Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-17-2021, 08:24 PM | #1 |
Drives: White 2013 BRZ Limited 6MT
Which Oil Sensor Is Better To Put Into The Block
Relocating either my oil temp or oil pressure sensor into the engine block via an oil galley plug. I'm installing a greddy oil cooler. I already have the oil temp and oil pressure sensors in a sandwich plate. I'm assuming I want to leave the temp sensor at the oil filter, and put the pressure sensor at the block, but I want to make sure I'm getting things as accurate as possible.
05-17-2021, 08:33 PM | #2 |
Rust bucket enthusiast
The real thing (in my opinion) to be cognizant of is consistency. If you're used to seeing certain pressures at certain RPM and get used to them, that's more valuable than them receiving different flow elsewhere.
Example- it's better to know that 51psi at 7400rpm is lower than your usual at one sensor location, than moving it and getting the same reading, but having to ask "is this normal for this sensor in this location?"
The Following 4 Users Say Thank You to DarkPira7e For This Useful Post: |
Similar Threads | ||||
WTB: FA20 Long Block/Short Block blown/running | The Racers Line | Engine, Exhaust, Bolt-Ons | 7 | 07-29-2014 01:26 AM |
WTB: FA20 Short Block or Blown Long Block | The Racers Line | Want-To-Buy Requests | 1 | 06-29-2014 05:21 PM |
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor | Supra2k | Audio/Visual, Electronics, Infotainment, NAV | 1 | 02-26-2014 08:11 PM |
WTB: short block or long block | DOTman05 | Engine, Exhaust, Bolt-Ons | 2 | 07-14-2013 06:48 AM |
