Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
03-01-2017, 02:57 PM | #1 |
Drives: 2015 frs
Widest 0 offset wheels that will fit.
Widest 0 offset wheels. Only concerned with clearing unibody and coilovers. Fenders bumpers and quarter panels are not a concern for me.
I can always go wider with the bodywork. Maybe Rocket bunny or custom. I would like enough room for good suspension settings for track use camber ect. Looking at 17" or 18" options. Prefer 17" but more tires are available in 18". No stretch 295 or wider tires. Guessing 11"-11.5" wide might fit. Any feedback would be appreciated. Posted in another thread no help there I don't know how much traffic they get though. Thanx in advance. |
03-01-2017, 03:07 PM | #2 | |
Drives: 2005 Toyota Camry
None. Widest 0 offset wheels that will fit with custom widebody? Anything multi-piece upwards of 16" wide. |
The Following User Says Thank You to mav1178 For This Useful Post: | Zer0 (03-01-2017) |
03-01-2017, 03:16 PM | #3 |
Drives: Legacy GT
The math is not too hard. The stock offset is 48mm. Going to zero offset would put the wheel 48mm farther out. That means if the whole wheel was 96mm wider, the inner face of the rim would be in the same spot. 96mm almost 4"
Also there are numerous online calculators that will compare the location of the rim and tire for different sizes. |
03-01-2017, 03:36 PM | #4 |
Drives: 2015 frs
So my estimate of 11.5 should work? I just like second opinions from people with experience with things I haven't done yet. I did the math and that was what I came up with.
03-01-2017, 03:38 PM | #5 |
Drives: 2015 frs
I planned on custom rotiform HUR wheels don't want to mess up the order as they can't be returned
03-01-2017, 03:51 PM | #6 |
Drives: 2013 Ultramarine FR-S
You are going to be hitting frame and need pretty major Non-replaceable body work to fit such a large wheel at that offset in the front. Not sure why it needs to be 0 offset. It will stick too far out in the front, and not enough in the rear for rocket bunny fenders (unless running 12+ inch in the rear). Really an 11" is going to be wide enough to fit a 315 all around. Again Fitting that up front is a mess. 285s up front with a perfect flush RB v1 Fender fitment on 10.5" wheel was enough that I had to trim the kit, bumper, Rear frame extension, headlight bracket slightly, rubbing the seam at the top of the wheel well. Rubbing the rear RB Kit/bumper still as well.
03-01-2017, 03:53 PM | #7 | |
It is going to suck for track use or any type of performance driving. If you want to hard park or get a nice show setup, go for it. Just don't kid yourself by thinking this will make the car drive better. I was purposely vague on my reply because your question is extremely open-ended. -alex |
03-01-2017, 04:02 PM | #8 | |
Drives: 2015 frs
03-01-2017, 04:04 PM | #9 |
How wide is it? Greddy's website says it is the same width as the V1 which I don't think is correct, and I couldn't find a number anywhere.
The Following User Says Thank You to DustinS For This Useful Post: | Zer0 (03-01-2017) |
03-01-2017, 04:05 PM | #10 |
Drives: 2015 frs
It looks wider but everything says it's not.
03-01-2017, 04:15 PM | #11 | |
Drives: 2015 frs
Similar Threads | ||||
Widest Track tires for stock wheels?? | track_warrior | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 56 | 10-11-2015 11:01 AM |
WTB Low Offset Wheels. | BCTV93 | Want-To-Buy Requests | 0 | 09-10-2015 01:26 AM |
Whats the biggest/tallest/widest tire you have on 17/8 wheels? | NickFRS | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 06-14-2013 09:36 AM |
how will +35 offset wheels fit | yetiFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 05-15-2013 05:33 PM |
What is the widest tire for these wheels? | ngabdala | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 09-12-2012 09:20 AM |
