Old 09-30-2022, 04:08 PM   #1
gpvecchi
gpvecchi's Avatar
Disable door chime?
I didn't find an option in Techstream to disable the annoying door chime, do you know if it's possible?
Thanks!
Old 09-30-2022, 04:29 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
Thanks!
Our Twin has a door chime? That's noise to me! Is it specific to certain markets?
Old 09-30-2022, 05:57 PM   #3
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
Are you referring to the long beep when you open the door while the car is running and then turn off the car? That means your headlights are on.
2020BRZtS is offline   Reply With Quote
Old 09-30-2022, 06:05 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Maybe he means the "key in ignition" warning when you open a door with the key still in
Old 09-30-2022, 07:01 PM   #5
tomm.brz
Drives: brz 2017 hksv2
we only have wireless key like on your limited's
but yes, or it happens when you open the door and then shut the engine off too, for example
anyway no, no chance to disable it unless you unsolder the buzzer
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
gpvecchi (10-01-2022), x808drifter (10-01-2022)
Old 10-01-2022, 03:13 AM   #6
gpvecchi
gpvecchi's Avatar
It's a chime that sounds when you have engine running, you open the driver's door, then you turn off the car.
Old 10-01-2022, 05:14 AM   #7
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
So, turn the car off THEN open the door?
Not sure why anyone would do it reverse.
Leaving the engine on and getting out is one thing.
Old 10-01-2022, 10:18 AM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
happens to me all the time. i'm shutting the motor down as i'm opening the door with my other hand. i just put up with the beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeep
Old 10-01-2022, 10:41 AM   #9
2020BRZtS
2020BRZtS's Avatar
Have you ever owned a Dino? My dogs are very excited to see anyone come home. I open the door as soon as I pull in the garage so they don't jump up on the door and scratch the paint. Then I shut off the car. To give it perspective the dogs are 80 and 174 lbs.
Old 10-01-2022, 10:43 AM   #10
2020BRZtS
2020BRZtS's Avatar
Turn off your headlights and it will stop.
Old 10-01-2022, 10:47 AM   #11
soundman98
soundman98's Avatar
i'm a bit too young to have owned a dinosaur. but i hear humfrz enjoyed the time period.
Old 10-01-2022, 10:48 AM   #12
soundman98
soundman98's Avatar
lights are never on when i shut the car off. that ain't it.
Old 10-01-2022, 10:49 AM   #13
2020BRZtS
2020BRZtS's Avatar
Are they truly "off" or are they on "Auto"?
Old 10-01-2022, 10:52 AM   #14
2020BRZtS
2020BRZtS's Avatar
The Following 2 Users Say Thank You to 2020BRZtS For This Useful Post:
soundman98 (10-01-2022), x808drifter (10-02-2022)
Door Chime Question ericmpena BRZ First-Gen (2012+) -- General Topics 23 05-10-2021 11:56 PM
Oil consumption? Please chime in OnTheFence Issues | Warranty | Recalls / TSB 48 10-01-2019 08:42 PM
Disable your seatbelt chime. DIY Natedawg Scion FR-S / Toyota 86 GT86 General Forum 31 01-12-2015 02:22 AM
Door Chime Question Ec1990 BRZ First-Gen (2012+) -- General Topics 6 08-20-2014 11:13 PM
DIY - Auto up/down disable (and retain door open indicator) Imperius DIY (Do-It-Yourself) Guides 4 02-10-2014 03:17 AM
