Member's Car Journals Car journals by our members. |
04-29-2020, 09:26 AM | #281 | |
Site Moderator
Drives: ichi 86 Project
I would of expected 3mm would be pretty solid. Plus if you wanna go structural, recommend getting trunk braces. They’re more structurally effective |
04-29-2020, 09:49 AM | #282 |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
well wanted to get structural without adding weight of metal bars + covering the rear seat area. Don't need to get that structural I guess its plenty strong
The Following User Says Thank You to SuperTom For This Useful Post: | ichitaka05 (04-29-2020) |
04-29-2020, 12:31 PM | #283 | |
Drives: 2017 86 860 Special Edition
The Following User Says Thank You to RayRay88 For This Useful Post: | SuperTom (04-29-2020) |
05-03-2020, 12:45 PM | #284 |
Made a huge sacrifice to the car gods with one of the big weight reduction mods the LIGHTWEIGHT FLYWHEEL!!
Went with this Ebay Special FX Flywheel for $140. https://www.ebay.com/itm/FX-RACING-C...72.m2749.l2649 It had good product reviews on Amazon so that was good enough for me. I reused the stock clutch/pressure plate. I also put in the Upgraded TOB, Velox clutch fork, Velox Pivot, new Fork clips Not going to post a install instructions as plenty of those are out there. My only advice is taking the time to remove the shifter completely instead of the unclipping from underneath shortcut. Taking the shortcut made it a pain to remove and install the tranny if your doing this in your driveway on jackstands. And jacking the front of the motor makes it easier to line up and slide in So now onto the weights Stock Flywheel 19.75lbs FX flywheel 11.75 for a MASSIVE 8lb LOSS! Stock Pivot arm .75lbs Velox heavy duty arm 1lb 6oz, for a 10oz gain Also added Torque Solution transmission mount + Aliexpress Shifter base bushing I haven't pushed it yet as I want to honor the breakin period but everything seems smooth. And to be honest don't notice any driveability issues. I did have to adjust the clutch engagement for the pedal. Overrall a nice chunk of weight off the front of the car again! |
05-13-2020, 03:34 PM | #285 |
Just Finished my rear seat flat plate. Also used it to remount the battery here instead of the the trunk.
First the weights out of the way The CF plate 2.25lbs + the black carpet covers 1lb =3.25 -minus old carpeted rear seat delete + stock center carpet = 2.5lb Ill add in .25lbs for bolts so total gain is 1lb I could shorten the power cable a bit and lose some weight but I left it alone for now CF Plate Carpeted pieces - pet slept on adding hair weight haha -old Carpet pieces + stock piece NOW ONTO The PICS! Carpeted piece. Used Rivnuts into the stock side armrests for mounting. Seat installed Used 2 small braces under the plate, plate is riveted to brace as you can see under battery |
The Following 12 Users Say Thank You to SuperTom For This Useful Post: | Berserker (05-31-2021), Iceman (05-21-2020), in_sherman (05-23-2021), MCTeeJ (05-13-2020), ML (05-14-2020), new2subaru (05-16-2020), PulsarBeeerz (05-24-2020), q335r49 (05-15-2020), RToyo86 (12-14-2020), sato (06-06-2021), Stonehorsw (06-01-2021), Wally86 (03-30-2022) |
03-29-2022, 05:57 PM | #287 |
Aliexpress steering wheel mod $40
Whats up everyone been gone for about 2 years. Spent that time away from cars. Mainly focusing on Crypto mining rigs. But now im making a comeback!
My first mod back is Aliexpress steering wheel mod I ordered these for about $40 https://www.aliexpress.com/item/1005003611999757.html https://www.aliexpress.com/item/1005002073638401.html Used this guys video on how to do it. I removed the horn/airbag and the steering wheel buttons. At the end used 3m double sided tape in the area near the steering wheel controls to pull, then tuck underneath Before During After! |
04-02-2022, 03:04 PM | #288 |
Drives: 2022 WRB BRZ limited
It’s good to have you back! What are your plans to further lower the weight? You’ve done a lot already… maybe something radical like a K-swap?
The Following User Says Thank You to AgentBlue243 For This Useful Post: | Jdmjunkie (04-02-2022) |
04-06-2022, 06:35 PM | #289 | |
Just added in the JDL catted/Resonated Front Pipe! This is about 5lbs heavier than my straight FP, but 2.5lbs lighter than stock. As a daily driver I could no longer bear the smell of being completely catless Current weight 2349.5 lbs. As long as I stay under 2370 which would be 400lbs less than stock ill be good. |
The Following User Says Thank You to SuperTom For This Useful Post: | Wally86 (04-07-2022) |
04-07-2022, 06:11 PM | #290 |
Aliexpress Day!
Added more weight (+3.5lbs)with this CF weave center console added today from ALiexpress. It slides right in and out (so I can remove it), also has this nice usb connectors.
Also added all these CF pieces from Aliexpress Speedometer, Vents, Door pieces, HVAC area, Roof |
04-11-2022, 09:16 PM | #291 |
Major Changes
So the past few weeks Ive been working on repainting my car. Literally used $5 a can Rustoleum Flat White. I neglected my car for 2 years so some of the dry carbon on the fenders ect had cracked other various cosmetic issues that would be costly to have entire car painted elsewhere. Im very happy with my rattle can results
Also added splitters, side skirts, spats. Painted anything matte black to a Gloss Black and 2k Clear and also added red pinstripe. And got some New Konig Hypergrams in Carbon w/lip 17x9 Last good old pic from 2 years ago NEW!
The Following 6 Users Say Thank You to SuperTom For This Useful Post: | Espi (04-12-2022), Jdmjunkie (04-11-2022), ML (04-12-2022), new2subaru (08-28-2022), villainous_frx (04-12-2022), Wally86 (04-12-2022) |
04-12-2022, 09:30 PM | #292 |
Forgot to add my weight increases with the mods
Konig Hypergrams 17x9, nexen Nfura 245/40/17 = 38.5lbs 2lbs heavier than my 17x8 setup but much more grip and still lighter than stock front lips 1.4lbs SIde skirts 2.7lbs rear spats 1.1lbs |
04-20-2022, 09:52 PM | #293 |
Drives: 2013 FR-S Vortech V3
Car looks awesome, good work on the paint
The Following User Says Thank You to GabeoHuncho For This Useful Post: | SuperTom (04-22-2022) |
Similar Threads | ||||
mothespaceman: 14' Satin White BRZ Build! | mothespaceman | Member's Car Journals | 25 | 09-19-2014 05:30 PM |
White BRZ Limited Build Thread | NoFlush | Member's Car Journals | 4 | 05-10-2014 02:04 PM |
white trd 2013 build | Pcharliep04 | Member's Car Journals | 0 | 04-24-2014 01:25 AM |
Build-thread White Wasp FR-S by Mit_Peid | mit_peid | Member's Car Journals | 7 | 01-05-2014 07:47 PM |
White GT manual Jan Build availlable | 86•BRZ | AUSTRALIA | 2 | 01-01-2013 11:45 PM |
