Old 07-01-2013, 04:54 PM   #29
Yruyur
Yruyur's Avatar
You are correct.
Sent from a hamburger
Old 07-01-2013, 06:02 PM   #30
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Yep. The ethanol content analyzer is sending EC levels to the ECU many, many times a second. This can be verified using the ECUtek software. Pretty cool to watch -- down to the hundredth of a percentage.
That's how you get away with indiscriminate fueling. E85, 93, it doesn't matter. Just put it in.
cobrabyte is offline   Reply With Quote
Old 07-01-2013, 08:45 PM   #31
scudzey
scudzey's Avatar
Drives: Subaru BRZ
Just finished installing most of the kit here, just have to run power and ground at this point. I wanted to point out that for the ECU portion. You can disconnect the two 10mm bolts there and the main ECU assembly will come free allowing for slightly easier access to those tricky plugs.
scudzey is offline   Reply With Quote
The Following 5 Users Say Thank You to scudzey For This Useful Post:
cobrabyte (07-01-2013), JiB (07-04-2013), Sensisnow (07-01-2013), Visconti (07-03-2013), Yruyur (07-01-2013)
Old 07-01-2013, 08:48 PM   #32
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Thanks for the info, we'll try to detail that in the video install guide coming soon.
post_break is offline   Reply With Quote
Old 07-02-2013, 12:24 AM   #33
Sensisnow
Drives: 05 TSX & 13 BRZ
Where did you tap into 12v for power? I have all of the cabling done except for 12v power. I can't wait to fire it up!
2013 DGM BRZ
Visconti STG2 FlexFuel Tune - aFe intake - Perrin resonated catback - P&L header, front pipe, & overpipe - Kartboy short shifter - Eibach prokit springs - Smoked sidemarkers - Full LED interior/exterior - Kenwood cmos-210 backup camera - Hardwired Valentine V1
Sensisnow is offline   Reply With Quote
Old 07-02-2013, 02:12 AM   #34
Sensisnow
I ended up tapping into the radio fuse in the fuse box for 12v and used one of the bolts behind the kickpanel for ground. I just flashed the tune, so as soon as the ECU is done doing some learning, I'm heading out to grab some E85! Sure, it may be nearly 2:30am and I have to be up in a few hours for work, but this is much more important right now!
2013 DGM BRZ
The Following 2 Users Say Thank You to Sensisnow For This Useful Post:
cobrabyte (07-02-2013), Yruyur (07-02-2013)
Old 07-02-2013, 09:37 AM   #35
charged86
charged86's Avatar
Hey I wanna see this when you get it running.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 07-02-2013, 09:46 AM   #36
Sensisnow
It's up and running now.
Finally got back home just after 3am after filling up with some E85. There's only 2 stations around me that carry it and of course the first one was closed. I put in 3 gallons of E85 just after my fuel light came on and then topped it off with 93 octane. By the time I got back home I was running right at E30. I thought it would be higher than that, but I suspect that the ethanol content of the E85 that I got was lower since the sign on the pump stated that it had a minimum ethanol content of 51%. I'm going to try the other station and see if it has a higher percentage.
The car with this tune runs absolutely fantastic! I can definitely feel more torque in the lower RPMs and it just seems to have more power all around...and that's before I even added the E85! @Visconti thanks for yet another amazing tune, I can't wait to see how it runs on pure E85!
2013 DGM BRZ
The Following User Says Thank You to Sensisnow For This Useful Post:
Old 07-02-2013, 11:19 AM   #37
cobrabyte
cobrabyte's Avatar
It really is a great tune. I noticed the same thing you noticed... even on pump gas, it feels better all around.
Congrats on the install! Now, do some logging and send it over to John.
Old 07-02-2013, 11:27 AM   #38
Sensisnow
I plan on doing some logging tonight, although I don't know how useful it will be since I'm running STG2 without a header and I don't want to waste John's time. I thought that my P&L header would've been here by the time I got the tune, but no dice. Hopefully it'll come in next week so that I can see what kind of difference that makes. I'll be out of town until next Monday anyways, so I suppose a bit more waiting won't kill me, although I'm really going to miss driving my car until then!
2013 DGM BRZ
charged86 (07-02-2013)
Old 07-02-2013, 12:03 PM   #39
EL7
EL7's Avatar
Drives: 13 BRZ Limited 6MT SWP
Originally Posted by infinite012 View Post
This still doesn't address the disintegrating fuel pump filter inside the tank when using E85, right?
I haven't heard of this either. Do you have a source thread where this is discussed?
EL7 is offline   Reply With Quote
Old 07-02-2013, 12:10 PM   #40
post_break
post_break's Avatar
It's all speculation for now. Until we get more miles on more filters we won't know for sure that E85 is causing this.
http://www.ft86club.com/forums/showthread.php?t=37814
Old 07-02-2013, 12:11 PM   #41
Sensisnow
Basically it was one person who experienced a problem after putting extensive track miles on the car and there was absolutely no definitive proof that running E85 was the cause. Many, many other people are running E85 with no issues at all.
2013 DGM BRZ
EL7 (07-02-2013)
Old 07-03-2013, 12:38 AM   #42
Shaun.
Drives: '13 Silver BRZ Limited MT
What would a reasonable amount be to pay someone to install it the kit? Seems a little daunting to me...
Shaun. is offline   Reply With Quote
campaign: ban jv, diy, e85, fuel leak, kit, laughing to the bank, oh lord jesus its a fire, visconti, viscontifried, viscontinued
Flex fuel testing Dynotronics1 Southwest 5 06-22-2013 03:27 PM
FA20CLUB Flex Fuel Kit Ready FA20Club.com Engine, Exhaust, Transmission 16 05-22-2013 11:04 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
Cheap flex fuel? nix Engine, Exhaust, Transmission 1 05-11-2013 04:05 AM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 02:55 AM
