Forced Induction Turbo, Supercharger, Methanol, Nitrous |
05-27-2013, 12:52 AM | #15 |
Drives: Scion FR-S
Eh...
The Following 2 Users Say Thank You to Gen For This Useful Post: | nix (07-19-2013), SkullWorks (07-16-2013) |
05-27-2013, 05:31 PM | #16 |
Drives: ZC6, Junk of ALL sorts
That's coming from the connection of the compressor inlet to your tester, right?
Bubbles rolling around the compressor housing walking toward the turbine side. Actually leaking from the tester connection. If so... no worries, just a funny picture to post.
# 1. Always know where your towel is.
ZC6-CBS, is home |
05-27-2013, 05:40 PM | #17 | |
Drives: Scion FR-S
At redline I'm seeing a drop to about 7.1 psi from a max of 8. Might explain the drop off in power I see on the dyno. If I remember correctly, the GT28s have no O ring; bolts are definitely snug. High temp RTV seems to come highly recommended. |
05-28-2013, 12:12 AM | #18 |
NASA SpecE30 Racer
That is interesting looking. I know I didn't put anything on any of my bolts when I assembled and clocked my GT28.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
05-28-2013, 12:35 AM | #19 |
Drives: Scion FRS
Use this as a cheap excuse to get a gtx30
07-01-2013, 02:14 PM | #20 |
Drives: Scion FR-S
Mustang dyno after addressing some issues with the original fuel pump install and sealing the turbo. I don't advise following the instructions that are sent with the kit for the pump. |
07-01-2013, 02:28 PM | #21 |
That's still very, very low. Something is wrong there.
07-01-2013, 02:49 PM | #22 |
Drives: 2013 Asphalt FR-S
On a Mustang dyno though? Those read super low as it is. Isn't the base FBM kit only do between 260-280whp on a Dynojet?
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
07-01-2013, 02:55 PM | #23 |
i would still consider that to be very low. I've never seen an FBM kit make less than 270whp even on a completely stock car on 91. That's what, 225whp? I could be wrong.
07-01-2013, 02:57 PM | #24 | |
Drives: Scion FR-S
For what it's worth, it read 155 at the wheels before addressing the fuel pump. The original installer followed the instructions on the install to a T, complete with zip ties. (not being sarcastic) It's now much more secure. |
07-01-2013, 03:06 PM | #25 |
correction to a dynojet reading would be 12% according to the sticky (not an exact science, i know). that put's at at 243 dynojet whp. i'd get the thing looked at.
07-01-2013, 03:22 PM | #26 | |
Drives: Scion FR-S
Here's King Tut's Dyno on 93 Considering it's on a dynojet with better fuel, that's damn near identical. This was his 14psi run. |
07-01-2013, 03:33 PM | #27 |
Drives: Scion FRS
We just did a complete turbo install on a customer car that made 304hp @10 psi on 93 pump.
On 16 psi and e85 we made 400hp. I will post up the whole build shortly. |
07-01-2013, 05:17 PM | #28 |
NASA SpecE30 Racer
I would not quote my numbers. As time has gone on, I have grown less confident in either of those dyno plots being correct due to RPM pickup issues. The RPM scale is not correct for either pull that was collected. I will have new dyno plots after July 12th.
- King Tut
The Following 4 Users Say Thank You to King Tut For This Useful Post: |
Similar Threads | ||||
86 Dyno results | Anban | AFRICA | 18 | 01-14-2014 06:54 AM |
Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
Compilation of Dyno results somewhere??? | Scooby South | Engine, Exhaust, Transmission | 3 | 01-08-2013 06:51 PM |
Pocket Dyno App Results | CBR600RR | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 09-12-2012 10:45 PM |
My Fr-s Dyno Results!! Surprising if you ask me | track_warrior | Engine, Exhaust, Transmission | 36 | 07-02-2012 10:15 PM |
