Old 11-03-2018, 08:22 AM   #1
junior-subie
OFT - Calibration Code Changes?
Hi all,
I'm pretty new to tuning and just wanted some reassurance -- I currently have a Stage 1 OFT tune on my BRZ. When I checked my calibration code before I flashed the ECU, my calibration code was ZA1JK00D (MY2017 US 6AT). However, when checking again now, my code is ZA1JK01I (MY2017 EU 6AT). Is it normal for the calibration code to change after tuning?
I'm about to do a Stage 2 tune on the car and just want to make sure I download the appropriate files. Thanks in advance
junior-subie is offline   Reply With Quote
Old 11-03-2018, 08:55 AM   #2
JIM THEO
Drives: BRZ 2018
Originally Posted by junior-subie View Post
Hi all,
I can't answer your exact question but sure your call ID should not change after the remap except Shiv has hacked for some reason your original maps.
If not sure about the stage 2 OFT just use your original ROM and copy the required tables from Shiv's stg2 maps, you simply loose FFT and LC.
JIM THEO is offline   Reply With Quote
Old 11-03-2018, 11:47 AM   #3
tomm.brz
Drives: brz 2017 hksv2
it's normal, v4 tunes for my17+ US car are based on EU my17+ stock tunes
Shiv brought back the old logic of pre-restyle to the newer ones because it works better and it 's easier to tune
when you are unsure, always download from oft website the tune with same calid of your original stock rom, in your case ZA1JK00D
DIY - Color Code of ID plate and code of part (SUBARU) - SB18-091 Trap63 DIY (Do-It-Yourself) Guides 0 06-14-2018 04:52 AM
p0462 fuel level sensor code. anyone else ran into this code georgiafrsguy Engine, Exhaust, Transmission 1 02-28-2017 08:28 PM
OFT help - A02J calibration ID? yunheng Software Tuning 7 08-18-2015 05:08 PM
New RPM Calibration TSB... 5AD86D Issues | Warranty | Recalls / TSB 23 01-21-2015 10:50 PM
changing calibration id garfull Software Tuning 3 09-14-2014 12:30 PM
