Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
07-10-2013, 02:15 PM | #29 | |
Drives: 2013 BRZ Limited - WRB, MT
07-10-2013, 04:05 PM | #30 |
the parts of the base that got messed up when the screws ripped out is backordered of course. luckily they gave me a regular mirror for now until it comes in and it's rattle free problem solved lol
07-21-2013, 10:06 PM | #31 |
Drives: 2018 BMW M2
Just started to notice this rattle today after a long drive. I can only hear it when the roads are bumpy. Going to check to see if it's the rearview mirror.
07-23-2013, 12:07 AM | #32 |
probably is. i didn't even think to check it till everyone else said to look at the screws on the base. I took the one screw out that holds the mirror down and sure enough, 2 of the screws holding the adapter in were completely stripped and slid right out. Got mine fixed and the rattles gone for now
07-23-2013, 12:45 AM | #33 |
Drives: 2018 BMW M2
Anyone with regular rear view mirrors have this problem?
07-23-2013, 06:53 AM | #34 |
Drives: BRZ DGM Limited
Anyone figure out the rattle left side of dash near the door?
07-25-2013, 01:16 AM | #35 |
Drives: 2023 Toyota GR86 Premium
Mine was the fuse box under the dash on the left. If you hear it rattling, reach down and push/pull the box to the left or right and see if it stops.
To fix it I just shoved some foam between the fusebox and wiring harness it was vibrating up against. Sent from my iPhone using Tapatalk 2
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
The Following User Says Thank You to wdninja For This Useful Post: | jimmillion (07-06-2014) |
07-25-2013, 08:04 PM | #36 |
It does sound like it's coming from that area...I'm going to take a look. thanks
09-01-2013, 12:11 AM | #37 |
I've fixed a few rattles so far, but have a new loud one from somewhere behind and to the left of the glovebox. It's not the glovebox itself because I removed it completely and it was still doing it. Any ideas before I tear it apart?
01-05-2014, 03:01 AM | #38 | |
I figured it out, it was the AC blower motor housing. I removed the blower motor and on the bottom there's a little plastic door that was making the noise. I lined it with felt tape and it went away.
05-08-2014, 08:52 PM | #39 |
Drives: Scion FR-S 2013 Raven
rattle behind the dash
I have a rattle from my glove box and when I open it, the rattle stop, then am sure the glove box is the cause.
I have also found this : http://www.toyotanation.com/forum/15...confirmed.html
o= FR-S =o Last edited by Mikepage; 05-13-2014 at 07:24 PM. |
05-10-2014, 08:51 PM | #40 |
Anyone with the same glove box problem?
o= FR-S =o |
05-13-2014, 07:25 PM | #41 |
Then am alone :_(
o= FR-S =o |
05-14-2014, 07:34 PM | #42 |
Drives: Red Gt86
Rattling sound
I am facing the same irritating rattling sound inside the cabin and clueless. Tried securing the wiring at the engine bay , tightened the strut bar but the sound still refuse to go away every time the car drives off and hit bumpy road or upslope But the wierd thing is the sound will go away after 20-30min on the road when the engine is hot.
It seem to be coming from the left side of the car. Will try to hold on the rear view mirror and see if it goes off |
Similar Threads | ||||
WTT: My FR-S black dash trim pieces for your BRZ silver dash trim pieces. | Tim_Asphalt_FRS | Interior Parts (Incl. Lighting) | 1 | 05-13-2013 06:25 PM |
Does anyone have a rattle coming from the center dash? | Liquidsnake | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 09-30-2012 10:09 AM |
Steering wheel/dash "rattle?" upon heavy acceleration? | brett_g | Issues | Warranty | Recalls / TSB | 2 | 08-04-2012 04:52 AM |
Trade my black dash plastic for your silver dash plastic thread. | F3dzo | Southeast | 0 | 07-17-2012 10:06 PM |
A/C Rattle? | djliquidsteele | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-17-2012 07:46 PM |
