Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
11-16-2022, 03:19 PM | #1 |
Drives: White FR-S kosei k4r 17x8
E85 FRS getting harder to start in the cold
This is the 3rd year I've run my 2013 FRS on E85.
I've not had much trouble starting the car in the first 2 years. It generally took about 2-3 tries to start when it's cold. This year as temperature drops, sometimes I need to crank the car like 10-20 times before it would actually start. Anyone else had this issue? what did you do to fix it? Should I switch back to gas for a while? My Mods: UEL header, E85 tune from open flash, coilovers and control arms. No mods have been done since switching to E85 |
11-16-2022, 05:19 PM | #2 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I usually just do a 50/50 split or even a 25/75 split (e85/gas).
The Following User Says Thank You to weederr33 For This Useful Post: | alphasaur (11-16-2022) |
11-16-2022, 05:32 PM | #3 |
friendly
Drives: 17' 86
This is the way. A blend will get you majority of the benefit of eth and mitigate most of the issues.
Seek comfort in discomfort.
The Following User Says Thank You to alphasaur For This Useful Post: | weederr33 (11-17-2022) |
11-16-2022, 06:35 PM | #4 |
Rust bucket enthusiast
Keep in mind, as the battery ages, it loses its some of its cold cranking amps potentially. With that said, I think Weederr's approach is sound.
The Following User Says Thank You to DarkPira7e For This Useful Post: | x808drifter (11-17-2022) |
11-16-2022, 09:02 PM | #5 |
Who tuned your car for E85? If it is not a custom tune, OF E85 tune is not known for great cold start abilities.
The Following 2 Users Say Thank You to Grady For This Useful Post: | villainous_frx (11-16-2022), x808drifter (11-17-2022) |
11-16-2022, 11:12 PM | #6 |
11-17-2022, 08:29 AM | #7 |
11-17-2022, 11:33 AM | #8 |
What those guys said.
I am more curious as to where you find E85 in Ontario?
11-17-2022, 03:29 PM | #9 |
11-17-2022, 04:34 PM | #11 |
Oh that makes sense then. I know a bunch of people here that would love to get it and it just doesn't exist.
11-18-2022, 04:10 AM | #12 |
LMGTFY
Drives: 13 FRS, 91 Miata
11-18-2022, 10:48 AM | #13 | |
Master Collaborator
A test light. |
11-18-2022, 11:09 AM | #14 |
Drives: X5 35d, D90, CX-5 Turbo
The Following User Says Thank You to LRNAD90 For This Useful Post: | x808drifter (11-19-2022) |
Similar Threads | ||||
Bad cold start 10:1 91 | KeepItStock | Engine, Exhaust, Transmission | 2 | 04-25-2022 04:33 PM |
Cold cold(under 30dg) start sounds super weird | vladniko86 | Engine, Exhaust, Transmission | 9 | 11-19-2020 09:08 PM |
Cold start pop | Ash3482 | Engine, Exhaust, Transmission | 3 | 03-07-2019 07:39 PM |
Cold start | JG | Engine, Exhaust, Transmission | 8 | 08-29-2015 02:55 AM |
White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
