Old 08-31-2014, 07:42 PM   #5251
Pekingduck
Drives: 4 wheels
Thank guys on the head up with oil in the charger. I check after my oil change and it was running low, I was surprise how much the charger took.
Pekingduck is offline   Reply With Quote
Old 08-31-2014, 07:57 PM   #5252
wrxgoose
WUB WUB
Drives: 2013 Firestorm
Originally Posted by stevo585 View Post
Would the stage 1 kit on e85 make it to 250whp? Sorry too many pages to read....
you can make it on 93 octane with a good tune.
wrxgoose is offline   Reply With Quote
Old 08-31-2014, 08:08 PM   #5253
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Originally Posted by sickmint79 View Post
is afr a standard obd2 read? i don't see it in my solo dl.
Yes but the OEM sensor cannot read richer than 12
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 08-31-2014, 08:24 PM   #5254
stevo585
Drives: White 2014 BRZ
I'm meaning non-intercooled, if so that's not bad. Cool.
stevo585 is offline   Reply With Quote
Old 08-31-2014, 08:26 PM   #5255
wrxgoose
WUB WUB
I managed 265 on a dyno dynamics with the base kit. No ic or anything. Check my build thread
Old 08-31-2014, 08:27 PM   #5256
stevo585
On my OFT it seems like it pegs the lowest at 11.25. I haven't tried the torque app or Ecuek logging. So my OFT is lying?
Old 08-31-2014, 11:04 PM   #5257
Calum
That Guy
Drives: 2013 asphalt FRS MT
Why on earth would you run compressed air into an engine with this much internal compression, without an intercooler? Honestly if you can't afford the intercooler maybe you should re-evaluate your goals.
Take a look at the first post in this thread, without an intercooler I doubt you'll see much past 230. Even that might be ambitious.
Goose, your build was a unicorn. No one has been able to match those numbers with the same setup.
Old 08-31-2014, 11:13 PM   #5258
wrxgoose
WUB WUB
accepted and admitted. but i figure someone would atleast be able to break 250 on 93 with the stock pulley.
The Following User Says Thank You to wrxgoose For This Useful Post:
Calum (09-01-2014)
Old 08-31-2014, 11:47 PM   #5259
TemeCal
Drives: 86
I don't think this is true. I saw <12 readings all the time on my previous tune. In fact, I just looked at a set of my logs from the last tune, and the lowest AFR in the log was 11.37. So, I'm pretty sure the OEM sensor can read richer than 12.
TemeCal is offline   Reply With Quote
Old 09-01-2014, 12:56 AM   #5260
brianhj
Drives: 2017 Camaro 1SS
I don't know about the other guy but the reason I don't want to: removing the fucking bumper. Cheap thin plastic tabs that break or bend and cause the bumper to sag. I'm avoiding removing the bumper at all costs.
I seriously don't want to deal with that shit on this car.
brianhj is offline   Reply With Quote
Old 09-01-2014, 06:32 AM   #5261
sam69
Drives: GT 86
I've had mine off several times and it isn't an issue so don't be put off as it ain't that hard.
sam69 is offline   Reply With Quote
Old 09-01-2014, 02:49 PM   #5262
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
Yeah, I was reluctant at first to take my front bumper off, but so far I have done it 4 times already and I'm doing it again today to try and fabricate a shroud for my oil cooler. Removing the bumper isn't difficult and the plastic isn't really that weak either. If you break a clip or two then you can buy some replacements at your local auto store for cheap.
Think of it as taking off and putting on a 32 button dress shirt. Not difficult, just really annoying.
GFR - aka my build thread
"They don't think it be like it is, but it do." -Oscar Gamble
MINOCIN is offline   Reply With Quote
Old 09-01-2014, 04:11 PM   #5263
brianhj
So all the guys who have bumper sagging/gap problems.. Do you think they were too hasty in taking the bumper off? Maybe they weren't careful enough or something? Serious question. I really do want the intercooler.
Old 09-01-2014, 04:18 PM   #5264
mikalem
mikalem's Avatar
Drives: 2013 WRB BRZ Limited
If you don't want to remove the bumper to install the innercooler you don't have to - you can get to the area fine going through the bottom - just remove the plastic liner (around 8 pop rivets and 3 bolts) then the hard plastic piece (3 bolts) you have room to install the innercooler this way - its how I installed it, without unmounting the bumper itself.
mikalem is offline   Reply With Quote
The Following User Says Thank You to mikalem For This Useful Post:
brianhj (09-01-2014)
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
