06-02-2020, 03:06 AM | #3529 |
Drives: 2016 Scion FR-S RS 2.0
Yeah, 60-80lb range I think.
Edit: 60lbs manifold 81lbs total parts Per: https://www.ft86club.com/forums/show....php?p=2406569 Sent from my Pixel 3 XL using Tapatalk |
The Following User Says Thank You to jayjay06 For This Useful Post: | BR-ZED (06-02-2020) |
06-02-2020, 08:25 AM | #3530 | |
Drives: 2014 WRB BRZ Limited
06-02-2020, 01:13 PM | #3531 | |
Drives: 14 BSP Edelbrock BRZ
Saving $20 isn't worth having to have the tune adjusted. |
06-02-2020, 01:13 PM | #3532 | |
The radiator cap fit the radiator fill for doing the JR Dual Rad/OC, but none of the caps worked for the surge tank on Edelbrock LTR. Last edited by jayjay06; 06-02-2020 at 01:13 PM. Reason: grammar |
06-02-2020, 06:18 PM | #3533 | |
Drives: UK GT86
In fact, after a quick search part number 0 280 130 085 has an identical output to their TMAPS and is the same wire type as I run.
.: Stealth 86 :.
06-03-2020, 10:07 AM | #3534 |
Drives: 2016 BRZ Hikari
Anyone else had any issues with LSPI? I've had my kit on for about a month now, tuned by delicious about a week after running the supplied Edelbrock tune, I noticed a bit of light bogging around 2000RPM under light acceleration, like 10%. Talked to Bill and he almost immediately sent me some documentation on the heart of the issue as well as a revised tune. It seems to have gone away now.
Overall my experience with the kit was super easy, managed to get it on with 1 helped over the course of 8 hours, spent the next day topping up fluids and bleeding stuff. Delicious was fantastic as well, I can't recommend Bill and Nazar enough. I've got the kit combined with Tomei UEL header, Tomei Overpipe, HKS dual resonated front pipe, and FT86SF V1 exhaust. Previously ran an Invidia catless front pipe and if I so much as even looked at the throttle pedal I heard the sound of a thousand murder hornets coming from the exhaust. Sounds much better since the HKS front-pipe, hoping the welds don't crack...
2016 BRZ Hikari Edition @BRZHikari1 Build Thread: http://www.ft86club.com/forums/showthread.php?t=107326 |
The Following User Says Thank You to Hikari1 For This Useful Post: | BA9092 (06-03-2020) |
06-04-2020, 02:41 AM | #3535 |
You shouldn't have any LSPI issues whatsoever. If that occurs, that's a tuning error.
However, downshift. The engine doesn't like being loaded up at low rpms. |
06-04-2020, 02:58 AM | #3536 | |
Drives: brz 2017 hksv2
LSPI is legitimately hard to keep off with boost on this car with stock compression ratio, unless you heavily retard ignition timing on transient (and you feel this temporary lack of torque somehow) and possibly play with PI injection timing Are the newer sn+/dexos2 oils really as helpful for LSPI as they claim anyway? normally i use 0w40 but there isn t any with that rating |
06-04-2020, 03:37 AM | #3537 | |
I'd find it difficult to believe an oil can somehow influence what's going on in the combustion chamber of a healthy engine. |
06-04-2020, 03:46 AM | #3538 | |
Also, oil is going to be mixed somehow to the charge as soon as DI fires up, so it becomes parts of combustion |
06-04-2020, 03:52 AM | #3539 | |
06-04-2020, 04:11 AM | #3540 |
just 2 first links on google are good to me
https://www.jstor.org/stable/26278010?seq=1 https://www.sae.org/publications/tec.../2015-01-2811/ also, both Zach and Delicious use earlier DI injection , earlier also than stock, for high load and medium and high rpm while keeping PI fixed @360 degrees that causes surely more impingment on pistons? it's true though that LSPI = lower rpm and there there is always later injection, but if charge can dilute oil film and go past ring seals, then oil film can dilute charge to me |
06-04-2020, 04:41 PM | #3541 |
Accurate articles, but not really applicable as LSPI primarily is for low rpm high boost, as stated directly in your linked publications. An edelbrock is not trying to push 1bar+ at 2500 rpms. It's barely making perhaps 0.2 bar, being generous.
The Following User Says Thank You to CSG Mike For This Useful Post: | tomm.brz (06-05-2020) |
06-04-2020, 11:28 PM | #3542 |
Drives: 2015 Subaru BRZ Limited
Just an update on the MAP sensor relocation re fuel economy. My commute is about 80/20 highway/city and 20 miles each way.
Previous to MAP relocation: 25.8mpg After MAP relocation: 30.7mpg Bone Stock before s/c: 28.5mpg I know the fuel economy indicator isn't the most reliable, but the delta does seem real. Last edited by devtec; 06-06-2020 at 06:44 PM. |
The Following User Says Thank You to devtec For This Useful Post: | CSG Mike (06-05-2020) |
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
