05-05-2017, 06:08 PM | #29 |
Drives: Nissan GT-R
Any updates?
05-06-2017, 12:01 PM | #30 |
Drives: 2015 frs
Still acquiring parts. I just bought a house so it pushed back the completion date to early next year. I bought the engine/transmission mount kit from vorshlag, as well as the driveshaft and transmission. Next is all the electrical, brakes, clutch, fuel system, exhaust manifolds and cats. Engine will be purchased last.
09-22-2017, 07:03 PM | #31 |
Drives: 2017 BRZ
09-25-2017, 09:33 AM | #32 | |
Drives: 2013 Ultramarine FR-S
09-26-2017, 02:18 AM | #33 | |
Drives: 2015 frs
I won't know until mock up. If it works I will switch it out for something better( for off-road track use ) after I get the sticker. |
11-24-2017, 11:40 PM | #34 |
Drives: 2014 BRZ
Any updates Zer0?
11-25-2017, 04:34 AM | #35 |
Drives: 2015 frs
No. I bought a house so it slowed me down. I will be buying the engine, and other big ticket items in Feb. Your pretty close to me im just past Stockton.
11-25-2017, 04:26 PM | #36 |
Drives: 2014 BRZ
Oh yeah, your close. I would enjoy checking out your progress when you get rolling. Figuring this swap out for California would be so cool.
Do you know if we need to stick with carb exhaust manifolds and stock cats only. Or do we need to stick with the exact exhaust system to the cats? (Meaning can we modify the exhaust pipes between the manifolds and the cats?) Congrats on the new house. |
11-26-2017, 01:52 AM | #37 |
Drives: 2015 frs
It has to all be the stock setup unmodified from the manifolds to the end of the cats for the engine you plan on putting in. Putting on carb approved parts should be legal but they prefer oem parts.
You will have to roll by when I get going on it. I will be posting progress on the swap and how the ref goes. If I can or can't get it done. |
The Following User Says Thank You to Zer0 For This Useful Post: | BAD ROD (11-26-2017) |
12-24-2017, 09:08 PM | #38 | |
Road-hole
Drives: 2013 Whiteout FR-S
once you get the swap plate...
You could probably put a 5.3 iron block truck lq4 in your car if you blow the ls3 and you'd be good. Jaden |
The Following User Says Thank You to Jaden For This Useful Post: | Zer0 (12-25-2017) |
12-25-2017, 03:23 PM | #39 |
Drives: 2015 frs
It's going to be a LT4 from GM performance. It would be easier, and cheaper to do a LS3, but I'm looking for highest HP OEM motor I can afford. Almost got the stacks ready to blow on this thing.
The Following User Says Thank You to Zer0 For This Useful Post: | ILLSMOQ (12-25-2017) |
01-17-2018, 07:22 AM | #40 |
Drives: FRS
Good luck!
I'll be watching very closely. |
01-17-2018, 11:51 AM | #41 |
Drives: 2017 BRZ
Similar Threads | ||||
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
California 86 Shirts | FR-Shred | Miscellaneous | 21 | 05-23-2016 03:43 AM |
Question from California | Cjymiller | EUROPE | 3 | 08-18-2015 02:33 PM |
California 91 | mike the snake | Engine, Exhaust, Transmission | 16 | 03-12-2014 06:46 AM |
California.. | VenomRush | Southern California | 92 | 11-16-2013 09:25 PM |
