Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
11-06-2014, 06:22 AM | #57 | |
11-06-2014, 07:29 AM | #58 | |
FBKC @ low rev and high/low load. I would change out ignition advance/kc learned and change to Oil temp/IAT, or run 91 tune on 93 if you have no access to E85, but that's because I hate seeing knock.
11-06-2014, 09:58 AM | #60 | |
There's an e85 station about 30 minutes from my house. Wouldn't want to drive there all the time, but I could fill a 5 gallon container every few weeks and create an e20 mix. I wonder if the e20 mix would eliminate the detonation (effectively 95 octane) and lean out the AFR by about 3-4%. Could be a way of killing two birds with one stone, no?
2022 BRZ Build 2013 FR-S Build |
11-06-2014, 12:16 PM | #61 | ||
There's no danger in going WOT before the trims have stabilized, the ECU will keep adjusting to hit AFR targets
11-06-2014, 05:35 PM | #62 | |
Chronic Flashturbator
Drives: '13 Scion FR-S MT
Then again, maybe your stock ECU tune was just a freak of nature? lol
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
11-06-2014, 07:44 PM | #63 | |
11-07-2014, 03:30 AM | #64 | |
Which is why looking at oil/air temps could help narrow it down.
11-07-2014, 04:11 AM | #65 | |
Ok somewhere before that log started were knock events that dropped your IAM below 1 , it was most likely lower rpm high load knock in 1500-3500 area as @s2d4 said. once you iam drops ie ecu pulls timing across entire rpm range reducing power. you can see a couple of instanced of fbkc of -2 degrees. your also pulling another degree flkc even with timing reduced by iam of 0.9. yes as @BuBlake and other said your running richer than ol fuel over 6000 and its flat lined at 11.25 which is about the limit of the reading of the 02 sensor so it may be even richer. think you have two problems maf way off top end likey aftermarket intake ?? and you have a batch of crappy 93. try some different brands of fuel this is likely why header tune is not performing as the header tune runs more advance than stage 1 tune and due your iam drop and still knocking the ecu has pulled that ectra advance that give you power , coupled with running rearly rich above 6k yep maf scale and better batch of fuel shouls sort it, fuel trims look fairly good so exhaust leak unlikely |
The Following User Says Thank You to steve99 For This Useful Post: | DarkSunrise (11-07-2014) |
11-07-2014, 08:16 AM | #66 |
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Just FYI..
Every time I do a dyno pull (or do aggressive driving) right after I change the tune my I get knock and my IAM drops a TON. The only way I can drive aggressively without losing timing advance is to give my car significant amount of time to learn the trims. If I flash a tune and drive ~80kms to my typical autocross meeting area then it is usually fine. Just an example, my car made 175whp before my header, fp/op, and OFT. After I installed all this stuff I went back and flashed my car on the dyno. Even though I went through the proper startup procedure my IAM immediately dropped to 0.8. A few runs later it was at 0.6 and I made ~160WHP (which really got all the VW guys laughing lol) On the drive home As the car learned the trims IAM came back up, and once it was at 1 no matter how hard I drove it it would not drop below one.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion 2017 Bluenose Autosport Club Overall Rallycross Champion Powered by Great North Performance, Jani-King Canada, and OK Tire. |
The Following User Says Thank You to Thorpedo For This Useful Post: | DarkSunrise (11-07-2014) |
11-07-2014, 11:38 AM | #67 | ||
11-07-2014, 04:19 PM | #68 | |
11-07-2014, 05:03 PM | #69 |
Sounds good - I'll try to clean it tonight before my track days tomorrow.
11-07-2014, 06:31 PM | #70 | |
Drives: Passat
If you say so. Last edited by Fast_Freddy; 11-07-2014 at 06:42 PM. |
Similar Threads | ||||
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 | FRSTEVE | Software Tuning | 105 | 08-04-2017 04:48 AM |
Stock FR-S/BRZ shock dyno & stock FR-S spring dyno | xwd | Tracking / Autocross / HPDE / Drifting | 16 | 08-07-2014 09:04 PM |
Stock Dyno vs GReddy Intake Dyno | JTOFJPN | Engine, Exhaust, Transmission | 0 | 06-01-2014 03:56 AM |
Stock Dyno and Perrin Stage 1 Results | brillo | Software Tuning | 4 | 01-24-2014 08:26 AM |
FINAL RESULTS: Taking Full Blown Stage 1 To The MAX! @Pure Automotive (Dyno Inside!) | Pure Automotive | Forced Induction | 57 | 03-27-2013 11:41 PM |
