Tracking / Autocross / HPDE / Drifting What these cars were built for! |
10-12-2018, 12:33 PM | #15 | |
Drives: tbd
Look, let me explain something to you. I'm not Mr. Lebowski. You're Mr. Lebowski. I'm the Dude. So that's what you call me. That, or His Dudeness
Duder
or El Duderino, if, you know, you're not into the whole brevity thing.
The Following User Says Thank You to boze_man For This Useful Post: | Shark_Bait88 (10-12-2018) |
10-12-2018, 12:38 PM | #16 |
Drives: tbd
I wish...will have to check with my accountant (wife).
or as the dude says..."By the way, do you think that you could give me that $20,000 in cash? My concern is, and I have to, uh, check with my accountant, that this might bump me into a higher, uh, tax bracket"
Duder
10-12-2018, 01:03 PM | #17 |
Drives: 2017 Subaru BRZ Limited
Sorry, I don't know any shops in South Jersey specifically. I definitely agree with you on FT86 vs Miata. I almost bought the new Miata RF, and I went with the 86 instead because it felt remarkably similar in handling performance but looked better and I (maybe a bit irrationally) hate convertibles, even hard tops. Found out later from some track buddies that they'd had Miata RFs and traded them in for FT86s, or to acquire an older car (S2000, NA/NB Miata). For the price differential, the FT86 is just better at this point in time, although the new 2019 Miatas got a power boost which might help since they still weigh ~300 pounds less from the factory. Of course you can't fit a full set of wheels/tires and a tool bag into a Miata on your way to the track like you can an FT86 On the necessity of an oil cooler, it really depends on how hard you're pushing the car and what the weather is like. If you are an experienced track driver I feel like you'd need the oil cooler right out the gate. These cars run hot on oil temps and tend to have somewhat scary oil pressure drop offs as that happens. In Texas this summer I was seeing oil temps >270F before I added an oil cooler... anything above about 240F is definitely causing a pressure drop on 0W20. You may be able to get by running a heavier weight of oil (5W30 or 5W40) in the interim, but before long no matter what you'll need the oil cooler. Might as well get it done right off the bat and potentially save your engine some heartache. Yeah, people have gotten the GT3 ducts working although I don't really feel like this car needs brake ducting with stock power. But maybe I'm just not a good enough driver on grippy enough tires to make it necessary yet. |
The Following User Says Thank You to Tristor For This Useful Post: | atomicalex (10-15-2018) |
10-12-2018, 01:03 PM | #18 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
To answer your quoted questions some:
Yes, people have used the GT3 ducts on various platforms. Not much exact data, but for $30 don't think they hurt Yes, an oil cooler is needed. AZP Installs is in Jersey, not sure exactly where though. |
10-12-2018, 01:27 PM | #19 |
Drives: tbd
gracias el presidente
Duder
The Following User Says Thank You to boze_man For This Useful Post: | finch1750 (10-12-2018) |
10-12-2018, 01:30 PM | #20 |
Drives: 2013 Firestorm FR-S
For the first few track days, I'd argue an oil cooler isn't needed. I've done 6 without one, though I added one this year, and know of somebody else (much faster than me) that did significantly more track days before adding his. When I say it isn't needed, I mean that it's not a guarantee you'll have a catastrophic failure. But it's still a good idea.
"Shark_Bait88, the man whos spent the most money modding his stock FR-S and its still stock." -@jdnguyen
The Following User Says Thank You to Shark_Bait88 For This Useful Post: | atomicalex (10-15-2018) |
10-12-2018, 02:07 PM | #21 |
AZP Installs is good.
Pads, fluid, oil cooler. If the plan is to track the car somewhat often, just get the oil cooler from the start and you will have 1 less thing to worry about. Bonus points for a basic alignment with camber bolts. From there...so many ways to go, but that's the way to start. - Andrew |
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
10-15-2018, 08:42 AM | #22 |
Drives: 2018 BRZ Limited Perf Pack
Headed out to Grattan on saturday, thank you for all the replies here as this will be my first day out with daBRZ.
www.atomicalex.com
2018 BRZ Limited Perf Pack 6MT, a couple of motorcycles, and a stick shift station wagon |
10-15-2018, 10:15 AM | #23 | |
Drives: '13 Whiteout
Since you plan on continuing tracking I WOULD think about an oil cooler, new pads and fluid as you mentioned asap |
The Following User Says Thank You to TommyW For This Useful Post: | atomicalex (10-15-2018) |
10-15-2018, 03:08 PM | #24 |
10-15-2018, 08:20 PM | #25 |
These cars are pretty sorted right out of the box. These mentioned improvements and THEN better tires and wheels and that will be 90% of the whole program. I'd concentrate on driver mods more than throwing more parts on the car. Once you can take the car to its limits with proper rotation etc then and only then would I start adding more shiny things
The Following User Says Thank You to TommyW For This Useful Post: | CSG Mike (10-15-2018) |
11-09-2018, 10:40 PM | #26 |
Drives: 2018 Gt86
I bought a base 2018 86 for $2500 off msrp in July. I've taken it to two track days at Summit Point and one at Dominion. It's addicting. I Upgraded brake pads/fluid and factory wrx camber bolts. It seems to be working out well. It is my daily and has 10k mi already (100mi commute). I am running Motul 300v 5w-30 and don't plan on an oil cooler until the warranty is up.
I considered a Miata but my head rubs. Tracks don't like them without rollbars anyway. Considered FiST as the rebates were stupid. From an autocross point of view I should have gone that route but the seating position doesn't seem right. Consider a pre 2017 86 if autocross figures prominently in your future. They have there own class that jives with popular mods. Driver mod is the program for 2019 My plan is 6-7 hpde next season with as many autocross events as I have time. I've read that sim racing and analysing datalogs and video is helpful. Thinking Aim SOLO dataloger and a real computer w/sim wheel pedals ect are in my future. I'm also crewing for a champ car and spec944 teams. Just to get a feel if W2W is my scene. Hopefully that info helps inform your decision. |
11-10-2018, 12:32 PM | #27 |
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
If you need an oil cooler, you need an oil cooler. No difference in not running one on the first track day or the 15th track day. They're cheap and easy to install. I dont know why you wouldn't.
There are definitely cheaper ways to go faster than the FT. However, a lot of those ways aren't cheap to run. You could go buy a bone stock C5 but your consumables will be high. Light cars and low power cars make for cheap consumables. I've only done one day in an FT, but from that day and from what I've read, I'd expect consumables to be about $125-150/hr- about the same as my Miata. Basically, one set of $900 tires every 4 track days tires, depending on where you drive and how hard (and if you have camber plates). All the other stuff is pretty cheap per hour, especially if you upgrade to a BBK up front. In contrast, my C7 is about $450/hr. I'd venture to guess it's very similar, maybe slightly lower, on a C5. Call it $350/hr. Neither of those figures include engine or trans or diff wear- which I assure you is about 5-10x higher per hour on a heavier, more powerful car. I can afford a lot of $250-300 track days. I can't afford nearly as many $1000 track days. Add up consumables to get a real idea of what the cost is. 20 track days a year on my C7 probably means about $20k plus half an engine and half a trans. In two years when I'll certainly need a motor and a trans, I've probably spent $60k . In the FT- I'm looking at $6000 for year one. After year two, with a new engine and trans I might be at $15k. That's $45k difference over just two years. Also, the FT is a LOT of fun, and that's the end goal for HPDE. I've driven a lot of fast cars, and they can be fun, or they can be a handful (and sometimes, both). Fast car doesn't mean fun car, nor does it mean a good car to learn on. The best thing I did to lower lap times in the Vette wasn't private instruction or more seat time in the vette. It was driving the Miata. In all honesty, it wouldn't surprise me if my BRZ was within 3 seconds of my GS on the same tires. Granted, the BRZ is gutted, caged, coilovers, etc and the GS is stock. I'll drive my GS at tracks like Circuit of the Americas, but for club tracks, it will be the FT (or Miata) almost every time. THAT is why I got an FT over a C5 or C6 or Cayman or something. I can afford any of those cars. I can't afford to run them. And that's something you should STRONGLY take into consideration before starting with any platform.
2014 BRZ: Full track car. Gutted, caged, coilovers, AP enduro, OMP, bolt ons, aero, etc,
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1992 NA Spec Miata: 1.6 + 1999 NB Spec Miata: 1.8 w/ all the goodies. 2018 GLE 63 AMG: +800hp whistling AWD TT V8 grocery getter 2016 GX460: IDK. Too reliable to sell. Too boring to use. Last edited by GrandSport; 11-10-2018 at 01:13 PM. |
The Following User Says Thank You to GrandSport For This Useful Post: | treedodger (11-10-2018) |
11-11-2018, 08:45 PM | #28 |
Drives: 2018 Gt86
Interesting numbers. What is cheaper than a FT? How much more are HPDE than W2W? I have a buddy who says his spec 944 isn't costing him more to run than his Corvette was.
Similar Threads | ||||
Ohlins Road & Track - settings (clicks) for street/track/ax | dp1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 06-27-2016 09:36 PM |
Tein Street Flex Questions | WolF_RS | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 06-02-2016 02:27 AM |
Street Mod questions | Shit Luck | Tracking / Autocross / HPDE / Drifting | 61 | 10-18-2015 04:59 PM |
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped | GuerillaRacing | Brakes, Suspension, Chassis | 149 | 05-12-2015 05:53 PM |
New FT86 Owner, some questions. | Parix | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 05-26-2014 07:41 PM |
