Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
01-05-2014, 02:45 PM | #1 |
Window switches not working right after battery swap
Okay, so the other day, I swapped my batter out for a Lightweight Braille battery (11lbs, using the FT86SpeedFactory kit, if it matters). Ever since then, I have noticed that from the driver's side, I can roll the driver's side window up and down, but the "auto down" and "auto up" features don't work. I have the hold the button the whole time each way. The switch for the passenger's side window on the drivers side doesn't work at all! On the passenger's side, the switch for the passenger side window works, but again, it must be done manually both ways.
Is this something to do with swapping the battery (can't imagine how it could be, but that's the only thing I did that day) or is it something to do with the cold whether? |
01-05-2014, 06:06 PM | #2 | |
That ought to re-set the auto up & down. Yep, that can happen after the battery is disconnected. humfrz |
The Following 3 Users Say Thank You to humfrz For This Useful Post: |
01-05-2014, 06:18 PM | #3 | |
Sent from my Nexus 4 using Tapatalk |
The Following User Says Thank You to jonbonazza For This Useful Post: | humfrz (01-05-2014) |
01-05-2014, 07:12 PM | #4 | |
Drives: Asphalt FRS
01-05-2014, 08:20 PM | #5 |
I first read it in the owners manual for my wife's 07 Saturn. That happened to her car a couple of years ago, after I swapped out the battery.
I just checked, yepper it's in the FR-S manual also (page 53) .... humfrz |
01-05-2014, 11:48 PM | #7 |
Drives: Asphalt FRS
The Following User Says Thank You to Wolfking For This Useful Post: | jonbonazza (01-07-2014) |
01-06-2014, 12:19 AM | #8 |
The Following User Says Thank You to humfrz For This Useful Post: | jonbonazza (01-07-2014) |
01-10-2014, 02:50 PM | #10 |
Kato
Drives: The Black Beauty
If you live in a cold area you might run into the same problem with the auto up/down not working due to ice and it sticking, but the solution mentioned above fixes it all the same. I had to go a step further because it got stuck in the down position on a 5° day so I had to remove the negative terminal for while before I could roll the window back up to reset the motors.
Similar Threads | ||||
Auto-Up/Down and Passenger Window Not Working | chanomatik | Issues | Warranty | Recalls / TSB | 106 | 05-09-2021 01:25 AM |
Passenger window not working after rain reset does nothing | Mike86 | Issues | Warranty | Recalls / TSB | 0 | 08-30-2013 08:18 PM |
Bass Rattles Driver Side Window Switches.... | jadewbj | Issues | Warranty | Recalls / TSB | 14 | 05-19-2013 12:42 PM |
Simple Shut Window Feature Not Working on Driver's Side | Gimagination | Issues | Warranty | Recalls / TSB | 21 | 05-08-2013 11:59 AM |
TR-B1500 battery and billet battery tray install. | mines13 | DIY (Do-It-Yourself) Guides | 8 | 12-07-2012 03:59 PM |
