Old 02-11-2019, 03:14 PM   #15
Originally Posted by Seanzky View Post
I don't disagree with you. Dissuading the OP from taking on something like an engine swap could be costly and definitely not easy. All I was asking was the costs between a built FA20 with FI versus a swap. The reason I asked was that I thought, from reading other threads in this sub-forum, that many opted to swap because the cost was pretty similar.
From what I remember, building up a stock FA20 and adding FI would cost around $15k. On the other hand, selling everything and getting an LS1, Tremec (Magnum XL, some opted for IIRC?), and an IS300 rear differential was also around the same price. Of course, you'd have to sell your stock engine, transmission and differential for around $8-10k first, but the idea of the out-of-pocket cost being the same but instead you get to "trade up" to a more reliable engine, with more power NA, was the reason most people went the engine swap route. I could be wrong if that's not the case. It's just what I remember from reading threads here a while ago.
Not a hope in hell you will get $8K - $10K for the stock drive train anymore.
Yes you could manage to do it cheaper with more available engines but the OP was specific to the 2jz. You could also do the FA20 build cheaper if you just buy the parts and build it yourself instead of buying a pre built engine. Overall the built FI is going to cost far less than a swap. There are maybe 10 successfully completed swaps documented on this forum compared to the thousands of FI cars. The biggest reason for that is cost.
Seanzky (02-11-2019)
Old 02-11-2019, 03:39 PM   #16
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
I sold my engine, spotless/mint- never seen a winter with only 20k miles for $3k and sold the trans for $350. The OP's engine is toast so this is a moot point.
spitsnaugle is offline   Reply With Quote
The Following User Says Thank You to spitsnaugle For This Useful Post:
Tcoat (02-11-2019)
Old 02-11-2019, 04:19 PM   #17
I would have given you $3,001 just so I don't have to clean mine this summer! So much sand. So, so, so much sand.
Old 02-11-2019, 04:22 PM   #18
Seanzky
Drives: Slow
That was the offer I've gotten for mine. I have less than 2,100 miles on my 2018 model year. I, too, am looking into swapping but for an LS (maybe LS3). I'm not expecting much from mine either.
Seanzky is offline   Reply With Quote
Old 02-11-2019, 06:38 PM   #19
vijay.dy06
Drives: Red BRZ
I did my swap and have all functions working except for cruise for roughly 11k, and still haven't been able to sell my engine and trans for 2k obo with 83k miles. Its possible to do it on the cheaper side; cheaper side being 7-8k.
Sent from my SM-G950U using Tapatalk
vijay.dy06 is offline   Reply With Quote
Old 02-14-2019, 12:15 PM   #20
frsty_86
frsty_86's Avatar
Drives: 13 FR-S, 90 Honda ED6, 07 TBSS
Elaborate on your wizardry
frsty_86 is offline   Reply With Quote
The Following User Says Thank You to frsty_86 For This Useful Post:
GrabTheWheel (02-14-2019)
Old 02-14-2019, 05:50 PM   #21
vijay.dy06
Drives: Red BRZ
I was fortunate enough to find deals on some parts.
The Following User Says Thank You to vijay.dy06 For This Useful Post:
frsty_86 (02-15-2019)
Old 02-17-2019, 12:14 AM   #22
gt7877
Drives: turbo frs
Hi guys 👋
Thanks allot for your reply
I build my engine with
New crankshaft
New cp pistons
New 🦅 rods
New bearings
James at hri well tune the car
The goal is 400whp
This well reduce cost of engin swap ..
Thanks 😘 again
gt7877 is offline   Reply With Quote
Old 02-17-2019, 07:06 AM   #23
mrg666
pessimistic skeptic
mrg666's Avatar
Originally Posted by gt7877 View Post
Hi guys 👋
New crankshaft
New cp pistons
New 🦅 rods
New bearings
The goal is 400whp
Thanks 😘 again
You left the whole FI thing out. Building engine will not make power alone. Based on the FI application and power level you mention, you will still need transmission, differential, cooling, and other upgrades that will double/triple the cost and effort.
I think, you will waste the money and end up with a mess that will go directly to junk. Leave the car alone. You are not up for it yet.
Old 02-17-2019, 02:21 PM   #24
gt7877
Drives: turbo frs
I think u miss understood me
I have install also FI turbo kit
Oil cooler
Transmission well Handel 400whp with no issue
More than this well coze trans slip
Next Car Recommendation Prmspen Other Vehicles & General Automotive Discussions 21 10-12-2018 07:43 PM
Dead RB25 Swap, Alive 2jz swap -Phil Engine Swaps 72 09-15-2018 02:35 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Recommendation for GTA PDR? 1Cor10:23 CANADA 12 11-08-2014 09:08 PM
Non LED recommendation for DRL boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 13 05-11-2013 05:34 PM
