Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
View Poll Results: What name should Toyota use for the production Toyota FT-1? | |||
Supra gets my vote! | 367 | 74.59% | |
I don't know, but its time for a new name. | 125 | 25.41% | |
Voters: 492. You may not vote on this poll |
03-18-2018, 04:51 AM | #2409 |
Because compromise ®
Drives: Red Herring
[ame="https://www.youtube.com/watch?v=rBN5CWMcOnE"]Jaguar Land Rover Transparent Pillar, Ghost Car Navigation research - YouTube[/ame]
The Following User Says Thank You to Captain Snooze For This Useful Post: | daiheadjai (03-19-2018) |
03-18-2018, 01:22 PM | #2410 | |
1st86 Driver!
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | daiheadjai (03-19-2018), WolfpackS2k (03-20-2018) |
03-18-2018, 01:34 PM | #2411 |
Drives: RX-7 / BRZ
FIFY
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
The Following 2 Users Say Thank You to Kiske For This Useful Post: | Dadhawk (03-18-2018), daiheadjai (03-19-2018) |
03-19-2018, 02:30 AM | #2412 |
Drives: Q5 + BRZ + M796
I’ve been trying to figure out how the center of gravity is lower than the 86. Does the car sit lower? Did they add weight low in the vehicle like using an iron block? Maybe a dry sump?
Also, the 50/50 ratio. Is this measured with a driver or without? I recall someone here who weighed their 86 with and without himself in the car and found the weight distribution 50/50 or 51/49 or something. Isn’t it more important where the weight is than if it is 50/50 like if the weight isnt center mass, but rather, at the ends then that isn’t ideal, but the car might be 50/50? |
03-19-2018, 12:00 PM | #2413 |
Drives: 2003 S2000, 2008 Fit
I don't think we should need this - but with how thick A-pillars are getting, I think a case could be made for it. Especially as avoiding pedestrian collisions is such a priority.
03-19-2018, 12:06 PM | #2414 | |
Drive upgrades. Don't buy them.
03-19-2018, 02:35 PM | #2415 | |
Drive From Home
Drives: BRZ STI Performance
This 50/50 weight distribution is most likely a Bimmer marketing thing. I think even the Miata isn't perfectly 50/50 without the driver, even tho the printed ad says so. BTW I asked my physics scientist friend about this new Supra where the engine is taller and narrower than our boxer engine yet with a roof that's lower. He said this overall lower CoG by a small margin could be BS and he would rather have the advantage of the more stable boxer since an engine is heavy. |
The Following User Says Thank You to krayzie For This Useful Post: | Irace86.2.0 (03-19-2018) |
03-19-2018, 02:45 PM | #2416 | |
The Following User Says Thank You to fatoni For This Useful Post: | WolfpackS2k (03-20-2018) |
03-19-2018, 04:42 PM | #2417 |
Anti stance.
Nothing has a front end like a 911. Know why? Because all the mass is in the back.
03-19-2018, 07:03 PM | #2418 | |
Drive From Home
86/BRZ/FRS 53/47 weight distribution explaination @ 5:13 [ame="https://www.youtube.com/watch?v=tHVhaTNRk8E"]2013 Scion FR-S/Toyota 86 Chief Engineer Tetsuya Tada Interview - YouTube[/ame] Fairlady Z/350Z 53/47 weight distribution explaination @ 6:33 [ame="https://www.youtube.com/watch?v=d2KBlta-zu4"]Best Motoring International Vol. 06 - The 350Z Shock - YouTube[/ame] Engine height for the front of the car is definitely a compromise with configuration other than a boxer. The boxer being wider, Subaru flipped the lower A-arm front to back and made the coil spring diameter smaller for better packaging (I think they got this idea from looking at older Porsches). All these stuff were discussed to death ages ago on this forum. Last edited by krayzie; 03-19-2018 at 07:19 PM. |
The Following User Says Thank You to krayzie For This Useful Post: | fatoni (03-19-2018) |
03-19-2018, 09:11 PM | #2419 |
Site Moderator
Drives: Supra
Most revealing 2019 Supra prototype spy pics yet! (Spotted March 19, 2018)
03-19-2018, 09:24 PM | #2420 | |
Drives: 91 Toyota Supra 16 Nissan Versa
it is quite beautiful
The FRS/BRZ was not meant to be a world beating car, it was not meant to be an extremely fast car, nor a powerful car, but a well balanced fun car.
03-20-2018, 07:41 AM | #2421 | ||||||
Drives: '23 BRZ
A V4 would for me be the perfect small/lightweight/inexpensive sports car powerplant... Quote:
For *me*, I wish they made a dedicated 2-seat/hatch version with the engine/trans, firewall/cowl and front-seaters moved about 18" aft. That would give much better weight distribution (and 50/50 *is* "better"). Quote:
Anyway, 50/50 is *not* "perfect". FR cars with decent power to weight are better with rear weight bias. If I could get my 550hp FD to something more like 45F/55R, I would (stuck at 50/50 with driver and 1/2 tank fuel). Quote:
Also, I guarantee the supra's driveshaft, flywheel/clutch, transmission all sit much lower than the 86's. Overall engine/trans c.g. height is probably not that different, and not far from vehicle vertical c.g. location for either. Quote:
And while we're talking about it, look how far FORWARD the boxer engine has to sit: A boxer engine is not ideal for either vertical or fore/aft c.g. location in an FR car... |
The Following 3 Users Say Thank You to ZDan For This Useful Post: |
03-20-2018, 01:29 PM | #2422 |
I think you are right on a bunch of your points.
If they had made the 86 a two seater then the engine could have been moved back further like the Corvette or 370z; other FR 2+2 setups like the Camaro or Mustang have engines that are necessarily moved forward. The Corvette’s engine does sit low because it is further back but it is significantly higher than the 86 motor. Remove the AC compressor, alternator and intake manifolds on both vehicles, and it is much more apparent the difference. The LS and LT motors are really compact, so that helps, but the Corvette also has other heavier components down low like their heavier transmission, differential, etc. BMW tries to keep CG low by using a slant six, so I’m guessing the Supra’s two seater setup will allow them to tuck the engine back and low enough. I wonder if there will be an xDrive option. I’m guessing not because tradition. BTW, the curb weight and distribution I have seen is without a driver. I can’t find the thread when the guy weighed himself in the car. I’m curious to know if there would be a significant difference. Obviously the height and weight of the driver will be important variables: http://www.ft86club.com/forums/showthread.php?t=4287 |
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | krayzie (03-20-2018) |
Tags |
bmwforsuckers, boring-zzzzzzzzzzzzz, brz, celica supra confirmed, frs, ft-1, hatch-y +1, morethanucanaffordpal, nomanualnogo, supra, toyota, twins, watstheretailon1ofthose |
Similar Threads | ||||
Toyota FR-S : Official Name for the FT-86 Concept? | Dark | Scion FR-S / Toyota 86 GT86 General Forum | 155 | 08-04-2010 11:05 PM |
