Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 |
Drives: '15 BRZ, Vortech supercharger
I didn't have any stored codes, so I'm going to have to try to reproduce the symptoms.
Its good to know someone else has experienced something similar. Just to clarify, my CEL didn't go off right after I filled up, it took the 5 miles to home, then the 15 miles to work the next morning, and it was off on the trip back home. I didn't get any TPMS light though. |
#16 | |
He who smelt it...
Drives: 14 FRS Hot Lava
The Following User Says Thank You to Tcoat For This Useful Post: | kch (09-05-2018) |
#17 |
bromatic train injury
Wait, no. I'm stumped.
#18 |
That was supposed to be a joke. :/
#19 | |
Hey, @soulreapersteve, what did they replace in your tank?
#20 | |
Drives: 2015 FR-S AT, 2019 CX-5
You wouldn't happen to have a deatschwerks fuel pump or anything like that would you?
OFT Stage 2 UEL E85/Nameless Performance 3 inch axleback with 5 inch mufflers/ TRD CAI / CNT UEL/ Cusco Strut BAR & LHD Brake Stop / "JDM" Toyota Badges / WinJet JDM headlights - DRL MOD from fteightysix.com - 5000K Diode Dynamics HID kit / Diode Dynamics LED interior Lights and sidemarker bulbs / JDM Clear Sidemarkers / Diode Dynamics LED switchbacks/ OLM LED rear turn signals / Tap Turn Relay
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | Ultramaroon (08-29-2018) |
#21 | |
I took another trip to jersey yesterday and had a CEL on the whole time without any symptoms, so I'm thinking it's that dang 'small evap leak' again. I'm going to take it to get the codes read today, and also get a new serpentine belt because it started to shred itself up about 20 miles away from home on the way back... When it rains, it pours. |
The Following User Says Thank You to Whoodoo For This Useful Post: | FRSBRZGT86FAN (08-31-2018) |
#22 | |
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | FRSBRZGT86FAN (08-31-2018), Tcoat (08-31-2018) |
#23 | |
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | Ultramaroon (08-31-2018) |
#24 |
So it was a code P0456 small evap leak that made the CEL turn on. I have had that code before and it doesn't seem to have any rhyme or reason for when it shows up and goes away. Also, it turns out there were some stored codes. P1170 no DTC definition found, P0087 fuel rail/system pressure - too low, P0172 bank 1 system too rich.
Sounds like the ECU thinks I ran out of fuel too... Maybe I'll tuck into the fuel tank this weekend and see what I can see. I think the supercharger puts a lot more strain on the serpentine belt than the normal accessory drive and the cheap auto parts store belt I had on it just couldn't hold up. I have a continental belt on the way which should be better quality. |
#25 |
Drives: 2013 Ultramarine FR-S
I have the same issue currently. Cars runs out of Gas at 1/4 tank. Fill up takes ~8 gallons. Have had both sides of the tank open and couldn't find any issues. It sucks as I know there is still plenty of fuel left. Hopefully something is found soon.
#26 | |
Maybe install a fuel starvation door see if it clears it up. Then you can see if maybe someone installed a fuel pump or the like
#27 | |
Also, after clearing the codes from last time, the CEL came on yesterday morning when I went to work but I haven't had it read yet. I wanted to see if there is an aftermarket fuel pump, so I pulled that out and discovered a Deatschwerks 340lph pump that had been installed a little weird. First, the snap ring that holds the top part into bottom part was gone and replaced with a little bit of safety wire. When I took the pump out, the bottom plastic piece that holds the pump in place was missing - the inlet sock was just captured on the bottom of the pump by the top portion of the housing that snaps in place. So, I'm going to try to find a new sock so it isn't as Jerry-rigged, but im also not sure if the pump is the problem, so I may end up getting a new one just in case it is... There was a little bit of crap stuck to the sock, and the inlet looked dark like it was dirty. Do you think it could be a bad pump? I'm going to start looking into injectors next. Anyone know of a good way to identify them? I know they aren't the stockers, but I couldn't see any identifying marks on them just looking from the top of the engine. *edit* I watched a couple of fuel pump install videos and it appears the sock was the one supplied in the Deatschwerks install kit. It didn't stay attached to the bottom of the pump, though. I thought maybe the sock wasn't properly attached and the bottom of the pump and crud got in there and messed it up, but now I'm not sure... Last edited by Whoodoo; 09-12-2018 at 08:03 PM. |
#28 | |
I am going to see of DW with warranty the Pump/check to make sure it's 100%.
Out of fuel with 2 gallons in the tank | Simisimi | Issues | Warranty | Recalls / TSB | 31 | 06-18-2015 03:30 PM |
