DIY (Do-It-Yourself) Guides For all DIYs. |
06-17-2019, 05:03 PM | #15 |
Senior gif poster
Drives: 2013 Asphalt FRS
I toss a microfiber cloth in that center area and throw my phone in there, cloth so the phone doesn't jostle about and make noise in corners. I also sometimes put it in the drink holder on the door. When I bought my car my super old iphone fit perfectly in that cubby, but since then phones have gotten to big. I hate ALL phone mounts, they all suck and look bad.
So there is no where good for your phone to go, I suggest you make your next phone purchase to cater to what will fit in that cubby. |
The Following User Says Thank You to DandoX For This Useful Post: | DarkPira7e (06-18-2019) |
06-17-2019, 11:42 PM | #16 | |
Drives: BRZ limited
Hi, One option could be to get the base in the picture. It’s very solid and does not move while driving and you can put it any place on the dash, even on the little bump between the SW and mid vents (gets the shape easily). I use it with a scosche magic mount. Anyone who has a wireless charging phone can also use the supporting magic mount. Check the image below with my old phone holder. The base of the magic mount is very similar to this. Hope it helps! Thanks Sent from my iPhone using Tapatalk |
06-18-2019, 01:08 AM | #17 | |
The Dictater
Drives: '13 Red Scion FRS
06-18-2019, 01:12 AM | #18 | |
The Dictater
The Following User Says Thank You to Spuds For This Useful Post: | soundman98 (06-19-2019) |
06-18-2019, 01:21 AM | #19 |
The Dictater
I have an off-brand suction cup mount stuck on the small window on the door, which I use if I need to navigate with my phone. Otherwise it's in my pocket or, rarely, charging in the bottle holder. I have the USB routed to the driver's side door to let that setup work while charging.
06-18-2019, 07:35 AM | #20 |
1st86 Driver!
True, but the fine isn't huge (it's $50 for first offense and $100 for the second) so I doubt anyone goes to court to fight it. At least the 5 or so people I know that have been ticketed for it didn't bother.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
06-18-2019, 07:39 AM | #21 |
1st86 Driver!
I agree. I toyed around with getting a strong magnet to attach to the back side of the dash trim, then a thin metal plate with maybe some felt over it for the back of my phone case so I could just 'stick' it to the dash.
In the end though, since I really can control all the functions I need from the headunit, I just leave it in my pocket or but it in the door cup holder.
06-18-2019, 07:55 AM | #22 |
Drives: 17 Asphalt 86
This was my solution to mounting my phone. I wanted it off to the side near the head unit.
I got the bracket from a user on this forum who 3D prints it him self. I then wrapped it with something I had laying around, and finished off with a Magic mount. |
06-18-2019, 08:38 AM | #23 |
Drives: WRB Subaru BRZ Limited 6MT
This is similar to my solution. Instead of the bracket, I just taped a couple neodymium magnets to the backside of the trim panel and used the magnet-backed scosche magic mount. It doesn't survive serious potholes (unless the object you're mounting is tethered to an OBD2 or something similar - I use it to mount my OFT when I'm logging, etc.). But it works well enough.
06-18-2019, 01:27 PM | #24 |
Drives: BRZ limited
Where to put this bloody phone?
Long distance:
Short distance, daily; Both are magnetic! Sent from my iPhone using Tapatalk |
06-18-2019, 07:22 PM | #25 |
Drives: Brz
I bought a 4inch usb type c cable that fits perfectly and makes everything look clean with less cables around when connected and mounted there.
Sent from my LG-US998 using Tapatalk |
06-18-2019, 07:54 PM | #26 |
Drives: jrsc_brz
In a '13, I put the double cupholder thingy in its rear position and put my phone in the space in front 9f it. Right where the cigarette lighter is. Now where te f do 8 put my backpack? And do I get in first holding the bag outside, then put it on the pass seat? Or from outside, throw it onto the pass seat, then get in. I'm not going to start with getting out.
06-18-2019, 11:17 PM | #27 |
Drives: 2017 Toyota 86
+2 for ProClip mount. Not cheap but solid, well-made, and secure.
06-18-2019, 11:45 PM | #28 |
SlipGrips mounts + RAM setup on the windshield is the best bet, or the Scosch Magic Mount, if you like Waze. Mostly you should just ignore it and drive.
Tags |
holder, phone |
Similar Threads | ||||
Where do you sit your bigass Phone? | Kids Heart | Scion FR-S / Toyota 86 GT86 General Forum | 91 | 10-11-2014 11:39 AM |
Is it possible to use a phone as a BRZ key? | Killianti | Electronics | Audio | NAV | Infotainment | 19 | 08-13-2014 04:55 PM |
How often do you upgrade your phone? | tzhu07 | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 03-18-2014 05:43 AM |
Phone app. | DanoFA20 | Site Announcements / Questions / Issues | 6 | 10-22-2012 11:55 PM |
