Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
08-26-2018, 07:45 PM | #169 |
Which cooler?
08-26-2018, 07:55 PM | #170 |
The Stark Performance cooler. It's a Setrab core that mounts in the fog light well. I've already got the cooler mounted, I'm currently working on routing lines, but I'm not entirely sure what the correct path to follow is. Anyway, once I get it all routed and installed, then I have Redline D6 ATF to go in I added a DIY guide for how to do the AFT fluid change to the DIY forum from the experience. Last edited by Tristor; 08-29-2018 at 02:36 AM. |
The Following User Says Thank You to Tristor For This Useful Post: | Busybee (10-25-2022) |
Similar Threads | ||||
DIY - Transmission / Diff Fluid Change Reference Guide | F1point4 | DIY (Do-It-Yourself) Guides | 295 | 05-13-2023 02:34 AM |
Transmission fluid swap? | flawedchemical | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 48 | 09-12-2014 02:23 PM |
Mt transmission fluid swap | bdanisi | Engine, Exhaust, Transmission | 8 | 02-08-2013 02:09 PM |
Transmission and Differential Fluid Change LINK | Amadeus | DIY (Do-It-Yourself) Guides | 1 | 12-23-2012 06:01 PM |
topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) -- General Topics | 51 | 05-04-2012 07:54 PM |
