DIY (Do-It-Yourself) Guides For all DIYs. |
04-17-2014, 01:53 PM | #15 |
Drives: Scion FR-S
Awesome thanks. I actually ended up leaving the black wire connected and taking the red wire from both LED strips to that circuit. Worked like a charm. Although the LEDs turn off when the high beam is on, is this normal?
04-17-2014, 03:40 PM | #16 | |
Manual Noob
Drives: 2013 Scion FR-S MT Asphalt
The Following User Says Thank You to FRS_Sovereign For This Useful Post: | 86-tundra (04-17-2014) |
04-17-2014, 04:02 PM | #17 |
Troll Hunter
Drives: fr-s, tundra
Actually not sure if mine do this or not. You added that circuit to the same fuse location? Where did you hook up the black wire to?
04-17-2014, 07:13 PM | #18 |
Drives: Scion FR-S
Yes the same location to the left of the 30 Fuse. I actually left the black wire connected to the factory harness. I am actually running into a separate issue now that I did not notice before. While the lights turn on with ignition, they turn right back off as soon as I release the E-Brake.
04-17-2014, 07:36 PM | #19 |
AKA Mugen Dom
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Because there is power flowing through that black wire you left hooked up... you need it to have its own ground. The red wire is hot all the time unless you turn on your lowbeams... theres a few points I looked around while the bumper was off to ground to.. just find a bolt on the metal part of the car....wire brush a little or sand paper to get it to the bare metal...and connect the black wire to that. I FINALLY got the sidemarkers off right before I had to goto work...drove the FJ and will hopefully pull the stock lights off when I get home. Unless the wife says no lol...Im not sure if the sealant I used on the 1 winjet is fully sealed or not though...grabbed windshield sealant but it was a very runny silicone compared to the RTV I normally use...if it fogs up I guess I'll take it apart and reseal it.
The Following User Says Thank You to Fett4Real For This Useful Post: | 86-tundra (04-18-2014) |
04-17-2014, 11:14 PM | #20 |
Drives: Scion FR-S (2013)
I bought a couple of these fuses and the add-on-circuit. I hope it is right. Question: do i have to do anything to the end part (blue area) of the add-on-circuit? Also, is the bussmann fuses needed or not?
Thanks |
04-18-2014, 12:01 AM | #21 |
Troll Hunter
The add a circuit is right. Combine the two red wires coming from the head lights and connect them to that blue butt connector.. Then ground each black wire from the headlights to a bolt on the side of the car
04-18-2014, 12:02 AM | #22 | |
Troll Hunter
Fj plus frs is win
The Following User Says Thank You to 86-tundra For This Useful Post: | Fett4Real (04-18-2014) |
04-18-2014, 12:05 AM | #23 |
AKA Mugen Dom
Yeh shame theyre stopping production on em
04-18-2014, 12:09 AM | #24 |
Drives: Fire Storm Red Slush box gt86/frs
This post has been bookmarked great job man, I wanted to paint the bottoms black too because the OEM ones are half chrom half black, FTEIGHTYSIX has an option to have the Winjet headlights retrofitted with the Ds2 projectors and new ballast + DRL mod, but I'm not sure if they'll do the paint on the bottom
The Following User Says Thank You to ProjectGT86 For This Useful Post: | 86-tundra (04-19-2014) |
04-18-2014, 09:36 AM | #25 |
Drives: Whiteout FR-S
For those who have already painted your winjets, what lines did you use to paint the sides? Did you follow the crease where the "projector bulge" (for lack of a better word) meets the side? I ask because if you follow this crease/line all the way up the side of the headlight, it ends up curving along the top of the headlight... so did you end up with a small black painted part all along the side AND the top of the headlight?
I put together a crude MS paint with a red arrow of the crease/line I'm talking about and how it ends up curving on top of the headlight. |
04-18-2014, 03:32 PM | #26 |
AKA Mugen Dom
Exactly. ..same as the OP just no retrofit...5k HID kit.
Sent from my SCH-I545 using Tapatalk |
The Following 2 Users Say Thank You to Fett4Real For This Useful Post: | 86-tundra (04-19-2014), BlackieChanz (04-17-2018) |
04-19-2014, 12:25 AM | #27 |
Troll Hunter
Nice!! Looks great
The Following User Says Thank You to 86-tundra For This Useful Post: | LittleMonster (12-16-2014) |
04-19-2014, 12:26 AM | #28 | |
Troll Hunter
I am looking at your pic, I stopped right above there the comb lines are. So if you see the lines that look like a comb, go up until you see the next crease coming across, I stopped there. this is hard to describe but I am feeling lazy
The Following User Says Thank You to 86-tundra For This Useful Post: | ahquit (04-19-2014) |
Similar Threads | ||||
DIY Retrofit Winjet headlights | post_break | DIY (Do-It-Yourself) Guides | 6 | 07-15-2014 12:13 AM |
WTT: Winjet Black Headlight for Winjet chrome | dezmoondo | Exterior Parts (Aero, Lighting, Etc.) | 0 | 04-13-2014 03:02 AM |
Install Morimoto Retrofit kit into Winjet lights? | Khyron686 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 03-17-2014 05:55 PM |
Custom Purple Winjet and Black Winjet Headlights | xclusive_brett | Cosmetic Modification (Interior/Exterior/Lighting) | 35 | 12-17-2013 08:28 AM |
