Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Old 08-25-2019, 12:06 PM   #15
i8ur911
Drives:
Do you get a vibration at any speed while driving straight?
Sent from my Pixel 3 using Tapatalk
i8ur911 is offline   Reply With Quote
Old 08-25-2019, 12:22 PM   #16
churchx
churchx's Avatar
Drives: 2014 orange GT86
Originally Posted by Rookie_34 View Post
I have on the bc br coilovers, i installed them myself. My car is on 18's and im running 225 front and 235 rear. I honestly dont think im hitting the bump stop. And so far all my test turns have been towards the right. Havent yet tried a loop turn lefty. If this helps, last night did pedal dance and took a long right loop, about 80mph, after exiting the loop. my car started to swerve like very dangerously. I ended up slowing down to 60mph. Its very scary.
Sounds to me like there might be excessive toe-out rear (when it should be in rear slight toe-in and even side to side). And again, without seeing alignment numbers cannot tell anything for sure.
The Following User Says Thank You to churchx For This Useful Post:
strat61caster (08-25-2019)
Old 08-25-2019, 02:19 PM   #17
strat61caster
Thread Killer
strat61caster's Avatar
Drives: '13 FRS
+1 the only thing to suggest until seeing the alignment printout is making sure suspension arm bolts are tight in the back. Most should be around 86 ft-lbs
ineedyourdiddly
Old 08-25-2019, 10:17 PM   #18
Joyride86
Joyride86's Avatar
Drives: 15 FR-S Firestorm MT
So you're taking an exit loop at 80 mph. Not to be a jerk, but are you just going too fast and your rear end is breaking loose? Why would you do the pedal dance to turn off the stability control etc? Also, you referenced tire size, but didn't mention the condition of them or maybe possible poor road conditions. Based on what you said, it's still could be a bunch of different things that are causing your issue.
Diode Dynamics Tail as Turn, LEDs, HIDs | Yospeed Custom Plaque and Frame | Suntek Carbon Tint | Spyder Smoked Side Markers | GrimmSpeed License Plate Relocator and Hood Struts | Five:AD Spoiler | JDM Armrest | Beat-Sonic Backup Cam | Moddiction Anvil 2 | Invidia N2 |
Joyride86 is offline   Reply With Quote
The Following 3 Users Say Thank You to Joyride86 For This Useful Post:
fuddbutter (08-27-2019), spike021 (08-27-2019), strat61caster (08-25-2019)
Old 08-26-2019, 09:32 AM   #19
Rookie_34
Drives: 2014 frs
My rear toe is set at 0.08, before the alignment with vsc and traction control off, the car wouldnt jerk so badly when cornering. Pedal dance a first loop and it felt great. I thought oh the alignment might of fixed it. Then the next loop i did 80 and as i exited, thats when the nightmare almost happend. Sometime this week ill have to get under and check suspension. Also ill get alignment sheet up. Thx
Rookie_34 is offline   Reply With Quote
Old 08-26-2019, 10:02 AM   #20
Vital
Drives: 2015 BRZ
Can you just post your alignment numbers? Or if you dont know how to do that tell us what the values are... there is no way to help unless we see that. And again have you checked your tires? are they worn or not....
Vital is offline   Reply With Quote
The Following User Says Thank You to Vital For This Useful Post:
i8ur911 (08-26-2019)
Old 08-26-2019, 10:08 AM   #21
Racecomp Engineering
1. Slow down until you get this figured out.
2. Tires:
What KIND of tires?
How many miles are on them and do they appear in good condition?
Can you measure the tread depth?
What are your tire pressures?
3. Can you take a picture of your alignment print out and post it?
4. Are the coilovers your only suspension mods?
5. Do you have a good local Subaru or race shop nearby?
- Andrew
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
spike021 (08-27-2019), wparsons (08-26-2019)
Old 08-26-2019, 01:46 PM   #22
timurrrr
timurrrr's Avatar
Drives: 2017 Subaru BRZ with PP
Are you taking it with maintenance throttle (i.e. just enough throttle to maintain constant speed through a corner) or no throttle at all?
It's ok for the car to have tendency to oversteer at the limit when you're off the throttle.
timurrrr is offline   Reply With Quote
The Following User Says Thank You to timurrrr For This Useful Post:
Old 08-26-2019, 02:54 PM   #23
Icecreamtruk
Drives: Track preped NA FRS
Im going with OP has never before experienced oversteer and is just scared shitless of it
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Old 08-26-2019, 04:13 PM   #24
wparsons
wparsons's Avatar
What spring rates? How low is the car? What are the full alignment specs?
flickr
Old 08-26-2019, 05:16 PM   #25
Rookie_34
Drives: 2014 frs
http://imgur.com/a/ZnEcEWQ
I asked for -2 camber front and factory specs foe the rest. Because i only have coilovers. He couldnt adjust the rear. My tires are hankoon evo v12, about 5k miles on it. During straight driving its fine. But if i was gonna switch lanes fast, it will jerk me pretty bad. Spring rates are factory, i believe 8k 8k..
Old 08-26-2019, 06:34 PM   #26
norcalpb
norcalpb's Avatar
Drives: '13 DGM BRZ Limted
The front camber is too off IMO. Id have them dial back the driver side camber to whatever max camber the passenger side can put out. You also gain driver side camber by sitting in the car...
Your caster seems to be 1 degree less than stock? That paired with 8k (450lb) springs on a bumpy highway may be your issue.
Old 08-26-2019, 07:36 PM   #27
i8ur911
Drives:
My guess is that your alignment is screwed up. I'm not buying that those are your actual alignment specs (fyi, it's stupid easy to put whatever specs you want on that printout - for a tech, not the OP).
I'd highly recommend checking to make sure everything is tight and then bring to another alignment shop.....even a dealer if you have one local.
Also, I'm assuming the car is slammed given the rear camber. I personally would raise the car up a bit as that will improve drive-ability.
The Following User Says Thank You to i8ur911 For This Useful Post:
Tristor (09-15-2019)
Old 08-26-2019, 08:00 PM   #28
churchx
churchx's Avatar
Under alignment pic was pic of car. It IS slammed. No wheel gap, no suspension travel, and no driveability . I guess though he may need that much rear camber simply for rear wheels to not rub on fenders at such drop, not sure.
Well, except of probably observable extra rear tire camber wear and probaly also wear on rear axle joints, his rear alignment doesn't look that bad toe-wise/evenness wise, which often are among very common causes for ease of loosing rear grip.
Though that front alignment freaks me out with half degree of difference for both front camber and caster. I guess those coilovers have camberplates so tech should be able to dial any camber within some .. 0-2deg? I have suspictions that just one of camberplates are installed differently. For example at different angle to affect both caster/camber, or misadjusted caster if it is adjusted separately like on eg. raceseng cascamplates, or all that tech did at front - dialed camber at camplates by notches on them w/o looking at actual alignment, then did a bit work on toe and left at it deciding to not bother more with cycles of crawling up for camber adjustment at camberplates and then back under car for toe adjustment.
Rookie_34: btw, like i8ur911 did, i also would advise to rise back car a bit to gain back some suspension travel, comfort and compliance for daily driving, reduce illchange of roll center, reduce that excessive rear camber and so on. Lowering within inch should make things much more reasonable/usable.
To my uneducated eye alignment doesn't seem that bad to easily loose rear traction. Maybe @Racecomp Engineering may comment better these numbers?
The Following 2 Users Say Thank You to churchx For This Useful Post:
Tristor (09-15-2019), wparsons (08-28-2019)
Search this Thread:
Advanced Search
Rear Suspension Clunking, front suspension groaning Butterballz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-14-2018 07:10 PM
OEM suspension and Rear Suspension Lateral Link Rod jprules Want-To-Buy Requests 3 10-04-2017 06:56 PM
Suspension Super Sale ISC Suspension | KW | Tein | Cusco and More OCRaceShop.com Brakes, Suspension, Chassis 14 08-26-2015 10:43 AM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 05:06 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
