Old 06-04-2014, 12:24 PM   #15
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by Dezoris View Post
I am testing out new tuning, and my previous tune maintained stock fuel cut off at 7450. The new tuning is quite the change but also has a higher fuel cut I believe at 7800.
Since I am Mr. Conservative, today I was driving bit hard in first hit 7700RPM and almost sh*t my pants.
Whats your feeling about what fuel cut off and what to set it at?
Seems the community is mixed. Toan of pTuning says hes done hundreds of dyno pulls out to 8k with no ill effects and he recommended to me to rev my car out that high to maximize power band on the 3076. Both Delicious Tuning and Jamesm don't recommend it other than extending 2nd gear. CSG doesn't recommend it.
I have seen plenty of FI dyno graphs here with people running to 8k. Is it safe? Unkown. So far it seems alright.
In the end it is your motor and if I had your setup and the torque curve stayed flat or kept increasing past 7400 rpm then I would probably choose to run up to 8k rpms to take advantage of that at the risk of more wear and tear.
The Following User Says Thank You to sw20kosh For This Useful Post:
chaoskaze (06-06-2014)
Old 06-04-2014, 12:33 PM   #16
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
While I'm still Na I have 4 maps that do different things. Maps 1 and 2 keep the stock redline fuel cut.
maps 3 and 4 keep the same redline however it does not cut fuel. It just stays at redline until I shift it.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following User Says Thank You to feldy For This Useful Post:
levifig (06-05-2014)
Old 06-04-2014, 12:34 PM   #17
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by dwx View Post
With the turbo I'm looking to put in a 3.91 FD so I won't have to wind out 2nd gear so much in autocross. I plan on running 7800RPM as the redline, but will be tapering boost a bit above 6800 just to keep stress off the engine.
3.91 wont be that noticeable , and i am doing a longer fd in one week
Sent from my IBrick
Old 06-04-2014, 12:43 PM   #18
Dezoris
Dezoris's Avatar
Well that's the thing, Bill says his tune is safe and tested. I have heard that from others and well, kind of echos that in this thread but... Clearly varying opinions.
Do you have any headwork done? If not, I HIGHLY recommend u drop the redline.
Thats my feeling, the tune maybe safe but that does not mean mechanically long term it will hold up.
I requested the redline be dropped to 7500. Never had an issue before shifting below 7K, but this tuning ramps up so fast at high RPM I cant catch it and autox is even worse.
Old 06-04-2014, 12:45 PM   #19
D K
Stig's dark passenger
Do people realize that dyno pulls and racing are 2 different things?
Show me somebody who is racing, regularly and revs it to 8K and let's see how long their engine will last.
Have you guys looked at the rocker arm design of our motors?
I'm surprised they last to 7400...
D K is offline   Reply With Quote
The Following 2 Users Say Thank You to D K For This Useful Post:
CSG Mike (06-04-2014), SmsAlSuwaidi (06-04-2014)
Old 06-04-2014, 12:46 PM   #20
SmsAlSuwaidi
Boosted
Well it is known that rocker arms are the weak link other than rods ! A few motors already blew from this issue, but most were revving over 8grand. My mechanic buddy already has a built set of heads/cams in his frs who was with me on the dyno and kept insisting to not over rev !
Sent from my IBrick
Old 06-04-2014, 01:22 PM   #21
xwd
Sent from my IBrick
I've done calculations and for my needs it's enough with the right tire size. I think the 3.73 would be too much. Still trying to make the decision though.
A local tuner pushing 500WHP floated a valve at 8K. He replaced the valves with Kelford ones and no more issues.
Old 06-04-2014, 01:27 PM   #22
SmsAlSuwaidi
Boosted
What Redline/Fuel Cut Off You Running
Ah ok, since my car is mostly a street car i hate doing a high boost pull with the current gearing. I just end up mashing gears and be in the top of 5th in no time.
Regarding values i remember being told the stockers are so soft @DesertFrs knows more about it
Sent from my IBrick
Fuel pump running when the car is off? Target70 Scion FR-S / Toyota 86 GT86 General Forum 12 03-25-2014 05:32 PM
FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 28 02-02-2014 08:19 PM
Electric fuel pump running with car off??? bpracer Issues | Warranty | Recalls / TSB 13 08-08-2013 09:42 AM
CEL after running out of fuel Kido1986 Issues | Warranty | Recalls / TSB 10 02-11-2013 12:34 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
