04-16-2012, 02:39 PM | #1 |
Drives: TBD
Cheap winter alloy rims
I don't really want to drive around on steelies for 4 months a year, but at the same time I am not willing to drop 3K on high priced alloys for my winter tires. Any ideas/sources for lower-priced alloy rims in southern Ontario?
04-16-2012, 03:18 PM | #2 |
Kuruma Otaku
Used 16" WRX wheels.
Because titanium. |
04-16-2012, 03:21 PM | #3 |
i'm sorry, what?
Drives: Canada
VW forums are also a good place to look for all kinds of 5X100 stuff.
04-16-2012, 03:21 PM | #4 |
Drives: TBD
Prob with used is that you can have non-visible warping or off-true deformation that only shows up when you drive - feels like a wheel balance problem that can't be fixed.
04-16-2012, 03:24 PM | #5 |
Drives: TBD
Besides wheel bolt pattern and size (17 X 7 standard) you have to specify the offset, correct? Which is IIRC 48mm.
04-16-2012, 03:35 PM | #6 |
i'm sorry, what?
Drives: Canada
the offset can be anything you want it to be so long as the wheel/tire combo doesnt rub
deviating from OEM width and offset will impact your scrub radius which has peculiar effects on handling. I won't go into the details, but anything you'll be fine with anything between the +55 and +40 range. and don't worry about centerbore, so long as it's larger than yours you are right, hidden problems with used wheels could happen. I've had a number of used wheels over the years and no problems.. knock on wood. I bought a set of used Kosei K1's in 2005 and they've seen track and street duty ever since.. and if they happen to fit over the FRS brakes then i might as well use em, haha. but if you're worried about used then buying NEW steelies is your best bet. Less headaches for everybody, plus adds to that sleeper look.
The Following User Says Thank You to 7thgear For This Useful Post: | Sport-Tech (04-16-2012) |
04-16-2012, 03:46 PM | #7 |
I usually post drunk
Buy a set of nice wheels for summer tires.
Buy a set of winter tires and mount them on stock wheels. ??? Profit |
04-16-2012, 03:50 PM | #8 |
i'm sorry, what?
Drives: Canada
fixed
04-16-2012, 08:10 PM | #9 |
Drives: 01 Toyota Corolla / Porsche 911 C2
I was just going to use the stock rims as winter wheels lol.. and get something else for summer (konigs or enkei)
04-16-2012, 08:22 PM | #10 | |
Kuruma Otaku
I think with going to a 16" for winter you'll find a better, less expensive winter tire selection. With my old Civic, I went +1 for the summers and -1 for the winters. (For example stock wheels and tires were 185/60R14, so in the summer I went to a slightly wider 15" rim and tire that kept the diameter ~ the same with 195/50R15, and for the winters I did the opposite with 175/70R13.) -1 for the FR-S will be ~205/55R16 (a little bit more diameter, and older WRX standard tires) or 195/55R16 (a little bit less diameter). I've got a set of WRX rims on my Legacy. But the Legacy will be the winter beater...
Because titanium. |
04-16-2012, 10:27 PM | #11 | |
Drives: 4 Wheels Auto
Another idea suggested of buying a set of good rims for summer and use the stock ones for winter is also good since the stock rim does not look too bad (IMHO) for winter use. It is just that you need to use up the stock tire pretty quick for the winter time. It is a bit pricy, though. |
04-16-2012, 10:41 PM | #12 |
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
why dont u just get some el cheapo black steelies for winters...doesnt have to be alloys....
04-16-2012, 11:12 PM | #13 | ||
Drives: TBD
04-16-2012, 11:53 PM | #14 | |
Drives: 2011 Outlander XLS, 2013 FR-S Blue
But for winter wheels, totally not needed. In Calgary I have at least 5 non-chain shops I know that will have tons of options or can order them in. Toronto will have many more. There are many 5x100 choices for us especially in 16s. |
Similar Threads | ||||
MR2 winter progress | NESW20 | Other Vehicles & General Automotive Discussions | 35 | 04-01-2013 10:43 PM |
BRZ/FR-S and winter driving: Watch this video if you have any concerns! | Turbowned | BRZ First-Gen (2012+) -- General Topics | 53 | 07-15-2012 11:29 PM |
After this last winter is RWD such a bad idea | Nate219BRZ | Great Lakes | 3 | 03-14-2012 05:03 PM |
Winter drivers... How moron it can get? | ichitaka05 | Off-Topic Lounge [WARNING: NO POLITICS] | 54 | 01-28-2012 04:34 PM |
Winter Sucks | OldSkoolToys | Off-Topic Lounge [WARNING: NO POLITICS] | 16 | 02-19-2010 12:02 PM |
