springs are 7 inches. only markings are RCE 70-170 15J15. All 4 marked the same. |
03-06-2018, 02:59 AM | #3104 |
The Stig's German cousin
03-06-2018, 03:06 AM | #3105 | |
Having said that, the KW-supplied springs sagged quite a bit, it's something to keep an eye on especially since it will change your effective spring preload, and therefore rake/ride height. In contrast to that, my Hyperco springs are, after 30k+ miles, the same height exactly as the new pair of springs that arrived a few weeks ago. |
The Following 2 Users Say Thank You to renfield90 For This Useful Post: | conedodging (03-06-2018), strat61caster (03-06-2018) |
03-06-2018, 03:14 AM | #3106 | ||
As to which is faster, there was a bump on the practice course at nats right on one of the apexes. If I nailed the gas hard enough I'd trigger the e-diff pretty hard, such that you could feel the car throw an anchor out for a full second before it continued accelerating. Obviously when it intervened, I didn't set fast times. But then I compared several laps with the pedal dance vs just delaying my throttle input a bit there. With the pedal dance I could get within 1 tenth of my fast time with just the 5 second button press, but my times were much more inconsistent and it just seemed like more work to get the car through the course. EBD probably tidies up your driving a bit and makes it easier to place the car where you want. YMMV. |
The Following 3 Users Say Thank You to renfield90 For This Useful Post: |
03-06-2018, 03:29 AM | #3107 | |
I ran the 255s last season. I developed a tendency to underperform on courses with more than a couple big digs, and in the interest of saving my fragile (yet still oversized) ego I largely blame the tires. Fresh 245s mounted this weekend, time to put up or shut up... Anyway, I think there's one course type where the 255 does well: a high speed momentum maintenance course where no one is really going to 3rd anywhere so that extra 1-2mph you get is building a small advantage in the fast spots. But this is roughly 3 hundredths of a second advantage over 75 feet; you need a lot of time near/at the rev limiter to make this work. In virtually any other course I think the 245 might be faster. If not, I'll need to find another excuse to save my ego. |
The Following User Says Thank You to renfield90 For This Useful Post: | smg1138 (03-06-2018) |
03-06-2018, 12:37 PM | #3108 |
Drives: 2022 BRZ
LOL....everything is For Sale
2022 BRZ 71 STR
Similar Threads | ||||
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
